Question about Coleman Cable Woods 59018 InWall 7Day Digital Timer White
Are the 7 different programs for 7 different days or are they exclusive?
There are 7 ON events and 7 OFF events
http://waterheatertimer.org/pdf/Woods-59028-59018.pdf
When programming the timer, you select individual days or blocks of days.
For example program1 ON time
Set the Hour
Set the minutes
Press the day key to scroll through the possible choices.
Then you set program1 OFF time
Set the hour
Set the minute
And then press the day key to scroll through the possible choices.
The choices are:
Each individual day
Monday thru Friday
Sat-Sun
Monday thru Sat
Monday thru Sun
Monday-WED-FRI
Tues-Thurs-Sat
Mon-Wed
Thurs-Sat
The key is to set the ON and OFF times for the same days or blocks of days
For example program1 ON is 8:00 am Mon thru Friday
Set program1 OFF for 3:00 pm Mon thru Friday
and then program2 ON is 8:30am Sat-Sun
program2 OFF is 5:00pm Sat-Sun
Program 3 ON is 6:00pm Tues-Thurs-Sat
Program3 OFF is 9:00pm Tues-Thurs-Sat
Program4 ON is 6:00pm Sat
Program4 OFF is 11:00pm Sat
Programs5, 6 and 7 might not be needed
The key is to make a chart of times before setting timer.
The chart will prevent conflicts in programming where the timer does not operate as expected.
Posted on Nov 08, 2010
Can I put my central heating on a different time from my water horstmann didam 425
It appears there are 4 trippers on the daily time dial that control all timing. 2 On and 2 OFF
On the right side are override switches for Hot water and Heating
You can only separate Hot water and Heater programming a little bit.
You can choose to have Hot water ON all day, or turn on-off once per day or turn on-off twice a day. Or OFF all day.
The Heater has the same options and the same on-off times as the Hot water.
Manual:
http://www.horstmann.co.uk/files/2513/9867/2118/user_guide_425-TiaraDiadem1.pdf
For fully separate programming, where Hot water and Heater can each be programmed differently, you would need a 2-channel controller like the Grasslin QE2
http://www.grasslin-controls.co.uk/towerchronqe2.html
http://waterheatertimer.org/pdf/Grasslin-QE1-QE2_GB-instructions.pdf
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 11, 2014 | Water Heaters
How do i program my nexxtech 4 in 1 universal remote
Go to the link below and select your remote model number. You will be able to download the remotes manual with programming instructions:
http://www.thesource.ca/estore/exclusive.aspx?language=en-CA&category=Universal%2bRemotes&brand=NEXXTECH#parts
May 22, 2011 | Televison & Video
I installed Rosetta Stone and got the error 2123, is this a driver problem?
Hello my friend.Usually this error is cause because antivirus is blocking that program and usually bitdefender.So
1.Open BitDefender Antivirus in Expert Mode,
2.Click on the Antivirus tab
3.Under the Shield tab click on the Advanced Settings button.
BitDefender Active Virus Control Settings window should be displayed
4.Now add an exclusion for Rosetta Stone(click on + and find your program and click ok)
If you don't have bitdefender add an exclusion like we did with bitdefender for your rosetta stone
Feb 08, 2010 | HP Computers & Internet
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
I have a motorola razr v3 and i lose connection
From what I have been told from a similar experience is: When it is a phone that is exclusively made for one service provider they tend to pick up a better signal since they are programmed to just accept that signal. Motorola makes phones for many service providers so they don't program it to be exclusive to one provider. By doing this the phone doesn't pick up as good of a signal as it would if it were originally programmed to pick up just one provider. I know this is a bit confusing and kinda hard to make sense by typing it but I hope it atleast helped a little bit.
Jun 14, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Calculate Quarters between any two dates
not sure if this is what you are after entirely but should at least help you out some what
=DATEDIF(A3,C3,"m")/3
As you said you cant just divide by 3 but I have divided the formula by 3 to see how many 3 months will go into the output you could maybe have another formula to divide it by 2 to see if it will divide by 2 to see if you get a whole number or not, if you do then you can just return the first part before the dot ( using split function ) and if the value is less then 1 then obviously the 3 months has not passed between the 2 dates
May 09, 2009 | Microsoft Office Excel 2003 for PC
Quickbooks Pro 2005 Access
If I remember correctly you have the option to share quickbooks or to use it exclusively....(and it was part of the setup). Fixing that (should be some reference to it in the help menu) cures one problem. Not being able to close it is a different problem. I can't remember exactly but I do know there was a decision somewhere in the set up that allowed you to share or not share the database. If others are signed on perhaps that is why you can't sign off. Just some thought to hopefully point you in the right direction.
Dec 13, 2007 | Intuit QuickBooks: Pro 2005 for PC
Coleman Cable Woods 59018 InWall 7Day Digital Timer White Logo
150 people viewed this question
Top Coleman Cable Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Coleman Cable Hardware and Accessory Expert? Answer questions, earn points and help others
