Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
Final spin.. does not work.. clothes are not being sprung.. still have lots of access water.. help please
  • Whirlpool Master
  • 1,902 Answers
Hello
Washer wont spin if it is unable to drain properly. Try checking the drain hose and drain pump filter for any clogs/foreign particles and clean it. You can also check/test the drain pump operation. Please get back to me if you have any questions.
Kevin
Posted on Nov 08, 2010
Why are clothes dripping wet after final spin?
There is a balance sensor in the machine that checks to see if the load is distributed for high speed, When that sensor goes bad, the machine wont spin the water out of the clothes. YOu need to check for spares
Apr 22, 2016 | Tricity Bendix AW1000W Front Load Washer
Washing machine leaking underneath
might simply be a small hole in the outlet drainage hose, this would explain why your machine leaks during the final spin, there is more pressure from the water inside the hose during the final spin than when the machine is draining. hope this helps.
Nov 11, 2013 | Hoover Washing Machines
My indesit 6105 does not finish with a final spin but everything else works and the drum spins up to this point. This means that the clothes come out very wet
There is fault on the final spin as it fails to dry or drain off the water from the clothes. It is possible that the RPM for the spin is not adequate or the timing is short. Please choose a different program to confirm. Also check for free movement of the drum or else use a de-greaser to the drum spindle bearing assembly.
Aug 02, 2013 | Washing Machines
After the final spin cycle, my clothes are still wet.
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 21, 2009 | Hoover HTC243 Top Load Washer
Will not spin in final spin
there is likely a blockage in the pump/bottom water feed hose. check out the filter and if clear you will have to clean out the bottom hose.
Apr 05, 2009 | Frigidaire ATF6000ES Front Load Washer
On final spin water not draining out
If the motor and drum are going round, then you probably have a blocked pump.
Check outflow of water from m/c, check filter if you have one. m/c will not spin if a lot of water in.
If still no spin then problem could be any one of a number of things.
Plz rate my solution.
Thanks.
Dec 14, 2008 | Washing Machines
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Final spin cycle
Lots of possibilities to check out before considering a problem with the machine: Is the load unsorted, too big or off balance? Drain restricted or too high? Oversudsed? Water draining completely out before going into spin?
Jan 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
67 people viewed this question
Sal De
Marvin
Marvin
jimorris77
