Question about Holley 0 80552 650 Cfm Four Barrel Carburetor
Its running to rich ? - Holley 0 80552 650 Cfm Four Barrel Carburetor
    Novelist:
  • 184 Answers
I believe those adjustments are air jets, so closing them off run too rich. Also open the slotted plugs on the float bowl to check the fuel level, adjust by running the needle and seat assembly out or into the float chamber to achieve the correct level- it quits ******* fuel when it's right. Next -(if that hasn/t helped) Look up the jets and adjustments for that engine application.
Posted on Dec 17, 2011
1991 Toyota Camry running rich after cleaning the throttle body and replaced the throttle positioning sensor. Checked for vacumm leaks but cant find any
92 camry failed smog because running rich. Why? - Toyota Nation ...
www.toyotanation.com/.../411132-92-camry-failed-smog-because-runni...
Apr 26, 2012 - 15 posts - ‎9 authors
off ignition timing, and the car was running to rich. the timing i will get fixed tomorrow but the rich .... Our 93 camry le with 4 cly engine failed agin a few weeks ago, both our toyotas always fail.. they are .... 1991 Toyota MR2 V6 91 MR2 N/A Rough Idle, Running Rich, No Accelleration
Apr 24, 2012
Celica 1991- Insane gas consumption/running rich
Jan 24, 2011
22RE Running Rich, didn't pass smog
Apr 25, 2010
1998 Camry 5SFE 4-cyl idle long-term fuel trim
Sep 11, 2007
More results from www.toyotanation.com
Toyota Camry running rich Questions & Answers - Fixya
www.fixya.com > Forum > Tags > running rich > Cars & Trucks > Toyota
... running rich I have a 1991 Camry that is running rich. I just replaced the O2 sensor and a new cat, oil change, new spark plugs. The car wont pass smog. it is ...
1992 Toyota Camry XLE V6 Excessive Running Rich ...
? 0:21
https://www.youtube.com/watch?v=WPTCtLwr61g
Aug 16, 2013 - Uploaded by StreetSports1
1992 Toyota Camry XLE V6 Excessive Running Rich ... 1997Toyota Camry V6 forward Oxygen (O2) Sensors .
Jan 11, 2016 | Toyota Cars & Trucks
I have a 4.9l engine surges at idle running way to rich and miss. at higher rpms .I changed fuel filter spark plugs . what can it be?
How do you know it is running rich? The computer controls fuel delivery. If it is running rich, one or more sensors may be giving the computer false readings resulting in a rich mixture. A leaking fuel pressure regulator internally will also cause a rich issue as well as a stuck open EGR valve. A scan test monitoring engine data can inform you of what may be the trouble
Dec 19, 2015 | Cars & Trucks
Feul running rich 2001 ford windstar
Running Rich or driven rich-- by pcm for a lean condition ?
Leaking Injectors--- rich
Failed O2 Sensors ---lean or rich
Vacuum Leaks--- lean driven rich
& more
Mar 02, 2013 | 2001 Ford Windstar
Poor acceleration and low gas mileage,smells rich at idle
You are off to a good start, MAF when it is contaminated it leans the vehicle out it doesnt make the car run rich, depending on the fuel strategy of the year make and model,and of course the engine size make all the difference,bad ignition coil make a car run rich shorted 02 sensor that lean bias make the car run rich, worn timing belt ****** timing and causes the car to run rich.so lets hear the results
Mar 24, 2012 | Cars & Trucks
I have the 305tpi and its running rich.the guy that owned it before i did eliminated the o2's...i'm just starting to put money ikt and i want to fix this running rich problem i have...what wou
well replace oxygen sensors that would cause engine to run rich if you remove or disconnect them oxygen sensor control fuel system it will cause engine run rich open loop mode on cold engine start ups as engine warms up it will go closed loop cause leaner fuel mixture.if you replace oxygen sensors could help rich fuel problem if not you could have intake manifold leak or faulty fuel pressure regulator.
Jan 24, 2012 | 1987 Chevrolet Camaro
1987 threequrter ton chevy 350 moter with quadura jet carb running rich an smokeing
either the float is sticking, when it is running use the back of a screwdriver and rap the bowl and see if this helps, or the jets need adjusted, start with the right one first, turn in untill the motor starts to lag then open it up untill the rpm stops climbing, do the same with the left one also, see if this helps. let me know.
Mar 13, 2011 | 1986 Chevrolet Chevy
Running rich its has new plugs the fuel press reg
MANY THINGS CAUSE RICH FUEL MIXTURE.FUEL INJECTORS.MASS AIR FLOW SENSOR AND BAD OXYGEN SENSOR.
May 24, 2010 | 1996 Nissan Maxima
Quadrajet running rich, how to ajust
Turn your idle mixture screws IN to make it less rich.
Check the float height it may also contribute to rich running.
Smaller jets.
Apr 02, 2010 | 1983 Chevrolet K1500
Running rich, smelling rich
You may have a bad fuel injector or in need of a tune up badly. The early fuel injection (throttle body) had a single fuel injector that would clog and not spray fuel in a mist but would dump fuel. Does it run rough at idle? That is a good indicator. Some are rebuildable but I would suggest replacement. If you have not had a tune up in a while that should be done too.
Jan 24, 2010 | 1994 Pontiac Grand Prix
98 talon running very rich!!
the egr could be the problem if its not working correctly,,,
Feb 27, 2009 | 1995 Eagle Talon
Holley 0 80552 650 Cfm Four Barrel Carburetor Logo
352 people viewed this question
Top Holley Boating Experts
Vernon Taylor
Mike
mike simpson
Are you a Holley Boating Expert? Answer questions, earn points and help others
