Question about Microwave Ovens
HI MY GIRLFRIEND HAS GOT THE HAMPTON MODEL # 7811 E200557FT & WE JUST WANT TO KNOW HOW TO SET THE SENSOR & TIME.THERE IS A BUTTON PLACED BELOW EACH THE SENSOR & TIME & ALSO GREEN & RED LIGHTS THAT APPEAR EVERYTIME YOU PRESS THE BUTTON.CAN WE GET A DIAGRAM TELLIN US THE MEANING OF EVERY FORMATION FOR THE GREEN&RED LIGHTS PLEASE.
4 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: Does not start !
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 04, 2007
shbarker
SOURCE: PANASONIC - SENSOR 1200 W. microwave
All electronics work but microwave won't heat.
Posted on Sep 21, 2010
MicrowaveSvc
  • 9085 Answers
SOURCE: khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Posted on Dec 03, 2011
Setting the setting the clock
Colin,
Most of the time, you hit clock, then on the keypad, punch in the time of day and then either hit clock again or hit the start button. Some models may ask you for AM or PM but it will scroll a message if it is going to ask that & will tell you what button to push. Hope this helps!
Jul 09, 2015 | Microwave Ovens
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Setting the clock
hello,
simple to fix up your self please follow this instruction below
  1. Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
  2. Step 2 Set the clock by pressing the "Clock" button.
  3. Step 3 Turning the dial on the sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
  4. Step 4 Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the sensor microwave oven.
  5. Step 5 When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
  6. Step 6 Press the "Start" button to allow the clock to begin on the sensor microwave oven.
thank you for using fixya.
Jul 31, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
How do I change the time on m Siemens Microwelle plus oven please? Model number HF75960GB
Did you try pushing the clock button, setting the time (eg. 300) for three o'clock, and then push the clock button once more. If this doesn't work, don't push the clock button at the end. Just set it, and let it stay until it stops blinking - and then it should be set. If you need further assistance, let me know and I'll help you. I'm just going by the usual standard of setting clocks on microwave's - but maybe with this model, there's another way. Good Luck to you! - Jim
Mar 28, 2010 | Siemens Microwave Ovens
I have a professional series frigidaire glass top stove and whenever I press the bake button or any other button like to set the clock F30 Err shows. what does that mean?
F30 Open probe connection.
Check resistance at room temperature & compare to RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
Check resistance at room temperature, if less than 500 ohms, replace RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
To find your nearest servicer, see Frigidaire Customer Support.
Jan 16, 2010 | Frigidaire Microwave Ovens
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Clock setting
Mine is a Samsung, I don't know about your brand, but mine has a "CLOCK, AUTO/START"
button. Press & hold this & punch in the numbers until have the correct time
Aug 09, 2009 | Microwave Ovens
Microwave shuts off before time elapes
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
The best place to order Panasonic parts is Tritronics. You can also call them at 866-779-5835.
If you prefer, you can find an authorized Panasonic servicer here.
Dec 07, 2008 | Panasonic NN-T990SA Microwave Oven
Microwave Ovens Logo
161 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
