Question about Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television
I have a panasonic pt-45lc12
We turn it on and the green on and off light just blinks on and off but the tv does not come on we hear the fan but no picture, we had moved it to another location when this started. the lamp looks good and is not too old. what do you think could cause this? how do I tell if the lamp has gone bad or could it be another problem.
  • drgnflie Jun 23, 2008
    we have the same problem....we turn it on and the green on and off light just blinks on and off but the tv does not come on we hear the fan but no picture,
  • wsheehan Jan 29, 2009
    where does the thermal fuse get installed?
We bought a $2.00 thermal fuse at the local Radioshack, installed it and my tv works just fine. We were told it was the lamp, the projector or the tuner. It was a $2.00 thermal fuse.
Posted on Nov 05, 2008
  • 3 Answers
We have this same problem and called a repair co. to fix, they said it was the tuner kit ($400) or
projection kit ($800). We haven't made the decision to fix because with labor cost we can buy a new
tv. We would like to find a place that sells the kits used and a manual so we can fix it ourselves.
Posted on Nov 01, 2008
  • tagliente_j Nov 30, 2008
    The thermal fuse worked for us also. Radioshack didn't have the right temp rating so we went to a place called Fistells, they didn't have a 115c, so we installed a 128c, it works.
    I want to thank you for this solution, it saved us allot of money.
    Sergeant:
  • 280 Answers
If you are not a tech you don't want to mess with the voltage that feeds the lamp. The vibration of moving the set can cause the lamp to go bad. blinking LED is usually a sign the lamp is bad. It is a good Idea to open the lamp door and then close it again to make sure the door switch isn't the problem
Posted on Jul 25, 2008
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
Pt-45lc12
It looks like a problem with a tube (projector light) I suspect the green one. Pay attention to flickering on the lights and post me the results.
Nov 01, 2007 | Panasonic PT-45LC12 45" Rear Projection...
I have a panasonic pt-56dlx75. the lamps are okay i had them checked but my tv will not turn on, no blinking red lights just a green blinking light in the power button. I can also still hear a fan working...
I am not familiar with your TV but the blinking light is generally the error code! You will need to count the blinks, that will tell you what is wrong with your TV! Wish I could help you more!
Jan 07, 2011 | Panasonic PT-56DLX75 56" HDTV
New Bulb... No Screen...
Ballast Board ,it is what turns Lamp on! Call Encompass Parts for Part or look them up online they have website. Call 1-800-638-3328 Ok I looked it up Part# is LSEB3062A1 which showed No Longer avaliable,So try UED 1-800-648-6657 and Look on E-Bay under Electronics For Ballast Board.
Nov 19, 2009 | Panasonic PT-45LC12 45" Rear Projection...
Lamp light out ?
Ck Fan behind Lamp first if it is OK then replace Lamp Look on E-Bay you can find lamps for as little as 82.00
Aug 06, 2009 | Panasonic PT-45LC12 45" Rear Projection...
Green flashing power light and ticking noise but wont turn on
Did you touch the Lamp? If you did it may have blown. the color wheel may be the problem or yes the balist
Jul 25, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Powerb button blinks and TV doesn't turn on
i think its time to replace your lamp if you have not done so.
you sould be able to get it from the front and also look at it most of the times you will see the broken glass pieces inside. only tool you will need its a philips screw driver.
Jul 03, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Panasonic PT-45LC12 just turned off?
having the same problem, after some research, came across this: http://www.fixya.com/support/t142873-panasonic_pt40lc12_blinking_green_power
Not a tech, so I'm going to look into it further on how hard this is to do.
Jun 27, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Pt456c12 wont come on blinks green at the on off light
Good Day, teagues;
It sounds like a bad lamp. Lamps normally have a 5,000-hour life. Looking at the lamp can tell you if it’s bad if it looks burnt, but not always. Your Panasonic TV is also known for having failure of the ballast, which turns the lamp on. 95% of the time it’s the lamp, trouble shooting the ballast is a little more challenging.
The lamp replacement is a very simple process; instructions are in the TV’s owner’s manual. Call the factory, they will send you the lamp to your home with complete detailed instructions.
Good Luck, Big Irish.
Jun 17, 2008 | Panasonic PT-45LC12 45" Rear Projection...
PT-45LC12 wont power up
You have a bad lamp. The "clicking" sound you hear is the ballast (lamp power supply) attempting to start the lamp. The warning on Panasonics that comes up on screen does so when the life expectancy of the lamp is approaching. Otherwise your "clicking" sound and the red light on front are saying bad lamp. When you replace the lamp remeber to follow the instruction that Panasinc provides with the new lamp on restetting the lamp timer. This is usually done with the volume down on the TV and the PIP button on the remote.
Feb 26, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television Logo
481 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
