Question about Dryers
What cubic size is a maytag de512 - Dryers
4 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: cubic foot size of Maytag PYE4500AYW
7.0 cubic ft.
Posted on Mar 28, 2010
hunter19_46m
  • 7482 Answers
SOURCE: maytag dryer model # de512,
Hi iprenorris...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Posted on May 21, 2011
oldTech2332
  • 2341 Answers
SOURCE: how to replace belt in
Hello
Watch this youtube video it will show you step by step how to replace the belt
http://youtu.be/6ufArteqWXk
Posted on Jul 23, 2011
Cubic feet for maytag model number washer sav571eeww
washing machines are rated in pounds of wash and not cubic ft
it is rated as either 4lb, 5lb, 5.5 lb 6 lb 7 lb 7.5lb
the size will be on the same decal as the model number and power details
Jan 22, 2016 | Maytag Washing Machines
What is the cubic size of my maytag neptune fav6800aww
if you go to www.searspartsdirect.com and enter your model #, you should be able to pull up the manual and it should tell you there.
Nov 27, 2015 | Maytag Washing Machines
How to replace belt in Maytag dryer DE512
Hello
Jul 23, 2011 | Dryers
What is size of this refrigerator
Total Volume 27.3 cu. ft. Fresh Food Volume 17.1 cu. ft. Freezer Volume 10.3 cu. ft. Dimensions Overall Width 35.75 in. Overall Height 70.25 in. Overall Depth 33.63 in.
Feb 21, 2011 | Maytag MSD2756G Side by Side Refrigerator
IHAVE MAYTAG NEPTUNE WASHER MODEL # MAH4000AWQ.I WANT TO KNOW WHAT IS THE SIZE IN CUBIC FEET?
If my calculations are right, this washing machine is approximately 3.00 cubic feet. You may want to double check it for yourself, though. I used http://www.ehow.com/how_6358141_calculate-cubic-feet-washer.html (updated 5/7/2010) to help in the calculation. My machine was approx 15"/1.25' deep and 21"/1.75' high. Hope this helps.
Aug 18, 2010 | Washing Machines
What is the cubic size of my maytag neptune MAH 1 washer
You can find the literature at this Maytag website if you have the correct model number.
Have a great day.
http://www.maytag.com/support/manuals_literature.jsp
Jul 05, 2009 | Maytag Neptune Washer
Maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Nov 20, 2008 | Maytag Neptune Washer
Dryers Logo
230 people viewed this question
Top Dryers Experts
