Question about Husqvarna Designer I
I can't find a button to turn on the light on my Designer 1
  • 201 Answers
There is no button to turn on the light. When the machine is turned on, the lights come on. If they are not working it means that one of the bulbs needs replacing. If one bulb blows, neither light works. The bulbs are readily available from auto spare parts shops. See page 110 of your manual for instructions on how to replace the bulb.
Posted on Nov 16, 2010
New designer I light doesn't work
The Designer 1 has 2 lights - one close to the needle and another in the throat of the machine. If either light is blown out, neither will work. You should be able to replace the lights yourself but getting it out of the machine can be frustrating. Instructions are included in the owner's manual. If you cannot find the owner's manual you can go to the Viking website at http://www.husqvarnaviking.com/us and click on the link 'Machine Updates' at the bottom of the page (right hand side). Then select All Machines, and then select Designer 1. You will be taken to a page that will allow you to download the Owner's Manual.
Mar 26, 2014 | Husqvarna Viking 1
.legge@hotmail.comMy designer 1 Touch Screen
Hi,Try this,switch off machine,press in reverse and pivot button together,switch on,release buttons and press up/down needle button,this brings up calibration screen.With a plastic stylus or something similar(not metal) touch in centre of each cross,they should turn green.Switch off and on again. This will calabate machine the screen.
Hope this helps
Mar 22, 2011 | Husqvarna Designer I
Hi Can u please tell me how to calibrate my Designer 1? Have not done it for a few years and now I've forgotten. Also my touch screen is only partially responding....I'm not getting any response...
Hi Vina, Since you can't get any response to your Menu-Norm-Prog-Rep-Set-or Help on your touch screen but you can get into your stitches, It does sound like you need to re-calibrate your touch screen. Normally you would get into your Set Menu to access your touch screen calibration. But as suggested on another solution. You turn off your Des 1, Holding in the reverse button (bottom left of the eight buttons) and the pivot button (the second one from the bottom of the four buttons) at the same time and turn on your machine. This is the Service menu that pops up (try not to touch anything on this screen, it could really mess things up if you don't know what you are doing) After this screen pops up go over to the eight buttons on the far left of your machine and touch the needle up, needle down button (top right button of the eight) the Calibration Screen will pop up on your touch screen (two plus marks labeled 1 & 2) In your sewing sitting position touch the center of the #1 mark and then the #2 mark. Once you've done that the Service Screen will pop back up. Shut off your Des 1 and restart it normally. Try getting into your different menus- Menu-Norm-Prog Etc. Hopefully that fixed your Calibration issue! ** Note: If the service menu doesn't pop up when trying to hold in these 2 buttons together and turning on your Des 1 the buttons weren't held in properly and you need to turn it off and try it again. Hopefully that helped you out!! Happy Sewing!! Kathy
Nov 24, 2010 | Husqvarna Designer I
My Designer 1 touch screen is not responding. I know how to calibrate it, but can't do even that until I can select the options on the screen. Is there a way to unlock it?
I have this information from a person who was a Husqvarna Designer expert:
When you just can't get to the menus at all:
Turn the machine off.
Then hold down the "Reverse" and "Pivot" buttons and power it back on.
You now have the setup screen.
Touch the "Needle Down" button and you will see the crosses.
Use a small blunt object like the metal end of the buttonhole foot (the stylus that
came with the machine would be better ) and
touch the centre of the crosses and each will turn green. Then click on
"save".
Oct 11, 2010 | Husqvarna Designer I
HOW TO CALIBRATE MY DESIGNER 1 SCREEN the screen is off if i touch program nothing happens and the arrows are off to the right side
Hi,Try this,switch off machine,press in reverse and pivot button together,switch on,release buttons and press up/down needle button,this brings up calibration screen.With a plastic stylus or something similar(not metal) touch in centre of each cross,they should turn green.Switch off and on again,and it should be fixed. Regards, Cathy.
Sep 15, 2010 | Husqvarna Designer I
Password For Viking Designer SE
actuall she/he means is after you hold down the back and pivot foot button and turn on the machine, it will pop up with a dialog asking for a password..
Jan 12, 2009 | Husqvarna Viking 1
Designer 1 reverse won't select, no light at all
The designer 1 has a weakness of the reverse pad (rubber button set) on left side of the machine wearing out and not working. You can try pushing from different angle, or pushing hard, but it most likely needs to be replaced. If you did buttonholes with the buttonhole sesor foot (foot with a wheel and a cord that plugs in), it would automatically size the buttonhole and you wouldn't need to reverse and you can use "FIX" to tie a knot instead of reverse
Dec 30, 2008 | Husqvarna Viking 1
Problems recalibrating Designer 1
switch on while holding in reverse & pivot buttons. release then press needle stop button. calibration marks will appear. set & restart.
Jun 27, 2008 | Husqvarna Designer I
Viking Designer 1 won't stitch correctly
Check that twin stitch width safety is not turned on in the SET menu (use More button at bottom of first screen to access third screen).
Jun 19, 2008 | Husqvarna Designer I
Sewing Machines Logo
242 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
MissFixIt828
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
