Question about Sony VAIO PCG-GRT360ZG Notebook
Hpw to remove bios battery sony pcg-grt360 - Sony VAIO PCG-GRT360ZG Notebook
  • 4 more comments
  • anves Nov 08, 2010
    I can not access the bios, because of a password, I never added a PW - I need to allow the LT to install XP from external drive
    I have a sony pcg-grt360 laptop, and I need to install XP from external cd-rom - I can not get into the bios to make the changes to select boot sequence - I need to remove the existing password
    Will this reset the bios password, this is the actual problem, I am denied access
    I need to get the bios password to reset to nothing
  • 942 Answers
To remove it, turn off the laptop, remove the cables and battery on it, Remove the hard drive by unscrewing the screws in laptop corners. Then remove the optical drive by removing also the screws. Then remove the fan and also remove the keyboard. Once you see the motherboard, push the side of the CMOS circle battery to lift it up and that is how you remove it.
Posted on Nov 08, 2010
    Genius:
  • 1,035 Answers
Hi. I provided you a link on how to replace the cmos battery for Sony Vaio laptop . Please click here.
  • 656 Answers
The battery in several sony's I've had to service is under the speaker/power switch section above the keyboard. You will see a screw, possibly next to the memory card slot, top left side. Unscrew the single screw, and CAREFULLY slide the top piece over then lift up to remove...but be CAREFUL because there are 2 flat ribbon cables attached to connect the piece to the motherboard. On 3 different sony systems the battery has been under this section. They are ridiculously expensive, so look for a generic replacement or be prepared to fork out at least $25 for a tiny battery or more!.
  • rajesh raman
    rajesh raman Nov 08, 2010
    yea sure this is the only way to reset the bios password
  • rajesh raman
    rajesh raman Nov 09, 2010
    hai this only was to reset bios ether remve the cmos battery it can also reset the system
  • Sony Master
  • 13,433 Answers
Please tell me why are you trying to remove the battery?
- it will not remove a password, it may bring up a security password and you can no longer use the laptop.
  • Ekse Nov 08, 2010
    Even if you get to the battery and remove it, its more than likely it wont remove the password.
    Please get in touch with sony for repair and support
    http://esupport.sony.com/US/perl/contact...
    We had a similar problem last year after the battery was removed the machine started asking for a password the instant it was turned on so it made the problem worse, we did get that solved by performing emergency bios recovery on that laptop, but thats really something that we can't do over the internet for you. Sonys going to solve this problem for you, contact them.
    Not for free I don't think so.
RESET BIOS PASSWORD
To reset the Bios password try removing the laptop battery unplug the power supply and hold down the power on button for 30 seconds, if this does not work remove the bios battery for 1 minute
Apr 15, 2014 | Sony Vaio PCG V505BXP Laptop Universal AC...
I want to clear CMOS
The CMOS is a block of static RAM that will lose its data if power is removed.
most newer laptops are using a small block of Flash RAM (perhaps a block of addresses within the Flash BIOS chip itself) or other type of EEPROM chip to store the password.
No amount of removing batteries and pressing power buttons will change it
http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCG-3E2L
you might get some more information from the manual
hope this helps
Jul 24, 2012 | Sony VAIO Notebook
I need passward sony vaio bios pcg-3c6p
Reset your bios battery by removing it for a minute than put it back and restart your computer again.
Apr 16, 2012 | Computers & Internet
HAVE TRIED CHANGE THE CMOS BATTEWHAT CAN I DO NXTRY TO REMOVE BIOS PASSWORD BUT IT COUDNT WORK,?
Sony Vaio PCG and some Vaio VGN Series use the last 7 digits of the laptop serial number to calculate the bios master password. The serial number for a Sony Vaio is often located on the bottom of the laptop on a white sticker. The serial number may also be found by removing the battery and checking in the battery compartment. The link to unlockbiosrecovery.com below works on the following models:
PCG-C, PCG-F, PCG-GR, PCG-GRS, PCG-GRT, PCG-GRV, PCG-GRX, PCG-GRZ, PCG-N, PCG-NV205, PCG-QR, PCG-R, PCG-SR, PCG-SRX, PCG-TR, PCG-V, PCG-VX, PCG-X, PCG-Z, VGN-B, VGN-FS, VGN-S, VGN-T, VGN-TX1, VGN-X
I use http://www.unlockbiosrecovery.com/Unlock_Sony_Bios.php
For $20 they use the last 7 digits of the laptop serial number to calculate the bios master password and then email it to you in an hour. They guarantee it to work and you can call them if you have a question.
Sep 10, 2011 | Sony VAIO VGN-FS640W Notebook
Y need bios password for SONY VAIO PCG-983M .Please help.
There is no generic BIOS password. If there is one on your computer then someone set it up. If you cannot find that person or remember what it is then you need to reset the BIOS. To reset the BIOS you need to remove all power from the system. Then you will need to open up the notebook to get access to the motherboard to find the BIOS battery which will look like a large watch battery. Remove that for about 1 minute. Then replace everything and start up again.
Jul 03, 2011 | Sony VAIO PCG-GRT290 (PCGGRT290ZP28) PC...
NEED TO CLEAR BIOS PASSWORD
Hi
BIOS passwords can be reset in two ways,
1. using software 2. using hardware.
I would first try resetting using software, here are two software's to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
CmosPwd - Cmos password recovery tools
Please let us know if it works
May 12, 2011 | Sony Vaio PCG-7F1L PCG-8A1R PCG-8C3L...
Unfortunately this laptop uses the restrictive style of BIOS password. Meaning if you can remove the cmos battery there is a good chance it will not forget the password.
Unfortunately the only way to truly clear it is to replace the whole motherboard which is a nightmare, especially with an older machine like this.
Are you sure there is no way you can get the BIOS password / remember it? I assume that is what is going on, correct?
Please let me know, just reply to my answer here...
Thanks
Tim
Nov 08, 2010 | Sony VAIO PCG-GRT360ZG Notebook
Sony Vaio PCG-6L7P unable to boot. Unable to load
HARDWARE PROBLEM, TRY TO RESET THE BIOS OR REMOVE THE REMOVABLE DISK CD/DVD ROOM, THEN USE EXTERNAL
Jun 26, 2009 | Sony Computers & Internet
I need to flush my bios.forgot password. Sony vaio pcg-7g1m
Try This:
Reseat the CMOS battary:
How to Change/Reset a BIOS password Posted on 30 December 2008
Tags: Tech News, Tutorials If you are a normal computer user who has forgot his BIOS password and you are unable to access to your BIOS, then you need a simple way to change your BIOS. Its not that hard because you just need a simple trick to reset your BIOS password.
Open your CPU cabinet after switching OFF the power and then try to locate the CPU battery which can be found very easily. Once you locate your battery you need to remove it once and restart your PC without the battery.
cmos-battery-check.png Note : Once you remove your battery from the mother board, you will find that all your time settings in your computer would be lost, and some softwares may stop working which are based on your computer time.
You need to shut down your PC again and now add back the battery which will enable you the time saving feature and also reset your BIOS password.
Feb 22, 2009 | Sony VAIO VGN-AR230G Notebook
How to remove bios password for sony notebook pcg-n505ve
Remove the small round cmos battery from the motherboard for about 5 seconds, replace & reboot. Hope this helps & please remember to rate my answer. Thanks.
Dec 29, 2008 | Computers & Internet
Sony VAIO PCG-GRT360ZG Notebook Logo
257 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
