Question about ViewSonic VA1930WM LCD Monitor
ViewSonic VA1930wm Screen stays on for about 2 seconds, and then goes off. 1) If no computer is connected you get a "no signal" message which stays for about 1 seconds and then goes off; blue power light switches to amber. 2) If a computer is connected the full Windows screen flashes on for about 1 to 2 seconds and then it flashes off (what appears on the display depends on where in Windows the system happens to be at that particular time). The monitor goes through this cycle about every 5 to 10 seconds, or so!
    Champion:
  • 331 Answers
Very typical of View Sonic. Sounds like a back backlight or inverter. I would go to www.viewsonic.com and open up a RMA. Most view sonic screens have a 3 year warranty. They will repair at no cost ..(if it is within that period) There is a date code on the back of the screen that will help you validate the above information.
Posted on Nov 07, 2010
My viewsonic monitor goes black after booting up
Does it do the same with other PC?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 17, 2010 | ViewSonic VA1930WM LCD Monitor
Monitor on but image from pc come in for a second, and get screen black
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 29, 2010 | ViewSonic VA1930WM LCD Monitor
I have a viewsonic va1930wm. it turns off and on. how do i fix this
Is ur graphic card ok?
Have ur screen tested on another PC to determine exact cause...
Feb 06, 2010 | ViewSonic VA1930WM LCD Monitor
Cant find signal from cable - Logo comes up in greyscale then states "no signal" Cable checks out fine.
Connect a different monitor to your computer, to see if the video-card in your computer is working.
Connect your monitor to a different computer (desktop/notebook) to see if the monitor is working.
Jan 21, 2010 | ViewSonic VA1930WM LCD Monitor
Screen turns on briefly then off, a few seconds later on again, then off. It is mostly dark, but turns on for about a second, then off.
Open it up and look for bad caps with bulging tops, also check for 12v for the backlight inverter circuits. See some example of failed Viewsonic monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 12, 2010 | ViewSonic VA1930WM LCD Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic VA1930WM
You need to isolate the problem to see if there's a problem with the monitor or with the sound card of the computer.
To isolate this problem, please try the steps below:
1. Make sure that the monitor is properly connected to the computer.
2. Check the volume of the monitor and the volume properties of the computer.
3. Try to connect your monitor into a known working computer.
Apr 15, 2009 | ViewSonic VA1930WM LCD Monitor
Screen goes to sleep after "no signal" message
If you do not move the mouse or press any key on the keyboard it could be just going into video power save. Confirm it by moving the mouse or pressing a key on the keyboard. If the monitor comes back on, adjust the power settings in control panel and change the time for the "turn off display" to a more suitable setting.
Dec 31, 2008 | ViewSonic VA1930WM LCD Monitor
ViewSonic VA1930WM LCD Monitor Logo
722 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
