Kenmore laundry center 417.94812301
My washer is making my head hurt. First it wouldn't spin or agitate, now while I was trying to diagnose it, it only fills when the lid is up. When it stopped spinning, the lid lock was working right. The pump works fine, and the belt is not worn and I found no oil anywhere. I have a feeling that my son overloaded it with towels. I am just completely lost - it seems electronic but I have no clue. Please help!
  • 2 more comments
  • olivia4414 Jun 15, 2008
    ok one more thing wrong - my dryer won't heat up ummm can anything else go wrong?
    I was able to remove the front panel of the washer but access to everything is through the back and I have no idea how to remove it - I imagine that is where the major controller is Thanks
    lol you are funny I am not even sure if my car has a spare tire now that you mentioned spares lol least you made me laugh about it all
    It is a 417.94812301 serial xe61203376
  • 1,879 Answers
It is a good type of washer up until the motor encounters a heavy load that will break it's normal operation.
Do you have a spare control panel that can be used for that unit ?
Posted on Jun 15, 2008
  • monk3ybidzness
    monk3ybidzness Jun 15, 2008
    ; ) - glad to make the best out of anything
    Sergeant:
  • 243 Answers
Sounds like the controller has gone out. Your best bet is to have someone come out and service it. If its under warranty they will fix most of it. If not a technician can tell you what needs to be replaced and you can figure out if its worth replacing.
Thanks,
Nate
  • 7 more comments
  • Nathan Ayers
    Nathan Ayers Jun 15, 2008
    hahah that is funny someone said that. I cant think of anyone that would have a controller laying around as a spare for there washer or dryer hahhaah. But it sounds like its your controller a technician can come price one out if its possible. Then that will help you know how deep your into it at this point.
  • Nathan Ayers
    what model is it exactly?
  • Nathan Ayers
    looked like a phone number. hehehe
  • Nathan Ayers
    you should check the speed control card for obvious signs of damage. looks like on these models it can overload.
  • Nathan Ayers
    the board should be marked with the number ZTX45
  • Nathan Ayers
    this seems like it would be the part if its what blows on these when overloaded.
    click here
    this should help you get everything figured out. I hope your problem is solved. As i said though might be best to have a technician come out to let you know.
  • Nathan Ayers
    if youd lik to service it yourself heres is a good way to go about it
    Step 1. Make sure It has power.
    Step 2. Check to make sure the motor doesn't move. Or that other things do work, Make Sure the fault is not with the timer line switch or the door lock switch.
    Step 3. Check the power to the speed control board (pins 5 and 6) is good.
    Step 4. Make sure the voltages on pins 2, 6, and 10 are 120VAC as required. The
    voltage on pin 1 if not the same unit is bad . If you were to put a small load on it, it
    would be the required zero volts.
    Step 5. Check and make sure the fuse is good.
    Step 6. Make sure resistances between pins 1 and 2, 2 and 3, 1 and 3 of the speed control board are 3 Mohms +/- as required.
    Step 7. Check to ensure Motor winding resistances are OK.
    after all this you should know exactly whats wrong. most of these steps needs a multi meter to be performed.
  • Nathan Ayers
    If youd like to goto a premium chat session I could help to walk you through it all. permitting you have a multimeter and tools needed.
    hope this helps you with everything, if not let me know.
    Thanks, Nate
  • Nathan Ayers
    Nathan Ayers Jun 16, 2008
    let m know if you have any questions about anything i posted. As I will be glad to further assist you. Should you choose to do it yourself.
    Genius:
  • 1,036 Answers
Sounds well confused doesn't it?
I think it is the major controller at fault.
Can you access it to check connections first.
I cannot see how so many problems can exist otherwise.
The dryer element may be broken. Check it with a meter to test ohms. If it's very high, it probably needs replacing.
If you need further assistance - just ask.
  • Richard Perkins
    Richard Perkins Jun 15, 2008
    The main controller is attatched directly to the control knob you are using - or certainly very close.
    It could have become faulty due to vibration/knocks if the tub was overloaded - or even corroded due to condensation.
    Remember to unplug and turn off supplies before attempting repairs (got to say that)
  • 4,472 Answers
You definetly want to have someone come out and service this. Is it still under warranty? If so you won't be liable for all of it.
Good luck,
Lee
  • Lee A.
    Lee A. Jun 19, 2008
    Still hoping to hear back if not I will assume that you found my solution more then helpful.
    Thanks,
    Lee
Have a Kenmore Laundry Center (dryer top and washer on bottom) - model is 417.99160110. A towel is firmly under agitator and gave us smoke! How do I remove agitator cap and agitator itself?
Remove the caps on the top of the agitator. Next using a suitable socket, undo the retaining nut being careful not to loose and washers..
Lift the agitator enough to remove the towel. Reassemble...
Apr 15, 2017 | Kenmore Washing Machines
Washer squeaks during agitation, both wash and rinse. also makes thumping sound for few seconds after spin cycle stops.
Hello Chris, thank you for your post!
I see that the washer on your Frigidaire laundry center is squealing during agitation. This noise could be coming from the motor or transmission and you may need to have the washer disassembled to locate which component may be causing the issue. For proper disassembly you may need to seek assistance from a professional technician. A technician will have the appropriate tools needed for complete disassembly of the washer without causing personal injury or harm to the laundry center. Hopefully this information is helpful towards your repair. -Matt
Apr 20, 2016 | Frigidaire fex831cs stacked washer&dryer...
When I put a light load into washer, follow directions, the washer starts by running water but does not go into next cycle
I would check the lid switch. If switch is faulty, it will allow unit to fill like normal, but won't agitate or spin.
Nov 15, 2015 | Kenmore 24 in. Gas Laundry Center with...
Top load frigidaire washer will not spin, it agitates, it drains
You need to replace the starter cap on the motor this is why it will not turn and the smell is the cap that's not starting the motor it also will hum.
Dec 29, 2013 | Frigidaire FFLE2022MW Electric...
Kenmore model # 110.23832100 Washer would drain but wouldn't spin or aggitate. Replaced coupler. Now will spin and agitate, but will not drain.
sounds like it's in the re-assembly since the water pump is directly connected to what you just did. take it apart once again and make sure all is put back right and water pump is properly seated on motor shaft.
Jul 15, 2011 | Kenmore 23822 Top Load Washer
Kenmore Series 80 Washer, Model 20852 - Agitator not turning well, making noise
Hi, If the washer spins properly but the agitator does not work, it could be the dog kit needs replaced. If the washer does not agitate or spin, it is probably the coupler.
Put the washer in wash cycle with no laundry in it and see if the lower prt of the agitator moves. If the agitator moves, try and hold the upper half of the agitator and see if it will only move one direction.The agitaor dog kit is designed to only let the top part of the agiator to grab one way. When they go bad, they can make some noise.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Washing Machines
Kenmore laundry center stacked washer/dryer washer tub shakes almost violently on spin cycle.I may have changed setting during spin cycle.Tub is off balance.The appliance cabinet is balanced and on a solid...
Head over to the manufacturer's website.
www.SEARSPARTSDIRECT.com and enter your full model number for an expanded parts diagram and ordering information.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 11, 2009 | Kenmore Washing Machines
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
