Question about Zoom X6 (5590) DSL Modem (55900003)
Zoom X6 installation
I'm trying to install a Zoom X6 (5590) router to my desktop to enable me to log onto the internet on my laptop but I'm confused!
My adsl modem has a usb connection into my PC but requires a different type of connection to plug into the router!? Also when I connect the ethernet cable from my pc to the router the ethernet light doesn't come on. What a I doing wrong??!!
Hi i am trying to go in zoom x6 page and put the password for my internet coz we use share broad band. thanks
Posted on Oct 18, 2008
    Genius:
  • 1,605 Answers
You need a ethernet network card, if you want it connected to the x6 directly, or you can get a wireless card for the desktop.
the instruction for setup the x6 is straight forward. but you need to follow it to the letter, otherwise it won't work.
if you need more information please email me at frcs68@hotmail.com
please rate if the answer solved your porblem.
thank you
Posted on Oct 16, 2008
Is the Zoom ADSL X6 modem router supposed to provide connectivity for a 3G Kindle? If so, how do I set things up?
Zoom X6 routers don't work with either Kindles or Nooks- it seems the connect on demand to save power confuses the Zoom router - typically requiring the unpractical fix of rebooting the router every two minutes.
Feb 03, 2011 | Zoom X6 Adsl Modem/router Rohs...
How to modify ethernet intf ifname eth-0
Hi
Please do the following
1) Log onto router
2) Go into enable mode
3) Type in conf t
4) Type fa0 (or what ever the interfaces is)
5)Tyoe in description ************** (* = description name)
6) Type end
7) Type save run start
All done
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | Zoom X6 (5590) DSL Modem (55900003)
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example: 192.168.1.xxx
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Feb 04, 2010 | Zoom X6 Adsl Modem/router Rohs...
I Have zoom adsl x6 and it disconnects after a couple of minutes.
You got to check for some kind of interference in your area.
Maybe a cordless phone, etc...
You can try changing the channel your wireless router is using.
To do that, you must log in into the Main Menu inside the wireless router itself.
For instructions, look in the manual.
Please don't forget to rate if this answer helps
Jun 28, 2009 | Zoom X6 (5590) DSL Modem (55900003)
Signal showing but no connection (zoom 5590 x6)
Hi……there could be a number of reasons why you can’t connect. I’m assuming you have rebooted both laptop and router to see if this helps, so let’s move on to some basic troubleshooting steps to start with:
  1. Can you pick up the internet through a wired (Ethernet) connection between the laptop and the router? If so, this narrows the problem down to your wireless connection.
  2. Can you login to your router again, and check to see if MAC filtering has been enabled. To find this, go to Advanced Setup > MAC filtering. If the status is ‘enabled’, disable it, Save changes, and try to connect wirelessly again
  3. If MAC filtering is off, and you still can’t connect, go to ‘View Wireless Networks’ on your laptop: disconnect from your network, wait 30 seconds, and reconnect. When prompted, re-enter your network key very carefully. Can you connect now?
If you still can’t connect, please come back to Fixya, and let me/us know the operating system on your laptop. Good luck…
Jan 17, 2009 | Zoom (5590-00-03) Wireless Router (G66115)
Zoom x6 model 5590 wireless router
Make sure the Connection Type is set to Static IP on the setup page of the router
Mar 10, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
ADSL X6
presuming that the router moved with you the telephone line socket could be too far away from the BT socket or is not correctly wired. if you have not moved the router then you need to buy a booster
Feb 18, 2008 | Zoom X6 Adsl Modem/router Rohs...
Need Zoom X6 help unresponsive
make sure your ethernet port is set to 'obtain address' and 'DNS' automatically (IE use DCHP and not static IP address) The software should be able to 'find' the zoom modem then.
Jan 22, 2008 | Zoom X6 Adsl Modem/router Rohs...
Zoom X6 wireless router
Hi, With or without the firmware update, the wireless should work and be indicated with the WLAN led. Have you done an update? Have you tried a hard reset? Most routers would require a reset to default after a firmware update. Pls be reminded that when you do a hard reset, all configuration would be lost, better log them down or do a backup. Alternately, you can check your router's web based configuration manager, apparently, there is an enable/disable feature/selection for the WLAN. Verify that is set to enable. Hope this be of help/idea. Post back how things turned out or should you need additional information. Good luck and kind regards.
Oct 02, 2007 | Zoom (5590-00-03) Wireless Router (G66115)
Difficulty in first time support with zoomX6 5590
Hi Maybe i could help you. I have installed this modem before for an ISP provider. Please give me specific task you want to do and I will explain what to do.
Apr 30, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Zoom X6 (5590) DSL Modem (55900003) Logo
400 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
