Question about Amana Refrigerators
I have an Amana Side-by-side model #SQD26V approximately 10 or 11 years old and I am the originalowner. The ice maker has quit. Water will no longer refill the ice cube tray. Yes, the arm is down and the water dispenser side works fine. Any assistance and/orpart that might need replacement would be great! Dave
IF IT HAS A WATER FILTER IN THE TOP RIGHT CORNER OF THE REFRIGERATOR, THE FILTER MAY NEED REPLACED
Posted on Nov 08, 2010
Looking for wiring diagram for amana bottom freezer model # BG20T2L MFG# p1316303wL serial # 9807110676 THE ICE MAKER QUIT MAKING ICE
First thing to check is the fill tube and make sure it is not frozen with ice.some ice makers can be manually advanced in order to refill with water some have a reset button to do this if these two things do no good and the fill tube is not blocked with ice then repalce the water fill valve on the bottom rear of the unit
Jul 10, 2010 | Amana SXD524VW Side by Side Refrigerator
My Aman side by side quit dispensing water. It
Does your fridge have a small tank inside the food compartment? If so, the water may have frozen in the tank and the problem can be solved if you take a blow dryer and warm the tank. That's what happened to mine and with a temp adjustment to keep the food compartment a bit warmer, the water doesn't freeze.
May 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
My refrigerator is six years old and for the past two months is making a loud buzzing noise. The frequency has increased over time. What could it be? It's an Amana side by side model ASD2626HE. Sounds like...
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Apr 12, 2010 | Amana ASD2626HE Side by Side Refrigerator
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Have Amana side-by-side about 14 yrs old. The icemaker overfills ice tray by about 8oz of water? Please help!
Unless someone has made a water level adjustment there is,
Only one repair. Replace the ice maker.
If someone has made a water level adjustment you can try this.
Remove the ice maker plastic cover. Locate the water level screw adjust it to a minimum setting and try it there.
If that does not correct the problem, replace the ice maker.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
ghhjd
Jan 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker not making ice
HAVE YOU CHECKED THE INLET WATER FILL TUBE ? IT COULD BE FROZEN UP AND THEN NO FILL ACTION. TAKE A HAIR DRIER AND TRY TO THAW IT OUT. GOOD LUCK,
Jan 02, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
235 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
