Question about Texas Instruments TI-83 Plus Calculator
What does it mean the calculator says "invalid dim"??
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If this isn't the problem, please reply to this post stating what you're doing to get this message, and we'll go on from there.
Posted on Nov 08, 2010
Invalid dim when zoomstat
Invalid dimension is displayed if the two columns have unequal length (number of elements).
Try plotting the scatter plot first, then worry with the Zoom.
Apr 11, 2014 | Texas Instruments TI-83 Plus Calculator
What is the meaning of the error message "invalid axes"
This is problem with graphing differential equation. Invalid Axes error occurs if Axes=TIME or if t(time) is set as a CUSTOM axis. This is important to noticed: if Fields=DIRFLD you cannot plot a time axis. See captured image
Feb 08, 2012 | Texas Instruments TI-89 Calculator
What does "invalid dim" mean?
The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat
plots. To turn the stat plots off, press {2nd}[stat plot], and then select 4:PlotsOff.
Jan 19, 2011 | Texas Instruments TI-84 Plus Silver...
When I press graph, it says "ERR: INVALID DIM" how
Jan 14, 2011 | Texas Instruments TI-84 Plus Calculator
When I try to graph, say y = x, I get an error message that says "invalid dim." The window settings are identical to another TI-73, so I'm not sure what the problem is. Can you help?
"invalid dim" could also mean that a list or, lists don't have the same dimensions or lengths. To fix this press [2nd][MEM][6][ENTER] -To clear out all the lists. Ti's instructions normally just has the user delete all memory instead of finding the exact problem. This can be done by being at the home screen and, by pressing [2nd] [Convert] [1][2][ENTER]. But, because I don't like starting all over everytime I preform a math process and, I like storing things into memory so I have to find the problem and fix it as I go a long.
To find such a problem as your's, I would look at x in the y= equation. It may be claiming that x is a list too. So you may want to [2nd][MEM][4] and then use the press [1] and find and highlight x and, press [ENTER] to delete it. It also might be a good idea before you start in the y= editor to press from the Home screen [2nd][MEM][4] and then press [4] and highlight the y= have equations and are not empty and, press [ENTER] to delete them. Then I would continue deleting all the y= equations too. Sure you can just make sure their off but, I'm not sure how advance of a user you are. On your calculator for the window settings to be a problem, you would have probably received a window range error.
Dec 31, 2010 | Texas Instruments TI-73 Explorer...
When I graph, it shows "ERR: INVALID DIM 1:QUIT"
Oct 28, 2010 | Texas Instruments TI-84 Plus Silver...
Error invalid dim
Reset memory to default, the error will disappear.
[2nd][MEM][7][2][2] Defaults set.
Hope it helps
Sep 06, 2009 | Texas Instruments TI-83 Plus Calculator
INVALID DIM error! help me!
Here is what the manual says
INVALID DIM : The dimension of the argument is incompatible with th current operation. (As dimension of a matrix, a list).
You can tell us more about what your were trying to do, we may able to help. Reset memory to default, the error may disappear.
Hope it helps.
Sep 02, 2009 | Texas Instruments TI-83 Plus Calculator
I need help with graphing everytime i try to draw a graph it comes up with this ERR:INVALID DIM what does that mean
It means that your Xmin or Xmax is messed up. it often shows up when you are plotting somethings (histogram for exanple) and you don't have enough X or Y range to fit all the points in it. it also happens when you are multiplying matricies without using the right dimensions. ERR:INVALID DIM just means your dimension is invalid.
Mar 06, 2009 | Texas Instruments TI-84 Plus Silver...
Invalid dim
Turn off your stat plots
2nd Y=
ENTER
Apr 23, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
