Having problem on starting sharp aquos LC-37G4U. When I switch on, the GREEN light appears on both TV & AVC. After few sec, i hear couple of clicks in AVC then the lights go on to RED. When I press Power On, it behaves similar ( finally gets on to RED ).
  • satish rachana Nov 10, 2010
    Similar incident happened earlier, but worked after reconnecting. I suspect, its some quick fix rather than some parts damaged. Request for some help
  • satish rachana Nov 15, 2010
    Could you pls help me where I should be looking for these bad capacitors etc. Would it be in LCD TV or the AVC system. I have power supply for both where as the Cable, DVD etc connection goes to AVC System. The AVC is connected through bus to the LCD TV. Request you to provide step by step details for me to verify
  • 5,138 Answers
Have you removed the back to Look on Power supply board for Bad capacitors ,they will be vented,swollen or Puffed up on Top 2200uf 10v 3300uf 10v 1000uf 16v.
this unit has Fan See if it is Dirty or full of Dust Clean it and that Might be Fix the problem.
Let me know what you find and if you need more help. Thank You
Posted on Nov 10, 2010
  • 4,889 Answers
From your description it seems like you are facing the infamous "Protection fault". It usually occurs in the power supply board of the tv when a vital component(such as a resistor, voltage regulator IC etc.,) that should regulate the flow of voltage in a particular circuit fails there by allowing more than the max voltage. As a result the set turns itself off to prevent further damage to its components and the power LED turns red. A component level repair is possible, but if you wanna do it yourself, you should have the know-how of electronic circuits and working on them i.e, using a multimeter, knowing what components hold residual voltages etc., If you do not have these skills then its highly recommended that you seek the assistance of a qualified tv tech, to fix it for you. If you are located in the US then please get me your zipcode so that I can get you a list of techs in your area.
Sai.
Posted on Nov 08, 2010
  • eagle338
    eagle338 Nov 10, 2010
    Well if the protection circuits, worked correctly to block the surge, you can get it back to working state by unplugging, wait for 5 min and plug it back in. You can give it a shot and see if it works.
I have a Sharp LC-46E77UN TV. Remote will start TV green light on. No picture, just stays black. PVR is on and connected to TV via HDMI cable. Cannot turn off green light. Must use power button on TV and...
THe problem is in the set top box. Or common called the tuner box. IT looses the 5 volts to the main display and thus the monitor will go into a shut down state. THESE boxes are factory repair only and must be sent off to repair.
Feb 20, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I can't play movies on my tv
Okay, this monitor setup is a little strange. There is an "AVC" component with this monitor that you use to connect everything. There is a 4 cable string (power, s-video, DVI, display port) that connects the AVC unit to the monitor. You must have all external equipment connected to the AVC unit, not to the TV itself. The connections on the TV talk to the AVC unit. I will assume you will be connecting the Blu-ray player via HDMI. HDMI is on input 4 on the back of the AVC unit. hit the input button on the remote or the TV and select input 4. There is a way of customizing the inputs to read out what you have connected to them (ex. DVD, VHS, etc.) to make it easier to use. This should get you signal from your blu-ray
Nov 06, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
LC-C6554U HDTV AGUOS 2 GREEN LIGHT FLASHING, NO PICTURE NO SOUND
Did you ever find a solution to your problem? I have the same set doing the same exact thing.
Thanks
Jul 30, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquous Remote Codes
You can download the manual for the TV. It has all the code for the remote on page 90.
Here's the link:
LC-37G4U | LC-32G4U & AVC System Operation Manual (3900K)
Mar 31, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp AQUOS LC-60C52U
hi had same problem easy fix get your sharp remote make sure you are on tv mode by pressing function button tv should light up on remote. then press view mode button(above 3) put setting on s.stretch and thats it bye bye green line.
Sep 08, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Out of sync message
When you first turn on the unit very quickly push the imput button to switch sources.It is stuck on the computer imput.
Feb 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
