Question about LG LS-K2430HL Heat Cool Mini Split Air Conditioner
Everytime turn the cooling or heating the power cut itself off what is it it's to do with the compresser please let us know and who to call to fix it we are in sunbury victoria. han our ph: 0403036559.
    Problem Solver:
  • 12 Answers
Call the authorised service center for further checking,first check the voltage with the help of electrician
Posted on Nov 09, 2010
How can I fix
Hello, try to clean and dry the electronic board, sometimes the humidity make shortcircuits between logic gates.
Oct 24, 2014 | Senville 18000 BTU Ductless Air...
L have got ford telster v6 ,everytime the engine starts to heat theres a hold light reflect on the dashboard and it cut itself everytime l get to th stop sign what may b the cause
it is a safety fixture for people like you, who do not respect gauges, if the lite come on is for a reason, too hot or nor oil pressure, well do that in some engine, obviously you did not respect the signs. that this make sense to you !!
Apr 14, 2014 | Cars & Trucks
My computer keeps restarting itself everytime i play games? How can i fix this?
It seems your power supply can't supply your computer power as needed so you need to replace your power supply. Use 500 watts pure power supply to avoid this problem.
Jun 23, 2017 | ASUS Essentio Computers & Internet
MY SAMSUNG P35 LAPTOP STOP ITSELF ON BATERY AND AC POWER
This maybe heat problem.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 27, 2012 | Samsung P35 HZM (NP35TP0FL2/SUK) PC...
Got a stihl cuts off after abour 45 minuts or whn it get really hot. it will not start unitl cool, what is the problem
Check for spark when the saw quits--the ignition module may be failing with heat. Try blowing the motor case clear of sawdust accumulation with compressed air to help control heat. Make sure the chain is properly adjusted, sharpened, and is being oiled sufficiently. Does the engine 4-stroke when not cutting? You may need to turn the H jet needle CCW a small amount so that the engine 4-strokes at speed, but immediately 2-strokes when cutting. This will produce the most power and least heat. Hope some of this helps!
Jan 05, 2011 | Garden
Je veux le formater parcequ'il s'éteint et se ralume parfois.svp aidez-moi à le formater manuellement.merci
> I want to format it because it goes out and sometimes ralume.
> please help me to format it manually. thank you
It could be over-heating, and turning itself off, to prevent damage.
Take a bottle of compressed air, and blow air through the power-supply, and through the cooling-fan on top of the CPU.
Oct 23, 2010 | Computers & Internet
My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
May 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Computer automatically powers down with out warning
It could be overheating, and shutting itself down, to avoid heat-related damage.
Turn the computer off.
Disconnect the AC adapter.
Remove the battery.
Purchase a can of compressed air, and give your computer a "blow-job" -- shooting compressed air everywhere "inside" your laptop, to remove dust.
The dust is acting as an insulator, preventing your computer's fans from cooling itself.
Or, take your laptop to a qualified computer technician, for more trouble-shooting.
Jan 24, 2010 | Gateway M-1628 Notebook
TV CUTTING OFF
Check this, for how long the TV is on? 30 min., 45min, 1 hour? because maybe you have accidentally programmed the SLEEP control. If so, go to the set up options or menu with the remote control and check the status of the sleep power off time. Or maybe the TV has the otion to power off automaticly set the same way that is the alarm turn on.
Jul 12, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
LG LS-K2430HL Heat Cool Mini Split Air Conditioner Logo
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
