Question about Dryers
I have a Kitchenaid Prestige dryer. model number KEYS677EQO. The lint screen won't slid in more than about 1/3 of the way. It gets caught on the left side. Any suggestions?
  • Wendy Redfern Nov 08, 2010
    Thank you, I will get a brush and try that. I will let you know.
  • Wendy Redfern Nov 10, 2010
    I haven't bought the lint brush yet. My husband tried to clean it out with a thin metal ruler. He doesn't think it is lint because there is a metallic feel to the stoping. It is hard and has no rebound as if it was fiber.
    Thanks
  • 10,319 Answers
A loose screw inside will need to be tighten down so the screen will go fully in. remove the hold down screws from the top of the screens insert housing and take a flashlight to see were that screw is. some can be tigthen down without tearing the outer dryers panels apart
Posted on Nov 18, 2010
    President:
  • 2,468 Answers
You need to remove the rear cover and on the left side where the black colored ductwork is there will be a small hose connected to the right side of this duct work and connected to a plastic box,sometimes the hose gets too far into this duct and hinders your putting the lint filter back in,its secured by a "C" clip,if this comes off or breaks the hose may get too far in the ductwork,if this isn't your problem,then try lifting and slightly twisting the lint filter as there may be a small ledge to get over inside the ductwork also...good luck and thank you.....daniel
Posted on Nov 10, 2010
    President:
  • 1,891 Answers
Very common problem . whirlpool /kenmore /kitchen aid / and some models of maytag . the lint from screen rolls up and gets stuck in the screen grove. whirl pool has a very good lint brush that will keep it clean Pt # 8212614 . this will clean the area and solve the problem. bursh is a long and easy too use type . i would bursh it during the run with air so lint will be blowen out .. mm hope this helps . .. feed back please. mm
Posted on Nov 08, 2010
  • dennis dodge Nov 11, 2010
    i re ck ed the dryer by model # and if you cannot get the filter too slide down all the way then something is preventing it . a thin ruller was a good thing to use . but something is in the grove's . lint when fabric softner is used can cause a gum and the heat can cause it to turn hard with . time . the lint shute mah have to come out too be cleaned . . but if groves are not clean then screen will not go down. / i have found screws / lint balls / clothing stays both metal and plastic / buttons / cloth? ect in the shute . hope this helps mm keep on trying .
Clothes get caught
Instructions
Remove the lint screen from the GE electric clothes dryer.
Roll the lint from the screen with your hand. If the lint screen is clogged with fabric softener, fill a sink with hot water and add 1 to 2 tsp. dish soap.
Scrub the lint screen with a soft-bristle brush and soapy water. Rinse the lint screen thoroughly and shake off any excess water. Set the lint screen aside to air dry while you clean the dryer exterior.
Dampen a cloth with warm water and wring it out. Wipe over the GE electric dryer exterior to remove any lint, dust or product residue. If the dryer is very dirty, dip the cloth in the soapy water and wipe away any spots.
5
Wipe the GE clothes dryer with a towel to dry. Replace the lint screen when it's completely dry.
Jan 09, 2013 | GE DCVH515EFWW Electric Dryer
Call the Maytag man because I dropped a toothbrush down dryer lint vent?
You can do this yourself.
What is the complete model number of your unit?
Dec 03, 2012 | Maytag Dryers
How do i open a kitchenaid dryer to inspect drum assembly. its squeaking bad
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
If the dryer is a DUET or HE2 or HE3 style, (dryers that match the front loader) then the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed
Jun 04, 2012 | KitchenAid Dryers
Getting to drum in kitchenaid dryer
My kitchenaid dryer will heat up but wont spin around
May 27, 2012 | KitchenAid KEYS750LQ Electric Dryer
How do I access drive motor on kitchenaid dryer mod.keys700jqo
Mar 04, 2012 | KitchenAid Dryers
Repair a kitchenaid dryer keys700gqo
Feb 12, 2012 | KitchenAid KEYS700LQ Electric Dryer
Dryer won't spin
Oct 22, 2011 | KitchenAid Dryers
I need a part number for the lint screen fora 9200l series dryer i lost the manual please help
Hello there:
Whirlpool recommends
8557884 Whirlpool Kenmore Lint Filter (screen)
This Genuine Whirlpool dryer lint filter is used on Whirlpool, Kenmore, KitchenAid and Roper dryers.
Special Note ***** Does your filter have a black spacer below the handle?.
************ If so you may need the Whirlpool Dryer Filter 8557857
The 8557884 Whirlpool Kenmore Lint Filter (lint catcher) is about 17 and 1/2 inches long and has a white handle
Hope this is helpful for you
best regards Michael
Nov 30, 2009 | Whirlpool GEW9200L Electric Dryer
Model 87577800 sock went thru the lint vent
The model number you have listed has the dryer vent on top of the dryer. Small items commonly fall down into the vent chute on these dryers. Articles can easily be retrieved by following these steps:
1. UNPLUG the dryer. Dangerous voltage is still present inside a dryer even when it is turned off.
2. Remove the lint screen and remove the two screws that connect the vent chute to the top panel.
3. Turn the dryer around so you can access the rear, and remove the exhaust vent hose.
4. Locate and loosen all the screws from the perimeter of the dryer back panel.
5. Remove the back panel of the dryer.
The air blower assembly and dryer vent chute are located on the left hand side (as viewed from the rear of the dryer). Remove the screws that hold the vent chute in place and you will be able to access anything that has fallen into it.
NOTE: Anything left in the vent can eventually get caught in the blower fan. So, it is important to retrieve anything caught in this area to prevent damage to the fan and to ensure the dryer ventilates properly.
If you have any questions about these procedures, please let me know. I hope this helps you.
Oct 27, 2009 | Dryers
Dryers Logo
91 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
