Hi, i just plugged in my macbook air for the first time into my HDMI port on my TV and the picture on the TV screen will only show the background of the PC and nothing else...what do I have to do to see the whole desktop?
  • 2 more comments
  • brad_melissa Nov 07, 2010
    I have done what you said and it will only display the background for the PC desktop, but nothing else??? what do I do? There must be a setting somewhere?? or something??
    When I plugged in my PC to my flatscreen TV for the first time using proper HDMI plug in, the TV will only show the background of the PC and not the rest of the desktop icons...what do I need to do?
  • brad_melissa Nov 08, 2010
    yes, the application Im trying to use is streaming video throught the internet
    it is not just the browser, all the icons dont show up, but the background does
  • 4,889 Answers
It depends on what application you are trying to use. Most applications have the option to display whatever you want to watch on an external display. So if you can get me the application you are trying to use, then I can tell how to resolve this issue.
Sai.
Posted on Nov 08, 2010
  • eagle338
    eagle338 Nov 08, 2010
    If its just the browser then you should just duplicate the image. I believe you are just extending the image. To activate mirroring, go to display preferences->Arrangement and check the box at the lower left corner that says "Mirror displays". You will also see some options to customize what the screen will look like. Note that this will resolve the problems with nearly all the apps.
  • 10,865 Answers
Hello Brad. For your MacBook video you will need EITHER the MiniDVI-VGA adapter, the MiniDVI-Video adapter, or the MiniDVI-DVI adapter. It depends on the input connector of your TV.
For the audio, a 1/8th inch phono (from the headphone jack) to L-R RCA plugs (to the TV's audio in) is generally what you need for simplest connection.
You need a DVI to VGA adapter like this (it should've come with your macbook):
http://www.sfsu.edu/~avitv/images/apple%...
Then you need a VGA male to male cable like this:
http://www.ultraproducts.com/images/skui...
Once you have those two things, you plug the adapter into your macbook, then plug one end of the cable into the adapter, and the other end into the PC Input of the TV.
Posted on Nov 07, 2010
How do you make a disk of pictures whiling playing music
Beth
You didn't specify what OS you are using.
If it's OSX then it's easy using iTunes & iPhoto to select a group of photos and background music.
My slide show on my MacBook gets transferred to the Apple TV automatically and shows up on my Plasma 50" Screen.
Cheers
Feb 17, 2015 | Computers & Internet
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
How do i connect my laptop to my dynex tv?
This depends on your hardware. If you have HDMI port on your laptop and on your TV it is the best and easyest option for your case. Just plug-in the hdmi cable, go to your computer Control Panel->Display and configure the second monitor as extended. Your TV must be monitor number 2 and you should use recommended settings for the picture resolution.
From your TV go to input source list and select the HDMI port.
Now you should see your desktop background without the taskbar and icons. So you can drag and drop the application you want to see on your Dynex TV(secondary monitor) and that's it. This method will bring video and audio just with one cable. Of course you can use VGA port on the Tv, but the quality of the picture will drop and you must have separate cable for the sound.
May 28, 2012 | HP Computers & Internet
I want connect HDMI cable my laptop model No 4736Z, pl tell me process?
To connect an HDMI cable to your laptop, find the HDMI port on your computer. Take your HDMI cord, and plug it in. Then plug the other side into a TV. The laptop should automatically duplicate the screen onto the TV. If the video does not automatically duplicate, right click on your desktop background, and select "screen resolution." Select the second display, and set the Multiple display option to duplicate these displays.. If your audio is not coming through, right click on your volume control, and select "Playback Devices." Then set your HDMI as the default playback device.
Bare in mind that these instructions are specific for a Windows 7 laptop that has an HDMI port.
May 02, 2011 | Computers & Internet
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
Macbook Pro DVI---> HDMI + Digital Optical Out = Problem w/ Sound
On the Sony The HDMI takes "priority" over all others, that's why you loose audio. If you run your DVI/HDMI to the TV and optical to the soundbar that would fix your issue. If your TV does not have Multiple HDMI inputs, you can get a DVI/Component adapter for your MBP then run it to the TV, or, If you have to have HDMI just to have HDMI, you can get a 2:1 HDMI switch and still have optical to your soundbar. Make sense? If youneed more help, just post a comment and I'll help some more.
Jun 23, 2009 | Sony HT-CT100 Theater System
No video with HDMI port
try 2 things, first use the rgb cables or video (yellow) cable and plug it into the tv using one of the imports..(vid 1,2,3 etc...) and see if that works. then check to see if you get a picture by not using the cable box, by pass it and connect it connect it in the uhv channel. also make sure you have it on the right input of the tv (meaning scroll through the input button on your remote to find the picture...i've done this a million times). still no picture try your dvd player input and if you have a vhs input see if that works. if it is the hdmi input...to be honest it's expensive and a pain to replace...
Feb 10, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Using a Sony Bravia HDTV as a monitor for a Macbook Air
Hey RHSully,
In addition to connecting your Macbook to the TV, you may also need to adjust the video output signal coming from the computer itself. Several of the TV's in Sony's Bravia model line should include a list of the optimal settings for each screen resolution within the owner's manual, but you may need to search through Sony's online support site if you can't find this list for your specific model.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 18, 2008 | Televison & Video
When The HDMI cables are connected, I use Directv, I have just recently started to have the picture come on and then start flickering and various color bars pop up on screen, then the screen will go black...
It is possible that the HDMI cable is defective. Did you try another cable?
It is also possible that the HDMI port on the TV is failing.
This can be determined by the process of elimination.
Jerry G.
Jun 06, 2008 | JVC Televison & Video
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
