Question about Kenmore Dryers
Dryer motor will not turn on. Circuit board has been replaced; motor repay has been checked ok. How do you get to the motor? The unit seems to be welded at the top and the back can be unscrewed but the top bein welded will not let the back come off??
  • 1 more comment
  • bill_finc312 Nov 08, 2010
    The Model # / Stock # :
    110-96595220 65952 What do I need to check to determine where the problem is? The motor is not coming on when the Air Only is selected and the start button is selected.
  • bill_finc312 Nov 11, 2010
    My dryer model # is 110 96595220 65952 . It has the filter at the bottom of the door. Can you give me directions for this dryer??
    Thanks,
    Bill
    I was not satisfied with the answer you gave; the answer was not specific to this dryer. I did find the problem; the thermal fuse was blown. I don't think you mentioned that in your diagnosis. This dryer has many switches in the circuit that could keep the motor from running.
  • 1,531 Answers
If the unit has a lint filter in the top then remove the screen and take out the two screws then use a flat tip screw driver and push the clips in to lift the lid the clips are in the front about one inch in from either side of the unit.then take off the screws that hold the front panel on.you can also try and hold the door switch in at the same time some one is pushing or turning the start button and then at the same time try to turn the drum by hand and see if it starts.once you get the fron panel off then you may need to clean the unit out and blow or vaccum any lint build up in the motor area.if the drum turns then it just might need to be cleaned if it still does not turn then you may also hace a bad door switch.
Posted on Nov 09, 2010
  • seth adams Nov 12, 2010
    well very sorry that i did not mention any of the thermal fuse.and i am glad you got it running they did cross my mind just forgot to mention them.
    President:
  • 1,891 Answers
There many models i do need your model th help to get to motor . but most kenmore dryes if filter is in top on left .. the top is removed and inside front cornors 2 screws release the front . other model s the top control panel is removed and under it is 3 screws tha the top will pull forward and the rest is easy . so with a model # i can help more .. feed back pls mm.. you may not have a motor problem . things like door sw . / one time thermo located on the filter vent housing / bad wiring ( loose connections .) or even the power 220 volts . 1/2 or the line may be out .. ?? do you have any lights or display on front of mach . .. feed back pls mm ..
Posted on Nov 08, 2010
  • dennis dodge Nov 09, 2010
    ok with the model # you need to ck the thermal cut out . located below the drum on on the back side of the vent housing . ( remove the front panel to get to it it is white andabout 1 1/4 " long and only twoo wires go to it you can jump this to test but do replace it if bad as it is a proctor . . this is a one time fuse you cannot reset it ..mm it is part # 59 on sears lay out . hope this helps mm
Maytag epic dryer
Without seeing dryer and checking it , best guess could be main control board problem
Dec 08, 2013 | Dryers
Proform V650 Treadmill - Main motor does not turn
The board will most probably need replacing. Almost certain.
I repair this brand for the manufacturer.
Nov 06, 2013 | Proform Exercise & Fitness
I have a lg gromm dryer and it dosn't get hot when drying why?:
I suspect that either the heating element is malfunctioning or the control board is. Sorry but either will mean an engineer's visit ;-0(
Sorry again,
Good luck,
John C
Mar 25, 2011 | LG Washing Machines
Fan runs outside.when i turn unit back on it starts to freeze up again,,,,also no air blowing inside.
The unit is freezing up due to the indoor fan not running. This could be because of several things. First turn off the power and see if the indoor fan turns freely. If it doesn't you may be able to oil it but more than likely it will need to be replace. If that's OK then check the capacitor for the fan motor. If it looks swollen, it's bad. You can test it with a multimeter with the capacitor test function. If that checks out OK then you need to check the fan motor windings using a multimeter on the resistance function. An open winding means the motor needs to be replaced. If the motor is connected to a circuit board, the problem could be the circuit board. You would need to check for voltage at the motor connections on the circuit board.
Sep 09, 2010 | Goodman CLJ30AR32 Air Conditioner
My drum will not turn
do you hear the motor spinning? if yes, the belt is broken and needs to be replaced. if no, check the power lines to the motor for a fuse or repay that looks burnt. if all that is ok, you may have a bad motor.
Jan 05, 2010 | Maytag Dryers
Unable to switch on. Have checked safety switch and fuse on home circuit board - OK Power on outside unit on and OK Remote control has new batteries and display OK Cleaned remote sensor panels on both...
as per the problem which you mentioned it clearly indicates that problem is with the switch in the wall unit.but you mentioned that you checked the switch and it is OK.
this means that the problem is with the main circuit control board of the wall unit.on that board the component is got blow-ned out or any of the component is got loose.you will have to check out with meter .if it looks looks then component needs re soldering but if its faulty or blow-ned out then that component needs replacement.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 31, 2009 | Heating & Cooling
Dryer won't turn on
Using a resistance meter, check the resistance of the motor that turns the dryer. If it short circuit (0 ohms) or open circuit (50ohms or greater) then you'll need a new motor.
There may also be a open circuit to the motor than inhibits it from functioning correctly.
An appliance serviceperson should be able to troubleshoot the motor and any other circuit faults. Perhaps a new (or slightly used) dryer is the cheapest solution.
May 10, 2009 | Dryers
Hoover HDV6UK keeps tripping circuit breaker
There are only 2 things that it could be both are heat related:
THe thermostat and thermal limiter OR the heating element. We can not rule out the motor though. Then you can get into the control boards. Maybe it is time.
Jun 05, 2017 | Hoover HDC6 Electric Dryer
Control Panel turns off
HI,
The PCB unit ie the control panel circuit board has gone bad. The probable cause of the same is moisture on the board.
Thanks
proton
Oct 21, 2008 | GE DCVH515EFWW Electric Dryer
Drayer problem
Check the belt, you access toi the belt by removing the back panel.
If belt is ok, then check the timer control, the motor, and the motor control unit, that is an electronic board, usually protected by an insulating box inside the appliance.
There are also a couple of circuit breakers you should check.
Entering the model number here you get the exploded view, and replacement parts.
Aug 08, 2008 | Hotpoint TDC32 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
