Question about Dryers
I'm still having the problem with the heat Some times the dryer heats for a minute and sometimes for 3 seconds, i replaced the coils and the hi-limit thermostat .I hear this clicking so i know the ignitor works I heard there is a flame senson with the ignitoe is that true? My model is SDG3036AWW and could this br the problem? How long should the heat stay on for when the dryer first comes on? -John
  • 1 more comment
  • John Dieff Nov 07, 2010
    the gas comes on but it doesen't stay on some times it will stay on for 30 or 40 seconds and some times when it first starts it will stay on gor 2 or 3 seconds
  • John Dieff Nov 08, 2010
    made a number of test and can't find my problem .The problem is i don'd know what the readings on the different coils and fuses should be ijumped out the thermal fuse i get good reading on the high limit thermostst so i down to ignitor .the gas valve or the flame sensor hoe do know for certain which is at fault Thank You -John\r\nIt's a Maytag SDG3606A
  • John Dieff Nov 10, 2010
    problem solved Thank You very much
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. check out this gas no heat tip.... You did not mention the ignitor... and it can also be the cause of problems... I would change it and see what happens...
BTW... did you change the operating t-stat??? It also could be the problem...
heatman101
Posted on Nov 07, 2010
    Top Expert:
  • Dryers Master
  • 76,691 Answers
The most common cause of this is a defective gas valve, more than likely it is sticking or the thermal sensor that signals the valve to turn on is defective, the sensor is part of the gas valve so the valve must be replaced when this problem occurs, as far as the model number goes that will not provide the make of the dryer, so always provide the make and the model number.
Posted on Nov 08, 2010
    President:
  • 1,891 Answers
The heat should stay on untill the drum tempt or the exhaust tempt reaches 155 deg. then the themo will cycle and shut off the burner . your problem i think is air flow . take the vent off the dryer and feel for good air flow . if air flow is good then i belive the fan is working ok and if heat stays on then the problem is the vent and the dryer is okk ..mm feed back pls .
  • dennis dodge Nov 11, 2010
    no need to send model # i see you posted it in the beginning . / other thing that may cause air flow problem is the drum felts both or them if in poor cond then air flow will not be over the heater .. and cause it to shut down . when dryer is heating the flame should not be touching the metal heat tunnel and should be very blue and verry little yellow . and if flame is short and toughing top of tunnel then we have a air flow problem . and the hi limit is shutting it down. ck theses and get back to me . mm
Admiral Dryer Model #AGD4475TQ No Heat
This is very rare on a gas dryer but I have seen it. If you have already replaced all that other stuff I would say it has to be inside the timer. On one I worked on once I could remove that orange wire and the dryer would function ok so I ordered a new timer, they sent me a bad timer. Same problem. I finally got a working timer after going through a bunch of mess. That fixed it. So if all the other components are working it very well could be the timer.
Dec 02, 2013 | Admiral Dryers
I have a gas dryer, model MDG7657AWW that will not stay heated. Every time I put it on, the flame comes on for about 21 seconds & then shuts off. I replaced the igniter, hi limit thermostat, cycling t
On a gas dryer the heat normally only comes on for 30 seconds or until the drum temp reaches 160f at which time the flame is shut down by the cycling thermostat. The drum temp then starts to drop. When the drum temp reaches 105f then another blast of heat is issued for 30 more seconds.That is how they work. Put it all back together and trow a load in there.
Oct 28, 2011 | Dryers
I'm still having the problem with the heat Some times the dryer heats for a minute and sometimes for 3 seconds, i replaced the coils and the hi-limit thermostat .I hear this clicking so i know the ignitor...
The previous problem is addressed by replacing the high-limit thermostat according to your last post. The igniter is definitely working since the gas is being ignited.
Yes there's a flame sensor along with the igniter on the burner cone and it must be not working properly. The cycling thermostat is good as per previous troubleshooting, the high-limit thermostat has been replaced, and the igniter is good. These findings and observations suggest that the flame sensor is not working properly. It is either dislodged from its proper position and cannot sense properly the heat from the flame and the igniter or it is faulty and needs to be replaced.
Check that the flame sensor is aligned properly with the slot on the burner cone. Replace the sensor if it is aligned properly. The sensor looks like this.
Nov 11, 2010 | Dryers
The dryer runs but no heat. The igniter glows when you start the dryer for about 10-20 seconds then goes out but the gas never ignites. I have tried bypassing the high limit fuse in the vent and have...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 11, 2010 | Roper RGX4634KQ Gas Dryer
Dryer burner just stopped working. the motor turns but no heat. It also will not start on timed heat.
HI, i recommend inspecting all areas stated below to address this issue. the most common problem will be a set of defective gas valve coils but, i suggest checking all points before replacing the coils.
1. Gas valve coils
igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. igniter
igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
No heat burner comes on for a few minutes and then goes out
Check the following to address this issue.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
2. Thermal fuse
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Jun 02, 2009 | Kenmore 72062 Gas Dryer
No heat after a minute of drying
Normal 0 Hi, You need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers.
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post thecoils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
May 30, 2009 | Dryers
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Dryers Logo
59 people viewed this question
Top Dryers Experts
