Question about Panasonic DMR-EZ47V DVD Recorder/VCR
The DVD record function is not working. Reading the manual it says that the function can be disabled if the unit is repeatedly turned on and off or if a disc is inserted around 50 times. I have a young child and this may have happened. Can the record function be enabled once more?
  • Richard Upton Nov 08, 2010
    Thank you for your help. I should have supplied some additional information to say that the display highlighted 'DV' - which implies that I should change the channel into which the signal is being drawn from (my little girl presumably have moved it from AV1!)
    Regards
    Richard
    Thank you for your help!
  • 1,476 Answers
Richardupton,
I know this may seem very easy and trivial but if you unplug the unit for an hour it should reset to factory specifications when you plug it back in. This should solve your problem. If it doesn't try playing a DVD. If it plays then there is a bigger problem which you probably cannot solve (electronic). If it does not play I would try cleaning the laser assembly. This is a process which needs to be done correctly. I have a tip at http://www.fixya.com/support/r4119308-clean_lense_cd_or_dvd_player which explains the process and where to get any materials you may need.
Thanks for using FixYa and for the great rating. Ratings will keep experts helping to solve everyone's problems. Thank you very much.
hardrocko
Posted on Nov 08, 2010
Unit turns on and off but nothing else works
Simultaneously press the [CHANNEL UP] and [CHANNEL DOWN] buttons on the front of the DVD Recorder for approximately 10 - 15 seconds (until the unit powers off).
Disconnect the wall outlet. Wait for 10 minutes. Then power up.
It this still does not help....and If you are capable of taking the risk check out DMR-EZ47 Firmware Installation Instructions
Panasonic DMR EZ47 Installation Instructions Manual
Familiarize yourself with all the steps and especially the page 7,8 before you attempt this,
Mar 25, 2016 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVD player will not read any discs.
> I tried recording a VHS to a DVD according to the instructions in the manual.
There can hardly be instructions in the manual to do this since that model is not a DV Recorder, but if it isn't reading any DVD then you have a warranty problem assuming your unit is still within the warranty period.
That unit is capable of recording DVD content to VHS tape but not the opposite.
Mar 13, 2010 | GoVideo DV2130 DVD Player/VCR
LG RH266 DVD/HDD RECORDER The HELLO message keeps repeating when turning the unit on. So cannot receive picture etc Is there a code from the remote to fix this or a part replacement ?
hi,i have an lg 389h dvd recorder,it just says hello scrolling across the display,and doesnt respond to any functions on the,remote control,any ideas,cheers.
Oct 14, 2009 | LG DR787T DVD Recorder
Vhs to dvd
Recording is disabled when the progressive scan mode is on. You have to reset the unit first.
Take out any disc or tape. With the unit on, hold down the Rewind and Fast Forward buttons together for 10 secs.
Then turn the unit off and on. It should work fine after that.
Jun 29, 2009 | Samsung DVD-VR357
Panasonic dvd/vcr DMR-EZ47V model.Code OOOOOO keeps going across.
You must manually hold in the on/off button on the machine itself (NOT on the remote) for approximately 30 seconds. This will shut the unit off. Then you can restart it.
Jan 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Child protective lockout can't be turned off
I found the remote, then tried 0000 to unlock, which didn't work. Luckily 1111 did. I figure if I hadn't found the remote, I could have bought a cheap universal one. But all is well now. I still have no idea how the parental control was implemented.
Mar 30, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Won't read disks
According to page 69 of the owners manual:
If you repeatedly insert discs or turn this unit on and off 50 times or more, the recording or editing of DVD-R may be disabled.
There is no suggestion to fix.
Mar 06, 2008 | Panasonic DMR-E75V DVD Player/VCR
NO FUNCTIONS
Replace the Digital board
Feb 26, 2008 | Panasonic DMR-E50 DVD Recorder
DVD tray will not open
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Feb 25, 2008 | Dual Presidian DVD Recorder
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
436 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
