Question about Kenmore HE2 Plus Front Load Washer
I have a Kenmore HE2 Plus washer. MOD: 110.47511701, SER: HLW3076273 that is leaking water. It leaks pretty much constantly as long as the washer is running. Pulling off the front bottom, I see alot of water all over (however the counterweight is dry). Pulling off the back and starting the washer shows a very big leak coming out of what appears to be the motor drive (black part that seems to be part number W10140581). Specifically it seems to be coming out of the "grate" bottom of this part. After I shut off the washer it continues to leak slowly from this spot (as if it is draining what is in the washer). Any help would be appreciated.
  • dcolpi Nov 14, 2010
    Just posting a follow up for anyone else that might have a problem similar to mine....
    Ok - well, I could never find where the leak originated, so I decided to take off the motor and get a better look. I went to start this, and I found that there was no bolt connecting it to the drum! Did I already try removing the motor? No. I looked around for the bolt, couldn't find it. Well, we will put that on hold for now.
    I moved the motor (pivited it on the right side, and I immediately find the cause of the issue. A big hole in teh drum! It seems that the lack of the bolt connecting the motor to the drum was the cause of the issue. As the drum vibrated, it was smacking up against the motor. There is a dimple there right above the motor (looks like a place where the plastic of the dumb was poured) and the motor had struck that dimple with such force as to drive it into the drum, also causing a crack about 3 inches long.
    Found the leak. It seems that someone forgot this bolt when they put together the washer. Mine must have been made Friday at the end of the shift.
    Well, a new drum probably costs a few hundred dollars on top of what I assume to be a big pain in the **** install (which would include getting the heavy drier off the washer). So, I figured I would try some plumber's epoxy that I happen to keep on hand at all times (I try to always keep some, along with duct tape, JB Weld, and other staples that I always find I need). I did need to run to the hardware store though to get a bolt that would fit.
    So far, no leaks and I am 4 loads in. If this holds, I think I can live with the fix. If it doesn't hold, my guess is that I need a new outer tub assembly (or just the back half if I can get just that).
    Hopfully by posting here I can help someone else who might have had a similar problem (I could not find any similar online anywhere).
jsrock516
  • 5911 Answers
SOURCE: Front Loader Kenmore Mod # 110.44832202 is leaking.
The rubber seal is known as a bellow. If the bellow is torn, more than likely it IS the cause of your leak. Your only course of action is the replace it. Searspartsdirect.com carries replacements. Just type in your model (as you provided) and look under the "Door and Latch Parts" heading for item number 1 (part #8182119). It is not a cheap part, but it will cost you much more to have an appliance repair company install it for you. This is not a difficult repair, and you can accomplish this on your own if you follow these steps:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Some additional parts that normally do not need replaced, but you may consider just in case are the front and back clamps that hold the bellow in place. They are listed under the same heading as items 6 and 14. They don't cost that much and may consider them just in case you need them. In particular, the front clamp, can break or the spring becomes stretched. Inspect these items just to be sure.
I hope you find this information helpful. If you require additional assistance, please let me know.
PS You may also try repairclinic.com for comparative pricing. They also carry the same parts (sometimes for less).
Posted on Sep 12, 2008
  • 61 Answers
SOURCE: Kenmore Elite HE3t door leaking (Model 44936)??
If the unit leaks during use with a constant drip from the 6 o'clock location between the seal and the glass on the door the solution is to change tha door seal. it is quite difficult to do I would recommend you call a local service company.
Posted on Dec 18, 2008
danromarris
  • 101 Answers
SOURCE: Kenmore 70 Series leaking water from bottom
I used to work for Sears as a home repair technician and washers and dryers were my specialty. Most likely the problem is with your water pump. I ran across this issue many times and what happens is people leave things in their pockets and it destroys the pump. A hair pin or coins, I have even seen socks and under ware get stuck in them causing leaks. What you want to do is tip the machine back and look at the pump. It is located right at the front of the washer with two hoses connected to it. You will want a pair of hose clamps though if you don't want water all over your floor. Disconnect the pump and look inside it for anything causing the motor inside to not work, this will cause slow draining and even leaking. If it looks clear then look for any cracks in the pump. If there is a crack then it needs to be replaced. Just call your local appliance repair place and tell them what you need. Pumps run around 30 bucks or less on average for Kenmore's. If everything looks good on the pump check the hoses that run from the pump and make sure there are no cracks or holes in the hoses. If they look good then the only thing left is the tub and the overflow tube. Chances are though that your pump is what the problem is and it is an easy fix. Good luck.
Posted on Jan 21, 2009
  • 188 Answers
SOURCE: he2 front loading washing machine leak at the soap dispenser regi
Hi dlypooh, thought I would post the solution here as well for anybody who needs to do a search in the future...
Remove the dispenser, pour water into the opening and make sure water can get into the machine freely. Inspect the opening for soap build up.
If water goes down slowly (re: dlypooh), open the washer door and feel around the bellow for anything blocking the water inlet port into the washer (socks can sometimes get wedged up there and cause a blockage).
If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
Hope that helps!
Posted on Feb 21, 2009
  • 41 Answers
SOURCE: HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Posted on Sep 03, 2009
Water is in the washer the next morning
The inlet solenoid valve is dirty and doesn't shut off completely so there is a tiny leak over time. Generally this will get worse over time. You can simply turn off the water at the tap after each use or replace the solenoid, pretty cheap part. Some solenoids can be opened and clean the grit out.
Jul 09, 2013 | Kenmore HE2 Plus Front Load Washer
Tip
I also had problems with my Kenmore HE2 leaking water on the floor. I removed...
I CAME TO THE SITE WITH THE PROBLEM OF MY WASHER NOT DRAINING. I HAVE HAD PROBLEMS WITH THIS FOR MONTHS. TAKING THE HOSES OFF. CLEANING THEM ETC... TODAY I FOUND THE BEST SOLUTION.. THE WOMAN WHO POSTED THAT SHE SAVED HER HUSBAND $300.00 BY TAKING THE BOTTOM OFF WASHER WAS RIGHT.....
BOTTOM OF FRONT LOADER.. THERE ARE THREE SCREWS.. YOU NEED ONE OF THOSE NOT PHILLIPS BUT ROUND LOOKING SCREW DRIVERS(SORRY).. ANYWAY TAKE OFF THREE SCREW.. ONE ON LEFT, RIGHT AND MIDDLE.. THERE IS A WHITE DRAIN HOSE WITH A CAP.. VERY HEAVY PLASTIC FRONT. IT IS HARD TO TWIST OFF CAP BUT KEEP TRYING. ANYWAY IT IS GONNA GET REALLY WET.. SOME WATER CAME OUT AT FIRST BUT I WAS NOT CONVINCED.. SO UNDRNEATH I STARTED TO SQUEEZE THE HOSE AND OUT POPPED 3 SOCKS AND AN ERASER.. THEN ALL THE WATER THAT WAS IN THE WASHER THAT WOULDNT DRAIN.. EVERYTHING WAS SOAKED INCLUDING ME AND MY SON SO BE READY WITH LOTS OF TOWELS. BUT IT WORKED. IM HAPPY TO SAY IM DOING MY FIRST LOAD NOW AND EVERYTHING IS RUNNING BEAUTIFUL...
on Apr 09, 2009 | Kenmore Elite 45986 Front Load Washer
Water leak
it is probably coming out of the hose that goes into the pipe behind your washer.
Dec 20, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 - water leaking from bottom - almost like a garden hose? any ideas
remove panel on bottom usually three screws will remove panel then u can look inside to find leak.. check the drain pump for leaks or debri inside pump by removing cap u willl see down there... hope this helps
Feb 06, 2010 | Kenmore HE2 Plus Front Load Washer
Washer is leaking. If facing washer, water is on
probablly water pump or hose tilt machine to view where water is coming from
Jan 17, 2010 | Kenmore HE2 Plus Front Load Washer
After my daughter washed a quilt. The Washer leaks water out of the bottom. Is a seal loose? What is my best access to open the washer to see what the problem is. Thanks
The quilt had nothing to do with this problem. It is the water pump that is worn and has started to leak from old age. It needs to be replaced.
Oct 10, 2009 | Kenmore HE2 Plus Front Load Washer
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Torn door seal on front loading washer
My husband used super glue on the tear and for now the washer is not leaking.
Mar 25, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
