Question about Dynex Wireless-G USB 2.0 Network Adapter
I have a dynex enhanced wireless g network adapter. The computer that uses it is a windows xp. The computer will recognize it and it will show up but I can't connect it to any wireless networks. There is a network in range (my laptop connects) but I can't configure the adapter to use that network, the network won't even show up.
  • 240 Answers
Does the stick see any other wireless networks? Can you try creating an Ad-Hoc network from your other laptop to this one through the USB stick? If the answer to either of these two questions then the stick is working fine.
I would check to make sure your router is not using solely a N network type because the USB stick will not support it.
If you are using a duel band router and you are currently using the 5ghz network then the USB stick will not detect this either.
Lastly if your network is not being broadcast, your laptop may connect to the network but your USB stick will not be able to locate the network.
You can also try power cycling the router (unplug for 30 seconds) and then search for networks again.
Thanks,
Pat
Posted on Nov 08, 2010
I have a dynex wireless network adapter and i cant run it on windows 7 because drivers are for windows xp and vista when are new drivers coming out?
They probably won't create them...that is unless hordes of people request them.
Have you already tried using the Vista drivers? Lots of times they'll work in Windows 7.
Let me know what happens and we'll try to figure something out if that doesn't work.
--RescueTechLA
Nov 28, 2009 | Dynex Wireless-G USB 2.0 Network Adapter
Similar problem... Really annoying
The issue happens due to quantity of applications at the background. Reducing the quantity of startup applications might help. Just type MSCONFIG after clicking run, At startup tab uncheck the non-essential applications
If you need further assistance please post
Good Luck
Jun 30, 2009 | Dynex Enhanced Wireless-G USB 2.0 Network...
Win XP Pro freezes when trying to use the Dynex wireless G card
Dynex Wireless-G Desktop Adapter is making my Win XP freeze within seconds after logging in. I've tried uninstalling, installing about 5 times. I'm doing everything by the install directions, nothing seems to help. It's a Compaq Presario Desktop.
Any help would be appreciated
Mar 01, 2009 | Dynex 802.11g Wireless-G Desktop Card
Can't configure router so my adapter can access my network
Use the XP to config Router.
Your 98 and your router are on different SUBNET check it.
Connect XP computer to Router using lan cable
Be sure to be on same subnet
Configure your Router
SEt same subnet for every PC connected to router.
Then connect to router using Wlan.
Feb 04, 2009 | Dynex Enhanced-G Wireless Broadband Router
Possible reason why your computer is not getting online wirelessly is because the wireless settings on the router and the wireless settings on your computer do not match. Here are some troubleshooting steps that I suggest you try:
A. Checking the Wireless Settings of the Router
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on the Wireless Settings under Setup and take note of the SSID.
5. You may also change the wireless channel here. We suggest channels 1, 6 and 11.
6. At the bottom of the page, look for the Security Options. If in case that the security is set to WEP or WPA-PSK, we have to enter the same wireless security on all wireless PCs. To make sure of the key, we can try modifying the security. Please refer to the following:
For WEP: Select Key 1 and enter 10 hexadecimal digits (0-9 and A-F) on the empty box beside it. Then, click on Apply.
For WPA-PSK: Enter an alphanumeric key (minimum of 8 characters) on the Passphrase box and click on Apply.
Note: The Key and Passphrase are case-sensitive.
7. On the left pane, please scroll down and click on Wireless Settings under Advanced. Please make sure that the boxes for Enable Wireless Router Radio and Enable SSID Broadcast are checked.
8. Click on the Setup Access List button and uncheck the box Turn Access Control On.
9. Click the Apply button.
B. Connecting to the Wireless Network
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
For Windows Vista:
1. Click Start then select Connect To.
2. Connect to a network window will show up.
3. Select your wireless network and click Connect.
4. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
We hope that the above steps provided would help resolve the problem. If the steps above did not work, we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Can your computer go online when it is hardwired to the router?
2. What wireless adapter are you using?
3. What is the operating system of your computer?
Aug 06, 2008 | Dynex Enhanced Wireless-G USB 2.0 Network...
Software won't install
I would take the dynex back to the store.
I have dynex and a brand new netgear router.Netgear is awesome!
Wife has netgear and hers is working fine and she is running vista!
Im running dynex and nothing but problems so easy fix is replace with netgear.
Goodluck
kingelviss
Jul 16, 2008 | Dynex Enhanced Wireless-G USB 2.0 Network...
DYNEX Enhanced Wireless G Adapter USB freezes up WINXP
hello!
your may try the ff:
-- run antivirus and antispyware
-- try a diff usb port
-- uninstall and reinstall updated driver of your adapter
-- make sure your computer usb port is 2.0 or if the adapter is backward compatible with USB 1.0 or USB 1.1 compatible
May 05, 2008 | Dynex Enhanced Wireless-G USB 2.0 Network...
Dynex Wireless-G USB 2.0 Network Adapter Logo
295 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
