Question about Kenmore Elite 45986 Front Load Washer
F 21 code keeps coming up - Kenmore Elite 45986 Front Load Washer
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
This is a general remedy for most Whirlpool made front-load machines, such as Whirlpool, Kenmore, Maytag, Amana etc. Keep in mind some Kenmore are made by LG, Samsung, Frigidaire among others.
The "Sd" or "F2" is the same as F21 on most Whirlpool washer's and indicates the machine has detected too much soap or a obstruction in the drain process.
Chances are the pump itself is being obstructed by debris or some other foreign object as opposed to being faulty, although the faulty pump can`t be ruled out...yet.
**This is also the reason for the "suds" message if applicable**
Here`s how to check it and clean it...
Though it being full of water may make it messy. A wet-dry shop vac is handy in this situation.
If it is in a position that allows you too lean it back against something strong or a second set of hands it will help if tilted back almost all the way.
Careful not to hurt the machine or yourself, and undo the fill hoses and drain hose.
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removable filter. ( **see image below...this is were a wet-dry shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet )
3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now.
( If the problem still exist`s the Sd or "F2" or "F21" will re-appear. If so you`ll need to check the hose/rubber bellows from pump to tub...back-flow ball...for other obstructions ).
5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a couple hundred bucks !
Now You should be good to go. Re-attach the lower panel and you`re back in business.
**NOTE: if this still fails to remedy the Sd, F2, F21 or if it returns immediately during the next drain you may require a pump unfortunately...part # 280187 available at "searspartsdirect.com" "repairclinic.com" etc.
**This however can also be caused by the back-flow ball inside the bellows which connects the tub to the pump. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.**
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Macmarkus :)
Posted on Nov 08, 2010
Error code F-21
F21 relates to a motor or control board fault.
Sep 27, 2016 | Kenmore Elite 45986 Front Load Washer
My Bluetooth keeps coming on at volume 21 I have to turn it down to 5 every time I get a call then it goes back to volume 21 how can I keep the volume at the same as number 5 seems to be the best volu
It seems you have a DEFAULT position and with that said, your device will always reset to the 21 volume setting. Contact the manufactures customer service personnel to go through the process of re-adjusting the controls.
Dec 01, 2014 | Car Audio & Video
2007 ford f-350 super duty with a 5.7 l v8 codes p2198 PCM keep coming up
Why wouldn't it keep coming up
-------Your doing nothing-------
Not reading your owners manual
Not studying OBD Vehicle Systems
Not Googling your fault codes-you got the codes but do nothing
P2198 --Lack of HO2S-21 Switch -Sensor Indicates Lean
If you did the required Preventative Maintenance & replaced
the Front Oxygen Sensor BEFORE they failed at 100,000 miles,
you may not be in the situation
Every time the Emissions Monitors run, the codes come back or never left
Need a repair shop, to road test with scan tool & put a couple hours
diagnostic time into the truck & about 6 or 8 hours getting caught up
on the maintenance required
Jul 22, 2014 | 2007 Ford F-350 Super Duty XLT
95 accord error code check engine code 21
This code is for a V-Tec valve control failure, which is why it doesn't come on until you hit 4200rpm. That's when the system activates. Check your connections at the V-tec solenoid/valve on the back of the head. You'll likely see it leaking quite a bit of oil leaking down the back of the engine from it. Don't bother messing with it, replace it. And don't use any kind of additives in your oil. (Slick 50, etc) These products notoriously clog the V-Tec valves. Good luck!
Apr 02, 2014 | 1995 Honda Accord
I have a carrier furnace the control board keeps coming up with differ t led coxes ifiI reset it it works a couple times then flashes a new code had four different codes come up so far 21 22 31 34
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 05, 2014 | Heating & Cooling
Trouble code 33 and 21 for mitsubishi pajero
those codes dont conform,refer your user manual for code reader
Feb 11, 2013 | Cars & Trucks
There has been a problem with your sound device (CODE:21)
Problem: Error (Code 21) is a known error that is caused by outdated or corrupt drivers. Failure to keep your drivers up to date could result with system malfunctions and device problems.
Solution: It is highly recommended that you update your drivers now to fix the problem.
Feb 23, 2011 | Computers & Internet
Regarding the kenmore he2 plus front loader washer.f-21 keeps coming on.actually worked for a couple loads today but f-21 started coming on again after i started washing a 3rd load of colored clothes.seems...
There is a strainer on the drain pump that is clogged. The manual does not mention this at all, it merely states the drain hose is kinked or clogged.
Under the front door there is a panel that is the width of the machine and is held in place by two screws, one on either side.
When you remove that you will see the pump and the the strainer attached to it. Unscrew the strainer (put a small pan under it to catch excess water) and remove to remove the junk accumulated.
Also, attached to the panel is another manual that refers to the error codes you are seeing.
Dec 20, 2009 | Kenmore HE2 Plus Front Load Washer
C:21:00 moisture code wont go away. dried it out. wont work.
keep it in a warm place for about a week. No battery, tape and every compartment or flap open  Also blow it with a fan for a day or two and try a hair dryer but, not very hot.
Apr 03, 2009 | Sony Handycam DCR-TRV250E Digital...
Kenmore Elite 45986 Front Load Washer Logo
154 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
