Question about Logitech Webcam
Whenever I plug in my Logitech Webcam my computer says "USB device not recognized". How do I fix this?
sandrew
  • 2961 Answers
SOURCE: usb extention lead doesn't work with webcam
So you know the cam is ok and the cable, so you will have to point to the usb port not being able to push enough power through the cable to the camera as it must take a higher voltage than the other cam. Make sure that the other cam software is uninstalled and you have done registry clean in case of conflicts and also try using a different usb port but install the camera with the driver again using the extension in it, aplogies if you did, i am assuming you may have installed the camera directly without the extension cable.
Posted on Apr 30, 2007
ziraffa
  • 827 Answers
SOURCE: webcam causing windows to shut down
I think this a problem with a USB driver. I had a similar problem once with a USB mouse and keyboard, when running XP. I never isolated the reasons for it happening, but I uninstalled the USB drivers for both and reinstalled them and rebooted and the problem disappeared.
Maybe try uninstalling the Logitech driver and then doing a Registry Clean (and a Clean System) with nCleaner and then downloading the latest zipfile for your webcam model from the Logitech support webpage.
Then plug the webcam in. It will detect and try to look for drivers but not be able to find any.
Now unzip the driver to a folder. Go to Control panel > System > Device Manager, and look for the Unknown Device with a yellow exclamation mark next to it. Double click it to open the driver window and then click the Driver tab. Press Install Driver and choose the 'Browse Computer for Driver' type option and navigate to the folder you unzipped the driver to, select it and open it.
It will Install and then you should reboot.
The problem should be solved, unless some IRQ conflict still happens, in which case you should do a Scan for Errors with an operating system disk.
SO, to sum up, when in doubt, uninstall the driver, clean the registry,reinstall the latest driver, reboot!
Hope that helps
Chris (ziraffa)
Posted on Jan 11, 2009
romsky79
  • 822 Answers
SOURCE: Computer does not recognize logitech quickcam chat
the memory chip of your logitech is defective. it damage by the current. change it.
Posted on Jun 04, 2009
JulesPCaut
  • 702 Answers
SOURCE: Lose webcam connection in Skype when using a headset
Have you checked the recording settings in Windows and in Skype? Try changing the default recording device to specifically indicate the device that has your headset plugged. I think the webcam also has a mic and that should not be selected.
Other thing to check is if there is some kind of resource conflict between your USB controller and audio card (use Device Manager).
Jules
Posted on Jun 22, 2009
  • 89 Answers
SOURCE: just bought logitech pro9000 & cannot get the webcam to work...
Depending on your windows operating systems of you might need to go to their web site and download driver to run your device both drivers are under the support section I have the link for the software you need to download to make you can run the unrecognized message means that your computer does not have the proper drivers to run the device here is the URL all you have to do select your operating system http://www.logitech.com/index.cfm/435/3056&cl=us,en?WT.ac=sc|downloads||dd a quick tip if 32 bit download doesn't work or your computer doesn't understand the file try the 64 bit
Posted on Jul 28, 2009
How to to instal logitech webcam
Logitech webcam usually comes with a CD to install software and drivers. If you are using windows 7 your computer should recognize Logitech Webcam when you connect it to your computer's USB port! Its necessary to have internet connection for your computer and Logitech webcam is just plug and play that means!
Just connect the webcam to your computer and remaining is done automatically!
Also drivers for logitech webcam are available online at their site www.logitech.com
good luck!
Sep 11, 2011 | Logitech Computers & Internet
Tip
How To Fix Usb Device Not Recognized in Windows
Sometimes, when you plug a USB device to your computer you may receive a Usb Device not recognized or usb port not working pop up message. If your USB device is not detected, then we will show you how you can troubleshoot usb not recognized error.
Follow Quick Steps To Resolve Usb Not Recognized Error Windows:
Press "Windows" + "R",a run window will open
In the "Open" box of the run window type "devmgmt.msc" and press "Enter"
This will open theDevice manager
Click on the arrow besides "Universal Serial Bus controllers"
Right click on each USB port and then click on "Uninstall"
Restart your computer and wait for Windows to re-installs USB controllers.
Try to connect yourUSB deviceagain.
How To Fix Usb Device Not Recognized In Windows 7 8 1
on Jan 28, 2015 | Computers & Internet
I'll plug it in and it says "USB not recognized"
You have to check the model of the webcam and install the right driver for it.
Does it come with a cd driver? You have to install that and then restart your computer for the webcam to work.
Mar 06, 2011 | Logitech Webcam
I purchased a Logitech Orbit AF webcam and i am trying to install the software. But when it prompts me to plug the webcam into a USB port, i do that and the software does not proceed. Even though my...
try this...
go to control panel/system security/device manager device mager/ scan device if you see a driver yellow icon like this(?) click it camera and update driver online. step by step. automatic run online...
rate 4thumbs up please...
Feb 05, 2011 | Logitech Webcam
I have a Kingston Data Traveler 8GB USB Flash Drive which I bought 4weeks ago. Whenever I plug it in one of my usb ports, i get a message which says "USB Device Not Recognized. One of the USB Devices...
The thumb drive might have some fault.
Plug it in other OS mainly windows XP and Linux.
If still same problem persists after tried in Linux, problem is with pen drive.
You can ask for a replacement from the dealer as it has guarantee for 5years.
Nov 30, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
USB not recognized
You need to have the LWS 1.1 driver loaded. You can get it directly from the Logitech web site on this link. After loading it reboot your computer, plug in the 3500, and then try the free webcam test site to verify it is working properly.
Jun 27, 2010 | Logitech QuickCam Communicate STX Personal...
Jules
Mar 02, 2009 | Logitech Quickcam Chat Webcam
It seems that the camera has died and is probably the USB plug at fault. If your a computer savy, you can try to replace the USB plug and re solder the connections together. If off warranty, it is much more efficient to buy a new one.
Nov 19, 2007 | Logitech QuickCam Communicate STX Personal...
Logitech camera plugged in but still can't recognise device.It always says device not pluged in.
please, note if the USB drivers for logitech were installed when the rest of software was. only as that the motherboard will recognize the webcam.
in the logitech's webcam cd, you'll see a chapter with only USB DRIVERS. if not, you can find them in www.driverguide.com.
it's free registration and easy to use site.
Oct 22, 2007 | Logitech QuickCam Pro 5000 Webcam
Logitech Webcam Logo
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
