Question about Gateway Computers & Internet
How can i fix system configuration error - Gateway Computers & Internet
    Champion:
  • 214 Answers
Please try to put little more explnation
or try this
Click Start button, and select Run or press windows key + R
in the Run dialog box type 'msconfig' and press enter
In the System Configuration Utility dialog box, select Startup and uncheck the unwanted programs from the start up list.
Select the Srvices tab and you can change the configuration changes here. Be sure not to uncheck anything necessary for the windows to boot.
hope this may solve your problem
Rabby
Posted on Jun 16, 2008
  • Rabby V V
    Rabby V V Jun 16, 2008
    no comments at this point
0xc00000e9
Problem: 0xc00000e9 problems occur when the system is incorrectly configured or critical system files are missing. These problems happen when a PC is not maintained properly and should be fixed immediately to avoid further damage.
Solution: To repair 0xc00000e9 errors correctly, download and install a repair tool. Tools are created to find and fix errors on your computer and ensure your system is running flawlessly.
Navigate to Advanced System Care. It is a free programme and it works!
Oct 27, 2013 | MSI Computers & Internet
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
Hi! I need to fix a friend's computer, and the problem is that lot of errors appear when I am turning it on, and to be able to run the windows I need to press F1 tot go to Bios, than exit and save...
Simple tips to fix this issue:
  • Clean the Temporary Stuff and Browser Cache
  • Remove Obsolete Registry Entries
  • Disable Startup Programs & Services
  • Customize Windows for Best Performance
  • Uninstall Programs and Disable Windows Features
For Instant Fix use Reginout system utility.
Jan 17, 2013 | Computers & Internet
Error code 0x00000002
STOP 0x2 DEVICE_QUEUE_NOT_BUSY error code has a value that is 0x00000002. This is a fatal error typically known as STOP message or Blue Screen of Death (BSOD).
This error generally occurs in Windows XP but may also occur in latest version of Windows such as Windows Vista or windows 7. The computer may stop responding without warning. Moreover, your computer may give error messages like STOP 0x00000002 error or related errors and if blue screen appeared then you may have to restart the system in the mean time of your work due to which unsaved work will be lost.
Cause of Error:
  • You may be using corrupted profile in your system which raised this problem
  • The device driver of your system is not updated
  • Malfunction of hardware usually is the cause of error such as STOP 0x2 DEVICE_QUEUE_NOT_BUSY or similar error
  • Registry database of your system may have corrupted or modified erroneously by invalid application
  • You have installed new hardware unsystematic or installed unknown application
  • Spyware has infected the PC
  • Antivirus software is not working
  • The operating system or application might have run out of usable memory.
This is one of the serious problem in computer if it is not resolved instantly then it might create some more unexpected error. STOP 0x00000002 error and its related error will disturb you all the time and you may have to bear loss of data. When blue screen of death appear on your monitor screen then you need to restart directly whether you have saved your work or not. Therefore, you are suggested to fix STOP 0x00000002 error as earliest possible.
How to Fix:
To fix STOP 0x00000002 error you need to follow the following methods.
  • If this error occurs in your pc then you will have to restart the PC and then press F8 key before appearing Windows. You will see a black screen with white text giving many options. Select the option "Last Known Good Configuration" and press Enter. If you have configured the computer improperly then it may fix the error.
  • If you have installed any hardware in your system then the chances is more that the device driver is not updated and thus errors of type STOP are given at the time of operation. You must download latest drivers.
  • If your system does not become stable then you need to try scanning of registry with this tool. Since, registry keeps all configurations of your system if it gets impaired then you must download registry repairing softwareand repair it .
Mostly, spyware has been the reason of various errors in computer system. Spyware damages files in the computer system and if once damaged then it is no longer used and it also corrupt registry database. The file which is infected by virus may be a program file, system file etc. If STOP 0x00000002 error occur in spite of antivirus then download anti spyware to scan your computer.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 28, 2011 | Microsoft Computers & Internet
My ibm thnkpad was error 174,how can i solve it?
This is the IBM description of the error -
Normal 0
173
Bad CMOS/NVRAM checksum
174
Bad system configuration
175
Bad EEPROM CRC
Go to the BIOS configuration - the Date and Time may be wrong.
If this does not fix the problem try setting the BIOS bacj to the defaults.
If this does not fix the problem, the BIOS battery may be worn out and needs replacing.
Sep 22, 2010 | IBM ThinkPad 380ED
System configuration error (DRNFFFFFFCD) 5.50
You need to fix IDStorage... Google for Despertar del Cementrio 8 fixing idstorage
Sep 21, 2009 | Sony PlayStation Portable (PSP) Console
Error 174
This is what the error might be:
174(Configuration error:)
1. Check device configuration.
2. Hard disk drive assembly.
3. System board.
When you power it up, press F1 or alt(prn scr) and hold it until you see the BIOS screen. It should then show you the configuration information. Error devices usually have a white arrow beside them. If you have tested the system and replaced the hard drive - quite likely the problem is that the drive is simply not configured properly, try a different setting for the HD. Also when a CMOS battery gets weak, occasionally errors will post, try changing the CMOS battery, it is usually in the memory area and looks like a large watch battery. After replacing it you will have to redo the bios settings again. Occasionally also simply changing a setting and saving it and then changing it back and saving again will eliminate errors - this forces the bios to rewrite it's data and correct any corrupt entries.I don't recall exactly but there may also be an option in that type of bios to clear the error logs. Do that also if it has that setting.
Aug 30, 2009 | IBM ThinkPad X61s PC Notebook
System Partition Compaq ML370.
Is your new hard disk is of same company and config. Hard disk of another company may cause this problem
Apr 14, 2009 | HP Compaq ProLiant ML530 Server
Tally6215 "Config 1" Error
The 'Config 1" message on the T6215 is not indicating an error message, this message is simply indicating that Config 1 of the 10 configurations that you can set on the T6125 is loaded.
With the Config 1 message loaded you should still be able to print so long as the printer is ONLINE and does not have any other error lights on.
If the printer is not printing I would recommend printing a configuration page to check the printer is working OK.
To print a configuration page follow these steps;
Put the printer OFFLINE
Press the MENU BUTTON
Press the DOWN ARROW to HELP
Press ENTER
The printer should print a configuration page, if this prints correctly I would recommend checking the settings in particular the Interface and Emulation settings.
I would also recommend checking connectivity between the system and the printer to check the print jobs can get to the printer.
Also check the system to ensure the correct printer driver and printer setup is being chosen.
Mar 26, 2009 | Tally T6215 Matrix Printer
Configuration error after trying to restore system
Go into system restore under windows system tools and rest your restore point to one prior to restoring your computer to original factory condition. Then wait until you can determine which configuration error is the problem and then restore to original settings. Good Luck
Nov 08, 2008 | HP Compaq Presario SR2150NX PC Desktop
Computers & Internet Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
