Question about Frigidaire GLTF2940ES Front Load Washer
Door lock how do you check for loose wires on the door lock? back of machine? how do you get into the back of the machine? walt
  • wagelb Jun 16, 2008
    I unplugged the washer. openned the door. pressed the option and sellect buttons simultaneously plugged it back in pressed the options and select buttons and voila it started fine. thanks. walt
Hi Walt, if I recall correctly there were a couple of screws behind the soap compartment that allowed me to take the control panel off. 2 more screws in top back and the top of the washer can be slid forward and removed. Access to switch was through the top. Hope this helps.
JIM
Posted on Jun 16, 2008
Re: Maytag Neptune Washer. Loaded 2 jackets (whites requiring bleach), added usual Gain detergent (granules), plus small amt. of bleach in dispenser, then started cycle. Then poured bleach into machine...
DO = Door Open
Door monitor switch in door lock mechanism is not able to communicate to the control board is open.
1.Make door is closed.2.Check for loose wire connections at switch and/ or machine control board.
3.Check for failed door monitor switch.
4.Check inputs and outputs at machine control board.
FL = Failed To Look
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
Dec 31, 2010 | Maytag Neptune Washer
Door locked model he 2t
F22 error code means that the door lock mechanism is not functioning and the wiring has probably come loose. Open the top (2 screws in back) and you'll probably find (as we have now 3 times) that the wires and door lock mechanism have come loose (no wonder with the vibrations of the spinning drum!). Plug it back in yourself and save the annoying repair bill! Make sure to unplug the washer before you attempt it...
Jun 05, 2010 | Kenmore Washing Machines
Door is locked dl error code
Plug off the mains, remove bottom panel. Reach upwards to lock area to find a chord, pull downwards gently, door opens. Check the lock for loose wire, check small push button in lock area to make sure it is not broken, check latch on door.
May 10, 2010 | Kenmore Elite 45986 Front Load Washer
Wont't start dl f on display
HI. this is a Door lock error. Check the following to address this issue. Normally you will need to replace the door lock assembly in this case but, it is not uncommon for it to be just a simple loose wire harness as well.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Machine just stops. A little shake gets it going again for a brief time then it stops again. Neptune model MAH6700AWW
You probably have a loose connection. My guess would be the door switch, since that's probably where I'd bump it to get it going again. The fix is easy: gain access to the back side of the switch, and make sure that the wires are making good connection. Also, check that the latch and lock don't have anything loose, may be it's something that you ccan tighten without going into the machine to wiggle wires. Check for the loose fittings first, tighten up what you can with the door open.
Best regards, --W/D--
Aug 09, 2009 | Maytag Washing Machines
An error signal "DL" - door lock signal keeps coming on
Check for loose wires from the door lock to the control board.If no loose wires,
Replace the door lock switch.
May 23, 2009 | LG WM2277H Front Load Washer
Front loader washing machine door wont lock to begin cycle?
you might have a defective door switch. this is the part that locks the door and sends a signal to the processor to say that the door is already closed.
check also the wires that goes to this door switch. it could just be loose connection.
tnx 4 using fixya,
drcool
Sep 20, 2008 | Washing Machines
Door lock light
I just had the same problem. The door lock wires have clips so unless you uncliped them that would not be the problem. It should be listed in the reset error code section, but I would suggest performing the system error check first before clearing the error.
Step 1 go to http://www.frigidare.com
Step 2 click on CUSTOMER SERVICE on top of page
Step 3 go to PRODUCT MANUALS and click on DOWNLOADS
Step 4 type in MODEL NUMBER and click on search
Step 5 your error code information is in the TECH DATA file there you can perform a full system check PLEASE READ ALL WARNINGS POSTED
Step 6 save all PDF files to a new folder name it FRIGIDARE for easy availbility.
Thank you and good luck.
Jun 15, 2008 | Frigidaire GLTF2940ES Front Load Washer
Front load washer doesn't turn itself on when door closed and cycle picked
First check the door if it is still properly aligned try to tightened first the two screw of the door sometimes it is loose align it, reset your machine, if it is still the same, now take a look on the rubber gasket attached to the shell cabinet, there is a big plastic clamp or a rounded wire with spring on the other end it is the gasket lock, pull it u can return it by reinserting it back, wire lock-just stretch it and put it back,after doing that-pull the gasket slowly,to your right the door lock is located, check if it is misaligned-difinitely no problem with your door lock it is a matter of alignment - happy washing
Apr 06, 2008 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
78 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
