Question about Hoover U5194-900 Mach5 Multi-Chamber Cyclonic Vacuum Cleaner Bagless Vacuum
My Hoover Mach 5 model number u5194-900 series ZF12.O will vacuum for about 15-10 min then it shuts its self off and will not turn back on., I have cleaned out all the hoses, filters and cleaned off brush. What can I do to fix this so that it will **** into the chamber. The hoses get clogged and it doesn't appear to be sucking into the "bag area"
  • 619 Answers
SOURCE: Brushes do not spin on my steam vac
Hi , check the belt
Posted on Jan 21, 2008
reddevil6
  • 1673 Answers
SOURCE: Hoover doesn't suck well
Did you check the inlet from the bottom? Take the bottom plate off, make sure that the tube(inlet)is free of any clogs. Also if the belt is stretched, then it won't drive the brush roll like it should, replace it part #38528033.
Posted on Feb 05, 2008
reddevil6
  • 1673 Answers
SOURCE: hoover mach 5 only used 3 times
If the filters are ok, and there is no clog in the hose or dirt inlet down by the brushroll, then the motor protector is probably bad.
Posted on Mar 30, 2008
  • 37 Answers
SOURCE: hoover turbine replacement
first you must remove the dirty water tank then the nozzle window on top of the machine. (this is the clear piece that the dirty water is sucked through.) then remove all 8 screws from the bottom along with the 1 screw on the main housing. after all this the top housing will be snapped into the base at two spots in the rear of the upper housing. when these are loose the housing should be out. you will find the turbine in the front along with 2 more screws and 2 hoses that also must come off. attach new part and reassemble.
good luck!!!
Posted on Sep 24, 2008
SOURCE: The brush rollers on my
I had the same problem. The problem is the small v-belt for the roller brush (Hoover part# 38528034). Although it looks in good shape, it's been stretched too large for the idler to keep good tension. The tension on that belt varies with the handle geometry so if you slam handle all the way down the belt gets stretched a little bit each time.
Posted on Oct 18, 2008
Hoover bagged wind tunnel 2 vacuum turns its self off after about 10 min. of normal vacuuming I can press the power button right away and the vacuum will turn back on and vacuum for sometime as long as 5...
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Oct 06, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
It is a Hoover mach 5 runs a few minutes then shuts off no power laglass@sbcglobal.net
This sounds like a thermal limiter issue, usually caused by restricted air flow. Investigate until you find a blockage.
Dec 12, 2010 | Hoover U8145-900 Savvy Bagless Upright...
Hoover Mach 5 turns off after 5 minutes of using. Can you advise the problem?
5 minutes everytime? If so, raise brush all the way, and vacuum next to nothing. in fact, tilt vac up so the brush touches nothing. wait 5 minutes. If it doesn't shut off, your brush is set too high. if it does, the motor is over heating. make sure bag is empty, no debris in brush, filters clean and make sure you're not plugged into an outlet that a breaker on the outlet can pop too.
Sep 28, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
My mach 5 vhoover vacuum cleaner shuts itself off alsomst as though it is overheated
No your motor is going bad. Have you ever owned an electric fan. If you can remember when the motor started going bad on it the fan would quit turning on its own.Your vacuum is doing the same thing. Please call Hoover and order a new one or go to ebay type in the make and model..
Aug 27, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
While vacuuming with my hoover mach 5 it all the sudden shut down
Hi, If it is warm to the touch, and it just shut down all of a sudden, I would say that the motor has an internal over load switch that is normally closed, and opened to stop from burning this vac out. It is a built-in safety. I would look at the roller for anything that may have hung up, but steady use for an hour just over heated the motor. Let it cool way down. Try and start it. Also, check the plug to see if you may have lost power there also. Let me know please so I can be of any help you may need.
Sincerely,
Shastalaker7
Nov 08, 2009 | Vacuums
Mach 6 shuts off
If the vac shuts off and then turns back on after waiting a while. could be a thermal fuse. it is in the motor compartment. recommend a pro shop service this issue.
Sep 27, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
My hoover mach 5 stopped during use and will now not turn on
If the machine overheats, a breaker trips. Most breakers reset themselves after they cool off. You may have a manual reset button to push on your model. The machine will overheat if the bag is too full, or if the exhaust port is clogged. The reset switch is usually on the back of the motor housing, near the footswitch.
Dec 22, 2008 | Hoover Commercial C1660-900 Bagless...
Hoover mach 5 only used 3 times
Mar 13, 2008 | Hoover Commercial C1660-900 Bagless...
Mach 5 hoover turns off
Just got a solution off another website. There is a pre motor filter about the dust collection container. I opened mine and it was very dirty. I washed the filter and you are supposed to let it dry out for 24 hours. Hopefully this will work. Another guy said it worked for him.
Dec 29, 2007 | Vacuums
U5180-910 vacuum shuts off on own
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Nov 18, 2007 | Hoover U5180-900 Vacuum
Hoover U5194-900 Mach5 Multi-Chamber Cyclonic Vacuum Cleaner Bagless Vacuum Logo
69 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
