Question about Brother IntelliFax-2480C Fax
How do I program my fax numbers? - Brother IntelliFax-2480C Fax
  • 240 Answers
You can program your fax number by going into the menu, go to initial setup and then station ID.
The station I{ will save your name and fax number (you do not need to put either one if you do not want to).
Thanks,
Pat
Posted on Nov 08, 2010
We have Panasonic TES 824. We connected 3-direct lines, one of them is for fax. However if I call the fax number, it goes to auto attendant. How to disconnect the fax number from auto attendant? Awaiting...
By programming. If the Auto Attendant is the DISA card, you can tell it to listen for the FAX tone and transfer it to the fax extension, or, you can program the 3rd number to ring only the fax extension and no others. Both require programming in the system cabinet.
Carl
Jan 18, 2011 | Panasonic KX-TA824PK Phone
I want to send a fax message using Brother 2820 fax machine, but I don't want the receiver to see my phone number when he receives the fax message print out. Is there any way I can do this?
The FAX machine will print the Tel number that has been programmed in your machine. It does not print on the basis of the caller ID received. So i think if you remove the number programmed in your fax machine
May 23, 2009 | Brother IntelliFax-2820 Laser Fax
Program one touch button to send fax to multiple numbers
Setting one touch numbers:
press function 72
set
press 1 for one touch numbers
press a position on the soft pad example 01
enter fax number with round buttons
set
enter name with soft pad letters
set
continue with more numbers or press stop to end.
For GROUP DIALING
Setting Group Dial:
press function 73
set
choose group dial
set
press program 1
set
name the program such as field offices.
set
press the one touch numbers you entered in the first step for this group,,,,01,02,05,08,17 etc
press set
press stop
load document in feeder, press Program 1 key, START
Jan 23, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
Need to change fax number programmed in Ricoh, afico 3025
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
Jan 13, 2009 | Ricoh Aficio 180 Laser Printer
Programming fax recipients
Go to quick dial programming in the manual. Lawrence
Jan 02, 2009 | Brother IntelliFax-2820 Laser Fax
I need to send a mass fax once a week
you need to program the numbers you want to fax in the speed dials and abbr numbers, then you can use a program key to select them all.
function-7-2-start [this is where you program your numbers]
function-7-3-start-1-start- then push your p key enter a name then hit start then select your phone numbers
Nov 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
How do I program in a fax number?
Register Fax dstinations:
  • Press User tools/counter button
  • Select System settings using the up and down arrows then press Ok
  • Select Key Operator Tools using arrows then press Ok
  • Select Address book Management using arrows then press Ok
  • Select Program/change using arrows then press Ok
  • Enter the registration number or Quick dial key, then OK
  • Enter user (destination) name using Quick dial keys - OK
  • Press Dest.
  • Press Fax settings using arrows then OK
  • Enter the fax number then press OK
The "Programmed" message appears, and then the "Address book" display returns.
Press the User Tools/Counter button.
Good luck and please rate me, thanks.
Sep 08, 2008 | Gestetner DSm618 All-In-One Printer
How to delete a pre-programmed fax number
If all else has failed and you cannot change the settings or change the numbers in the program itself, often uninstalling and reinstalling the fax can correct the problem
Aug 15, 2007 | Gestetner DSm735sp Printer
Fax Numbers-Memory?
Unfortunately that is a function of the sending unit. If they did not program their number in, then you won't have a record. If this is a persistent problem, you may want to sign up for Caller ID. Even if they put the paper in upside down, your fax will still print a head on top of the page with the information they have programmed. If they program a wrong fax number, then all you will have is a wrong number. Wish I have better new for you. Ed
Jun 13, 2007 | Muratec M1250 Fax
Brother IntelliFax-2480C Fax Logo
75 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
