Question about Jenn-Air Cooktops
Two burners will not ignite. - Jenn-Air Cooktops
  • 244 Answers
The gas openings might be clogged. Boilovers can cause this. With the gas OFF, use a wooden toothpick to reach into each hole and loosen the cooked on matter. Once you have these openings clear, the gas should come on and will burn off the residue.
Posted on Nov 11, 2010
All pilots ignite when 1 gas knob is used on one burner
All igniters will spark when you turn on any burner but only the one you have turned on will allow gas through to ignite.
May 04, 2014 | GE Kitchen Ranges
Have trouble starting gas burners on nobel fse90-1. Is there a trick to starting the burners. I need serious help before I go mad!
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | Cooktops
All 4 electrodes spark when only one is turned on
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
On our 6 burner gas coocktop, the right two burners don't light
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
Trouble with front burners: Right burner sparks but does not light Left burner does not apper to spark, but lights If you turn on both bruners they some times light???
The igniters for the burners are all on one circuit so when you turn the burner to light the switch inside the burner valve will cause all burner igniters to come on. As far as the left burner not sparking it could be due to a bad igniter switch in the valve and when you turn on the right burner you are causing all(including the left one) to spark. You will need to make sure that the burner eyes are clear and not plugged. You can use a sewing needle to clear out the eyes. The small eyes at the igniter electrodes are very important because if they are clogged the burner will not light.
Jan 15, 2010 | GE 30 in. JGP328 Gas Cooktop
Viking cooktop gas unit ignition clicks on all burners when I use
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
I have a JGP636 or 960. One burner won't do
When you turn the burner knob on does the igniter click and turn off on it's own when the flame ignites? If it does then it has flame rectification. That means it can sense when the flame is on. Or does it click when the knob is in the light position and not stop until you move the burner knob? Then this is standard ignition. If it is standard ignition it sounds like it is the igniter switch built into the burner knob might be defective. Are you able to turn on any burner knob and when they are in the igniter position do all the electrodes spark or just the burner that you are turning on? If they all come on then they are wired in a series. If they are wired in a series do you get a spark at the electrode of the problem igniter? If so you can turn on one of the other burners to ignition position then while it is clicking turn on the problem burner to light it. If the cooktop uses flame rectification then there may be a problem with the switch built into the burner knob or the flame rectification sensor for that burner might be bad.
Sep 29, 2009 | GE Profile JGP636 Gas Cooktop
Cooktops Logo
73 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
