How do I fix my screen back to normal? My child did something now the entire screen when turned on is sideways. Help....I can't tilt my head and work on the computer at the same time.
  • joecoolvette
    joecoolvette Nov 08, 2010
    Or just hold down the CTRL and ALT keys, and tap the UP arrow key. Keep tapping until the screen is back to vertical.
    Champion:
  • 331 Answers
Hi There.
Sounds like a up coming little computer guru ! I am going to base my answer on the Intel graphics driver because (there are many) and non was specified. You may feel free to ask for further clarification and I will do my best to answer.
The Intel drivers have a feature allowing rotation. Typically, it's really easy to bump the button to change this. I have not figured out the keycombination yet though.
Right Click on your desktop: You should see a menu of choices. Look specifically for:
1) Graphics Options
2) This will have a little > that points t "Rotation"
When you see rotation; you will need to move it "90 deg" either to the right or left; to set the screen back to normal.
Hope this helps. If it does; please leave positive feedback , I appriciate it.
Posted on Nov 07, 2010
Screen has switched sideways how do l get it back to normal?
Hi Barbara, The link below is a YouTube video showing how to fix sideways screen, Also there's videos down the right side of the link that may help as well.......... CHEERS..
An LG Voyager freezes and then the screen flips UPSIDE DOWN
May 10, 2016 | LG Cell Phones
Briggs & stratton 500 series 158cc. Mowed all lawns, and worked just fine. Then (because it was such a jungle in my yard) I accidentally hit a decent sized piece of cement, but mower worked still after...
When you got it running immediately after the hit on the cement was it running normally? Similar power to before, or a bit rough?
Briggs & Stratton put an aluminium key between the flywheel and the crankshaft, so if you hit something big and stop the engine instantly it doesn't shear the shaft, just the key.
If it's only partially shorn it could still run, but with the timing a few degrees out.
The oil leak is most likely from tipping the motor forward.
The oil gets past the valves and pours into the combustion chamber.
We were told in the small engine workshop to never tilt a B&S side valve motor any way up than cylinder head up (that's the front, or spark plug side on this machine), or carburettor side up.
You'll need to either check/replace the key yourself if you have the skills to remove the flywheel, then you'll need to take out the spark plug (probably oiled up) and clean out the cylinder with some petrol / ether or similar, while pulling the pull start, before replacing the plug with a new one.
May 23, 2014 | Garden
My screen on the elitebook is turn sideways how can i fix it back to normal.
On your keyboard, press CTRL-ALT and the Up arrow key at the same time. If up didn't work,, use the down arrow key.
hope that helps..
Sep 15, 2010 | Computers & Internet
The display has turned sideways so i have to tilt my head to view the screen, any help in returning it>?
hehe, this used to be something naughty male techs did to female techs in the course to show superiority.
It is possible to rotate the whole desktop even upside down Right clicking on desktop ( box appears) select Graphics Options and Rotate to the degree that puts it all back the right way. Enjoy!
please rate my help++++Thanks for using FIXYA
Jun 22, 2010 | Dell Studio 1537 Notebook
Screen turned sideways
Hi there. Your daughter mus have press on something on the keyboard. Inorder to get the screen back to normal . Try to press and hold the crtl + alt + uparrow key at the same time. This will take your screen back to normal position.
May 31, 2010 | Dell XPS M1210 Notebook
The entire screen is sideways
it is an option to have your screen side ways so if you want you can rotate your monitor and it is easy to change back. to fix it all you need to do is right click on your desktop and chose properties and then go into screen settings and it will be an option as to which way your screen is displayed I would go into further detail for you but these settings are in a different place in almost every system. if you have trouble finding theses setting please message back with more details about your systems and I can try to assist you more.
I hope this helped.
Thank you,
Norse
May 16, 2010 | Computers & Internet
Screen on Dell Inspiron 6000 turned sideways. How
Power off the laptop.
Power it on and tap F2 at the Dell logo. check if the screen is sidways in the BIOS or not. If it looks normal in the BIOS restart the computer and go to control panel and uninstall the Video drivers. Restart the computer. It will boot up with basic drivers. Install the video drivers and the issue should be fixed.
If the display is side ways even in the BIOS try a BIOS update from support.dell.com and if you dont have an update reflash the BIOS with teh version availbale on the website.
Jun 18, 2009 | Dell Latitude D600 Notebook
My Fisher Price Precious Planet Swing tilts to the side.
the seat itself should rotate around even though the bar is in front to back the seat can be in forward or sideways position
Apr 07, 2009 | Baby Gear
Monitor screen displays sideways
if the screen is rotated then press
ctrl + alt + up arrow
your screen will be placed correctly
this is happened because sometime you might have pressed by mistake ctrl + alt + some arrow key .....
the hot key will be enabled defaultly so your screen got rotated
Jul 05, 2008 | Gateway FPD1950
Monitor screen went sideways
Try the ALT key and the Up Arrow.
If that does not work, try CRT ALT UP and DOWN arrows till you can rotate your display.
Jan 29, 2008 | Computers & Internet
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
