Question about Ridgid 14653 14" Band Saw with leg stand
RUBBER ON BLADE WHEEL KEEPS COMING OFF ON RIDGED 14 IN BAND SAW
  • 7,733 Answers
Most common causes are:
1-Adjust the wheel
2-change the wheel rubber
Find out a great site at Look at eReplacementParts.com and the parts diagrams.
Posted on Nov 08, 2010
  • william swayze Nov 09, 2011
    try 3m weatherstrip cement make sure blade is tracking correctly
Band saw blade keeps coming off
Set up your band saw properly. There are several reason why band saw blade keeps on coming off on the wheels: loose/wear tire, improper guide adjustment, incorrect tension, over feeding wood stock or the problem could be on the blade itself. Try to change your blade, I got my band saw blades on sawblade.com . I suggest you watch band saw tune up tutorial videos on youtube. Hope that helps.
Aug 13, 2014 | Black & Decker Saws
What makes a delta 28-243F 14" band saw blade keep coming off?
The most common is wheel misaligment. The top wheel has an adjusting screw or the equivalent somewhere, and you can turn that to align the blade to the center of the wheels.
Second most common is guide problems. There are some guides that are supposed to hold the blade "just right" above and maybe below the table where you are cutting These must be set to support the blade in it's correct position as you are cutting through the material you are cutting.
3rd problem is a saw blade that has lost it's tension from being
" worn out ".
Be blessed.
May 20, 2014 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
Delta 28-160 band saw 3 wheel, blade keeps coming off
Sounds like your tracking screw needs adjustment, located right beside the knob used for tightening after adjusting the tension on the blade. Allen wrench required. Turning right pushes out and turning left pulls it in. A little is a lot when adjusting this screw. Always turn the blade in the same direction as the cut while adjusting.
Nov 27, 2012 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
Bandsaw blades keep popping off,could it be heat related?
Blades slip off the wheels on these saws is because one or both wheels are not turning true to the blade. This can be caused by:
- Missing or worn tires on the wheels. The rubber tires have to be on the wheels and they have to be in good condition.
- Occasionally the screws holding the sprocket on the driven wheel come loose and the wheel will wobble causing the blade to come off.
- Both wheels ride on bearings and shafts that, if seized, worn or broken, will let the wheel wobble enough that the blade won't stay on.
- If the blade is stretched or twisted from use it won't stay on very well.
Aug 06, 2012 | Dewalt DWM120 Heavy Duty Variable Speed...
Tire comes off top wheel almost all the time. Tire comes off bottem wheel sometimes. Don't know how to set up this saw.
My jet bandsaw did same thing only fix was new tires .Tires are supposed to be tite on wheel .get wood dowels between tire and wheel and roll new tire onto wheel. If desperate could glue on with weather strip adhesive.put bandsaw blade on both tires spin wheels with power off till blade is running in center of wheel by adjusting top wheel in or out. When done adjust blade guides to blade and bearings to back of blade .This is top and bottom of cutting area
Jan 16, 2011 | Delta Woodworking Delta Rockwell 14 Inch...
How do you keep the blade on the wheel? Mine keeps coming off. It is a Rockwell product. The blade came off while I was using it and I can put it back on both wheels but as soon as I turn it on, the...
Sounds like it could be quite a few different things. My suggestion is to go to you tube and look at Band Saw setup. I haved viewed the one from the wood whisper and it covers set up in detail, there are also other videos that may help.
Sounds like a setup problem - wheels,tires,guides,and even blade tension can cause this.
Does the blade track true when turning top wheel by hand?(unplugged of course)
Is the blade tension correct?
Are the tires in good shape?
Are the guides and back up bearings set correctly?
I hope this will get you headed in the right direction.
Nov 14, 2010 | Delta Rockwelldelta 14" Hinged Wood Band...
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
8 inch delta band saw that cant keep the band in place in use
The rubber bands on the metal wheels are called tires, and if they are cracked, they may very well be crowned and causing the problem with the band coming off.
To test, remove the back guide (as opposed to the side guides) on the top and bottom guide sets (above and below the table.). Put a blade on, and see if it will stay on. If it doesn't, replace the tires. If it does, reinstall the back guides and make sure they do not touch the back of the blade when the saw is running. There should by about 1/32" between the guide and the blade.
Dec 11, 2009 | Saws
Rubber bands pop off of wheels
My Delta 14" had the same problem. My fix was to get new rubbers, took care of my issue. They do stretch, but the newer the rubbers are the more the will retain there form, the older they are, not so much.
anaanymous
Oct 10, 2008 | Ridgid 14" Band Saw with Stand
Ridgid 14653 14" Band Saw with leg stand Logo
204 people viewed this question
Top Ridgid Saws Experts
John Trevino
Jim Thurston
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
