Question about Epson Stylus Pro 4800 InkJet Printer
Head clogs after changing cartridges
My cartridges were all very low so I changed them all and did a power cleaning because I had not do one in a long time and I don't use the printer very often. Now I am having clogging on cartridge 1-3. I have run a number of regular cleanings but the probem is not improving much. It is the lower bands on the test sheet that are missing. The partern is consistent with each nossle check.
Any ideas on what I can do besides more cleanings?
Thanks,
Chris
  • 33 Answers
Replace the damper
Posted on Jul 01, 2008
Why is my canon is printing blurred lines
If you're like me you don't use it everyday which means that the inkjet nozzles become clogged over time. If you use the menu panel on your Canon printer navigate to the MAINTENANCE menu and run all of the different cleaning cycles pertaining to the print head and nozzle. You may have to run them more than once unfortunately. Fortunately, the cleaning processes are quite good.
Are you getting 'low ink' warnings at all? If so, it's time to change the ink cartridge that is low. You can tell either by the on-screen message on your computer or if you lift up lid to access the ink cartridges. They will center themselves after about 10 seconds allowing you to change them. Low ones will be flashing red.
Let me know if you have any problems. Don't forget to rate my response. Good luck!
Aug 20, 2014 | Canon PIXMA MP190 All-In-One InkJet...
CP3525X printer will not print the black cartridge.
Your ink cartridge is low, empty or possibly clogged
First step is to see will if it print a test page
Go to Start, settings, printers. Right click on the printer, properties, print test page.
If that doesn't work there should be a head cleaning option in properties that will make it clean the print heads.
If there is still nothing after that then either it's badly clogged, low or out of ink, and needs to be replaced
This may help
Turn on the hot water until warm
Put about 1/2 inches of water in a cup
Put the print head portion (where the ink comes out) in for about a minute or two
This will help to dissolve the clogged print head
Dry off the cartridge using a soft tissue.
Re-insert the cartridge into the printer.
Run the normal cleaning software routine a few times
Still having Problem Then follow Us For
Brother Printer Support
Feb 21, 2014 | Brother HL 5250DN Laser Printer
Blank pages when printing ipf6300
A ink cartridge or cartridges maybe low, empty or possibly clogged
If the ink cartridge is still clogged, saturate a q-tip with alcohol
and lightly rub the print head
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :Printer Support
Feb 11, 2014 | Canon imagePROGRAF iPF6300 Large Format...
Black cartridge (HP21) will not print or prints faint 2mm strips (like a pedestrian crossing) of a broad black test piece on my HP Deskjet 2180 Desk. Colour (HP22) is OK. Cleaned cartridge manually per HP...
This type of cartridge has the printing head in them - the possibility that all 3 ones are clogged is extremely low. If you get a bad printing with them it's because the heads are incorrectly commanded - either the pin array that transfer the command is damaged and they will have to be cleaned and fixed or the processor of the printer is dead, and the printer with it.
Jul 09, 2011 | Office Equipment & Supplies
My hp color laserjet 5550 is not printing cyan i have replace cartrige and power supply board but nothing changes
It sounds like the print head is clogged. Try doing a Head CLEAN. If you don't use the printer at least once a week the ink will dry up and clog the print head.
If you can not get it cleared, see if your manual shows the print head and replace it. Some ink cartridges have built in print heads. But if that was the case, when you changed the ink cartridge it would have worked.
Hope tis is of some help. Bud
Jan 20, 2010 | Computers & Internet
Color on photos suddenly has a blue - purple wash with no greens
Your yellow cartridge is probably not working as your photos suggest. Remove and reinsert the yellow cartridge. Try printing only yellow color.
Your printer has a separate head for printing; the nozzle for yellow ink might be clogged. Try running a head cleaning routine from your printer software.
Sep 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Not printing magenta ink and tried cleaning heads already
Hi, one or two head cleans won't clear a clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink have some new ones ready. Hope this helps.
Please take a moment to rate this solution, thanks.
Mar 28, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Moen one handle kitchen faucet very low water stream
if the pressure is good with the head off then you can probably get a new head for it u shouldn't have to change the cartrige. it sounds like the head is clogged so plastic pieces in the head to help save water "water savers" it is hard to clean them i would try changing the head u should be able to find on for a moen, u buy for looks u buy it for life. take the old head with u when u go to buy a new one so they can match it up to the right one.if you can't find it and a lowes or home deptm try a plumbing supply house
Mar 08, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Black is not printing. Have changed cartridge twice and cleaned heads several times
Most likely the printer head is clogged either you have had a bad cartridge that was dried out and dried all the black ink in the brothers.
the only way to clear this up is take it to a place that cleans the head manually, or try top get to the printer head and clean them yourself.
Dec 04, 2008 | Brother Office Equipment & Supplies
IP4200 Printing wrong color
Try
www.fixyourownprinter.com
In the field type your printer and model
Take no notice of adverts.
Also try Canon support
Jun 08, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Epson Stylus Pro 4800 InkJet Printer Logo
94 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
