Question about Whirlpool Dishwashers
Dishwasher will not drain. It appears to us that the pump simply is not pushing the water out. We have disconnected the hoses and then the water drains, but there is nothing clogged up. The garbage disposal works fine. We can hear the pump when we push drain but nothing happens.
  • gcuenin Nov 08, 2010
    model number gu2800xtvb1
  • 10,865 Answers
Hello. I suspect that the dishwasher drain pump has a chunk of debris in it or that the hose is clogged or kinked. Do this. Get a #2 phillips head screwdriver and remove the lower front panel on the dishwasher. Once that panel is off you will see the drain hose attached to a small pump, usually in the left front of the lower space. Undo the hose clamp and then unscrew the pump from the frame so you can physically look inside to see what might be there.
Remove any debris you find. Next hook the hose up again to the pump and put the sink end of the hose into a 5 gallon bucket. Then run the dishwasher through a drain cycle and see if the pump is indeed moving any water. If it is not, replace the pump. One source for parts is Searspartsdirect.com.
Joe
4 thumbs up please.
Posted on Nov 08, 2010
  • Whirlpool Master
  • 3,247 Answers
Please provide the full model number of the dishwasher. There might be an air gap in your plumbing which is blocked. Some dishwashers use the air gap to tell it how much water is required to clean the dishes.
Water not pumping out
Hello there and welcome to fixya
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt
Apr 02, 2012 | KitchenAid Architect® Series II KUDT03ST...
My kitchenAid dishwasher won't drain well. the hoses are clear. solenoid seems to be opening and closing. What is my next step?
Hello there again I am really sorry we got disconnected
Please try this
The water doesn't drain from the machine
If the water doesn't drain from your dishwasher, check these: Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Jun 27, 2010 | KitchenAid Dishwashers
My dishwasher GE profile quiet power II MV832134B GSD 4030Z04WW will not drain.
Hello there again
I think we got disconnected in the chat room so i will post the solutions here for you to check ok
The water doesn't drain from the machine If the water doesn't drain from your dishwasher, check these: Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt If the motor isn't turning or working, the unit won't drain. at all." If the motor hums but doesn't turn, it may need to be replaced.
Jun 27, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Will not drain in drain cycle
If you can hear the pump attempting to pump the water out, disconnect the dishwasher drain hose and place a bucket underneath it and run the drain cycle again. This should clear any clogs along the drain line and prove that your pump works. While you've got it disconnected, remove the air gap vent and clean it. A small, but large enough amout of debris can be blocking the flow of water from the dishwasher's drain hose to the garbage disposal or drain pipe. The air vent has a small cap at the top that can be removed to make cleaning easier by simply flushing it with water.
Mar 20, 2010 | Bosch SHU9915UC Dishwasher
MY SON'S DISHWASHER WON't drain
Hello there:
Please try these things below my post and click on the links that are available for you ok
I hope that tthis is very helpful for you
best regards michael
Water will not drain from my dishwasher. Investigate these six areas if water will not drain from your dishwasher :
dishwasher_drain-hose.jpg Drain Hose
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
dishwasher_pump-repair-kit.jpg Pump Assembly
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
dishwasher_belt.jpg Belt
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
dishwasher_timer.jpg Timer
A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor.
dishwasher_motor.jpg Motor
The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor.
dishwasher_drain-solenoid.jpg Drain Valve and/or Solenoid
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them.
Nov 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Excess water left in the dishwasher, water not draining. I have checked all pipes and checked all filters which appear ok
  • Check sink drain and drain hose for restrictions . The drain hose can cause the dishwasher to fail to drain properly. The recirculation hose can be responsible for problems with poor rinsing of dishes.
  • To access the drain hose remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
    The drain hose connects to the pump and runs to the sink drain (or to the air gap on top of the sink). The pump has a second hose that recirculates the water back into the dishwasher. The drain hose is roughly 1 1/2 inches in diameter. While inspecting the drain hose, check the recirculation hose as well.
    If checking for leaks, feel the hoses where they connect to the pump, for wetness and check the ground right under the connections. If they are wet, it may be a loose or improperly mounted clamp, a damaged pump housing or a leak in the hose itself.
    If checking for blockages, disconnect the drain hose from the pump, pinch the wire clamp with pliers and slide it up the hose. Place a shallow pan beneath the pump to catch any spillage. Remove the hose from the pump; wiggling the hose may help to loosen it.
    Check the hose and nipple to the pump for any debris. The only way to be certain the drain hose is completely clear is to disconnect it from the sink and run water through (such as spraying a garden hose through it at full pressure). Disconnect the recirculation hose and check it in the same way.
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Aug 20, 2009 | Fisher and Paykel DS605I Built-in...
Frigadaire dishwasher
please rate my solution thanks
Jul 13, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Water won't drain out
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Jul 13, 2008 | Dishwashers
Will not drain
pull the check valve in line after pump this my be jamed if not the pump may need replacing
Feb 24, 2008 | GE 24 in. GSD5560GSS Built-In Dishwasher
Dishwashers Logo
43 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
