Question about Harman Multimedia AVR-254
My AVR-254 will not completely install the latest update. i have been having issues where the reciever would completely drop HDMI audio but i would still have video. if i tinkered with it a little i would get the audio back. today the audio and video completely went out. i tried doing a "reset" and then the whole receiver locked up, meaning i cant change any of the settings. it seems as if all of the buttons on the front of the receiver are inoperable. i can't even listen to FM radio because it is stuck on XM. so i tried to do the update as recommended by tech support and it updates everything except the video portion. it fails everytime. so, if you have any thoughts as to why all of this is happening i would appreciate it. thanks, josh
3 Suggested Answers
  • 3 Answers
SOURCE: Harmon AVR 254 No Video, No Sound.
Mine was replaced by HK under warranty with a brand new one with the latest firmware. I had to wait about 2 months though to get a new one as opposed to a refurbished one. You have to demand it. Otherwise you get the refurb. My new one hasn't exhibited any issues and everything seems to work better than before (PS3 menu "clicks" all seem to work now and I don't get the pink or green flashes between sources I used to get). So a replacement was the fix for mine..... :(
Posted on Sep 08, 2009
SOURCE: Harman/kardon avr 247 no audio or LED display on the reciever
I've had the exact problem. HK in the states is no help, you need to deal with a company in Montreal (Jan Industries). Regular techs are unable to fix it without schematics that only authorized dealers have and the manufacturer. This problem happened to me just after 2 years and outside warranty. I've bought a Yamaha today.
Posted on Apr 03, 2010
Monitor output signal
Email or call the manufacturer
http://www.harmankardon.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=AVR%20254
Aug 27, 2012 | Harmon Kardon Harman Kardon Avr 254 7.1...
Avr 254 the resolution button don't work
The resolution button only works for video being processed through the reciever.
If this is the case- if you are using a set top video decoder for digital TV, the real issue may be related to the set top box. They do have an issue with certain boxes when switching between modes.
If you do not have a manual, download one here, and also check some of the supplements/updates as well:
http://www.harmankardon.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=AVR 254
There is also a software upgrade available that you can download and connect your computer to the reciever and perform the upgrade following their instructions.
If the both the remote button and front panel do not work, you may not have the right TV or monitor code entered in. This can happen with universal remotes even. There may have been a firmware change made in the TV or monitor that would have resulted with a different entry code. If there is more than one code- try them all to find the one that does work correctly or do a code search.
Mar 28, 2012 | Harman Kardon Audio Players & Recorders
AVR 254 is not responding. None of its front panel buttons are working (except volume). Same thing with the remote. I noticed that in the front panel area, the speaker icons in the Speaker/Channel Input...
ok
The reason your receiver is causing you issues is cause of a 2 time Delay fuse's on the transformer board all you have to do is to by pass them.
Check the connector on the top front of the HDMI board. at the bottom of the connector it tells you the voltage of each wire the middle one is GND. should read 1.8v and 5.6v if the 5.6v line is dead. you key's in the front panel and sometimes video and audio as well.. will also stop working. all you have to do is to by pass them.
I will be posting a video later today on how to fix this issue. Regards,
Search for AVR 254/354 fix
Mar 16, 2010 | Harman Kardon AVR 325 Receiver
Getting picture lines across tv that keep scrolling down like old tv's used to do. HDMI connected to cable box. Cable box to tv works fine and dvd to receiver hdmi to tv works fine no picture problems. can...
You will need to run HDMI directly from TV to Cable Box. Then run an optical or digital coaxial from your cable box to your receiver. The version of HDMI in your receiver is 1.1 or 1.2 and will not pass signal correctly. The recording industry has placed many roadblocks in front of HDMI to keep us from recording.... Go figure... That's the fix though. Hope this helps
Dec 19, 2009 | Harman Multimedia AVR-254
AVR 254 with Xbox 360 - Same problem
I just recently had this problem for the second time, first time I had the unit replaced. This latest time I perfromed the firware upgrade and the issue was resolved. Follow this link http://www.harmankardon.com/EN-US/Products/Pages/ProductDetails.aspx?PID=AVR%20254
then select "Product Updates" you can download the firmware from there. Be sure to read the PDF and follow the on screen instructions exactly. This process will erase all your stting so you'll have to reconfigure all your sources and settings upon completion. Good Luck.
Sep 06, 2009 | Harman Multimedia AVR-254
ok
Mar 25, 2009 | Harman Multimedia AVR-254
My Harman Kardon AVR 254 is not responding. None
I am having the same problems with my AVR 254, did you find a solution?
Thanks
Mar 15, 2009 | Harman Kardon AVR 325 Receiver
HDMI on PC but not on Denon AVR 3805 -
For this situation you will have to take audio output from the TV to an input on the Denon
Jan 11, 2009 | Denon AVR-3805 Receiver
AVR 1508 Reciever Setup Issue
AVR 1508 doesn't upconvert. Only components coming in on HDMI will go out HDMI.
Nov 28, 2007 | Audio Players & Recorders
Harman Multimedia AVR-254 Logo
155 people viewed this question
Top Harman Multimedia Audio Players & Recorders Experts
Steve
berggei
Are you a Harman Multimedia Audio Player and Recorder Expert? Answer questions, earn points and help others
