Question about ASUS K52JRA1 Notebook
Where is the wireless adapter switch? - ASUS K52JRA1 Notebook
A physical wifi adapter is not installed asus
goto device manager and look in the network adapters
whats listed there - do you see a wireless adapter
did themachine come with wireless
is the wireless switched on - acer have a switch to turn wireless on/off
Jul 09, 2014 | ASUS Computers & Internet
Network adapter hp6505f
If your computer has a wireless network adapter, Windows will automatically detect wireless networks in range of your computer. You can see a list of wireless networks that Windows has detected in Connect to a Network.
  • Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
If Windows doesn't detect a network that you think is in range of your computer, it could be because of one of the following reasons:
  • The wireless switch on your computer is turned off.
    Many laptops have a wireless switch on the front or side of the computer. If your computer has a switch, make sure it's turned on. Some computers also use a function key combination to turn the switch on or off. Check the information that came with your computer for details on locating the wireless switch.
  • Your computer is too far from the wireless router or access point.
    Move your computer closer to the router or access point. If the computer is portable, try moving it around to determine the range of the wireless signal and the best place to use the computer.
    If you can't get closer to the router or access point, consider buying and installing an external antenna for your wireless network adapter. Many wireless network adapters are set up so that you can attach an external antenna to them, which provides better reception than a built-in antenna. Check the information that came with your wireless network adapter to see if you can install an additional antenna.
  • The wireless router or access point is turned off or isn't working properly.
    There are two things to try:
    • Make sure the router or access point is turned on and that the wireless signal light is illuminated.
    • Reset the router or access point by unplugging it, waiting at least 10 seconds, and then plugging it back in.
Sep 10, 2012 | NEC Computers & Internet
Cannot access internet wirelessly,Have tried several routers but cannot connect wirelessly, talktalk suggest that there is a problem with my wireless adapter
I faced the same issue and had to change 3 different routers of 3 other brands first of all switch off your router for 10 minutes and then change your ethernet cable (BLUE COLOR CABLE) with a new one also try changing the sides REMEMBER its a cable that connects from your MODEM to your WIRELESS ADAPTER !! and then switch on your ADAPTER (WIRELESS ROUTER) and wait for 10 last minutes :)
hope i FIXED your problem :)
Mar 22, 2011 | HP Computers & Internet
Bought a Cisco wireless rotor. Downloaded fine to
usually laptop computer has wirelss adapter switch. look at the side of the laptop or infront of the laptop. its a small switch that you can slide back and forth. or you may press Fn+F5 or F6 to enable the wireless adaptor (this depends on the brand of the laptop) just look for the F keys that has a computer and wireless signal on it. have a good day!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 04, 2010 | Levelone CP TECHNOLOGIES LEVELONE...
My software says it doesnt detect the adapter how do i fix this?
first power on your wireless switch then insert software cd of your wireless adapter. then restart your system. okay
if it doest not work then go to device manager and under network adapter update your driver software for your adapter via internet. okay
Dec 02, 2009 | Belkin (F5D7050) (F5D7050VSNPDQ) Wireless...
My xbox 360 wireless adapter stays red and wont turn to green, my router and modem seem to be working
Switch them off and then on in the following order:
modem, router, computer. Make sure adapter is switched on!
Nov 26, 2009 | Microsoft Wireless Network Adapter Xbox...
Wireless adpter not working
ARE you using the adapter utility to conncet to the wireless network.
If you are using the adapter utility then try to switch over the windows utility ( for WIn XP and Vista only)
If you are not able to see the network with the windows utility also then try to uninstall and reinstall the adapter.
Click Here for more info
Oct 13, 2009 | Toshiba (PA3212U) Wireless Adapter
Acer aspire one wireless adapter not loaded the popup says
If you're using the built-in wireless adapter, make sure that the wireless is enabled. If there is a wireless toggle switch, make sure it is ON. You will know if it is ON is the wireless LED is blinking or if it is ON.
Jul 06, 2009 | Acer (D10709-002) (D10709002) 802.11g/b...
Wireless switch cannot turn on the intel 2200 agb wireless adapter for my laptop
*Assuming that the computer is a windows XP Operated.
Click on start => run => Services = Ok.
On the services window => check the status of the wireless zero Configuration => try switching it 'on' or switch it off and then switch it 'on'. If that does not resolve the issue then it could be hardware failure.
Dec 14, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
ASUS K52JRA1 Notebook Logo
97 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
