Question about Toys
How do you fold it? Do you have instructions. I have it up and now I can't fold it back down. Can't find any clips or thing a gigs to do it.
  • 1,498 Answers
If I may be so bold, kindly put yourself in our place and read your question.
While I am confident someone here can help you, I am also quite sure that in order to do that, they need to know what it is you can't fold.
Please post a new question with details like make, model what it is, etc.
Thank you and best regards
Mike
Posted on Nov 08, 2010
Once I've folded my phil & ted vibe (in single mode) the locking clips won't fold into place (I've used as much force as I dare -- worried I might break the clips if I try any harder). This makes it...
When folding the Vibe some important things to remember are that the handlebar must be in the most upright position (perpendicular to the ground), nothing can be below the rear axle level (ie. lift the basket up above this) and the front single wheel should have the side with the attachment bar on the outside.
The fold locks will not engage if everything is not in the correct position. If everything is in the correct position the fold locks will easily engage/disengage. If everything is NOT in the correct position the fold locks will not engage and should not be forced.
Folding:
  1. Put handle bar in upright position.
  2. Undo the side lock clips. Then you lift the red lever on the side to start the fold. Fold so that the pram front wheel and handle come together.
  3. As the pram folds ensure basket is above rear axle and the front wheel has the attachment bar on the outside.
  4. When the pram is fully folded you can fold the side lock clips back in place.
Nov 12, 2009 | Regal Lager Phil & Teds Vibe Jogger
I can't fold the buggy down!
First you need to make sure that the handle bar is in the top most position. Next the Front wheel needs to be turned sideways as you begin to lower/fold the buggy.   You must also watch the basket part so that it folds up and in so that it doesn't get stuck. I usually will also fold it forward and down so that I know the wheel and basket are in the right position.  When it is finally down it should clip into place. Hope that helps a little. :)
May 16, 2009 | Phil & Teds E3 Jogger
Instruction for a pegpergo stroller to close
There are little finger/thumb grips right below the handles that you push with. Not the long oval thing, that adjusts the handle height, but little grips on front and back of the handle. On both left and right handles. you put your index finger under front one and middle finger under back one, (both sides at same time, use both hands) and pull UP on them while leaning the stroller forward to fold it down, push it down until it clicks. Open same way, pull up on same grips to release the click lock.
good luck, DON'T PULL RELEASE CLIPS UP MANUALLY, THEY WILL SNAP AND YOUR STROLLER WILL NO LONGER CLOSE, MY DAD BROKE BOTH OF MINE.
May 01, 2009 | Peg Perego Baby Gear
Fold and lock stroller
Hi! I have the same stroller as you do, the way to lock it once folded is, you should see a red plastic loopedy thing down by the front right side of the seat. This hooks onto that weird brown plastic nubb i'm sure you've seen on the right side of the handle.
Hope this helped!
Mattie
Mar 17, 2009 | Graco Quattro Tour Deluxe Travel System...
Fitting instructions for the wind deflector????
If you are having trouble fitting the wind deflector, try adjusting any of the four spring loaded pins. Each pin is actually a screw that can be turned to lengthen or shorten for a proper fit. Once pins are the correct length, facing the rear, insert the two pins on the left / passenger side first. Then use the springs to insert the rear / driver side pins. Last pin inserted should be the one closest to the driver seat. The large clip should extend just over the outer, right edge of the deflector.
To fold, you first need to release the pin from the upper / folding part of the deflector. This pin is on the driver side of the deflector, but on the left part of the clip. When removing / folding the deflector, grab the clip closest to the driver seat, and pull out and back (towards the driver seat). Then slide as far left (towards passenger side) as it will go. This should release the pin from the upper/folding part of the deflector and allow for easy folding.
Feb 23, 2009 | 2007 Mini Cooper Convertible
I have a 1996 Isuzu Rodeo, and cannot seem to figure out how to lay down the back seats. Can anyone please tell me how to do this? Thanks, Jim Cummins: jcmusic@tampabay.rr.com.
There should be two seat belt clip notches in the seat where the seat belt clips comes out the seat. In those two notches there is also a strap in each notch that doesn't look like it really belongs there. Pull those two straps at the same time and the seat pops up and folds down. The back rest part of the seat will then fold down. Remove the head rest section of the back rest and it will fold all the way down.
Feb 22, 2009 | 1996 Isuzu Rodeo
Folding - Quinny buzz 3
HI, if it's the same model as I have: start with the frame facing you with the break on, you will see 2 long grey 'buttons' situated where the seat clips in to the frame. One of these buttons has arrows on it like this ^, this one you push in the direction of the arrows. The other you, simultaneously push in. You then push the whole frame down - this takes a bit of pressure. The whole thing should fold flat, you then secure it with the cable located near the wheel.
This sounds very complicated, it isn't once you've done it the first time - I hope it makes sense to you!
Feb 06, 2009 | Quinny Buzz Jogger
FOLD DOWN STROLLER
there will b a bar at the back puch that up,there is also usally a small clip at the side push that down then push the buggy to the ground.
hope this help thats how mines is done
May 20, 2008 | Evenflo Baby Gear
2nd hand BEBEcar Adventure raider AT+
Hi, I have just bought second hand the exact same pram. You have to push in the red button in the middle of the handle, then turn the handle down towards the floor. By putting a little pressure on it it should now start to fold down. Hope this helps.
I have my own dilemma though. When the carry cot is on as a forward facing pram, does the seat unit come off that you use for the buggy?
Apr 17, 2008 | Bebecar Raider AT Stroller
How do I fold the Bell Jogging Stroller?
OH SNAP!! I just went back and figured it out. So provided your Bell Jogger Stroller is like mine, here's what you do: look for the black plastic clips on the sides of the frame. As you face the stroller head-on, these clips should be on either side of the passenger area. The clips have semi-circular grips. Pull up on these to release the clips. This should allow the push handle to fold down toward the floor. Then make sure the snaps holding the cargo pocket below are UNsnapped, allowing the stroller to completely fold in half. To set it back up again, reverse the process although I would re-snap the snaps last of all.
Nov 20, 2007 | Bell Sports Scout Jogger
Toys Logo
79 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
