Question about Makita 10" Miter Saw LS1030N
On a makieta mitar saw changed blade how to reattach the blade safety guard
  • Makita Master
  • 7,733 Answers
I need saw blade safety guard for 71/4 Kobalt Miter saw
Fixya does not sell saw blade safety guards.
Jul 22, 2017 | Blade Saws
Looking for the blade guard arm.
Search Results
    7" Job Site Tile Saw with Laser - RIDGID Professional Tools
    https://www.ridgid.com/us/en/7-inch-wet-tile-saw-with-laser
    Ridgid7" Job Site Tile Saw with Laser. ... Heavy Duty Arm - prevents flexing while keeping the blade aligned; Guard Baffle - reduces air turbulence to help keep water ...
    [PDF]7" BRIDGE TILE SAW
    manuals.harborfreight.com/manuals/97000-97999/97360.pdf
    7" BRIDGE. TILE SAW. WITH STAND. Owner's Manual & Safety Instructions. Save This Manual .... that has an outlet that looks like the one illustrated above ... Use saw-blade guard and spreader for every .... arms and shoulders. To reduce the.
    [PDF]10" INDUSTRIAL TILE/BRICK SAW Owner's Manual ...
    manuals.harborfreight.com/manuals/69000-69999/69275.pdf
    parts. Nonslip footwear is recommended. Wear protective hair covering to contain long hair. 11. ALWAYS USE ... an outlet that looks like the one illustrated above in Figure A:... For Your Own Safety Read Instruction Manual Before Operating Saw. 1. Wear eye ..... Connect the clear water Hose from under the arm of the Motor ...
    SKIL 7" Wet Tile Saw 3540
Dec 16, 2015 | Blade Saws
Any guard blade for a saw miter
Yes, Did you buy it new? It has two heavy plastic seen through plate that are attached to each other. This safety shield is gravity fed. That mean as one pull down the saw the safety guard will pivot into the upper shield. As the saw go back up after cutting a piece of wood. The safety shield will drop back into it safety position covering the 12" blade. GB...stewbsion
Aug 23, 2011 | Bosch 12" Dual - Bevel Compound Miter Saw...
Need to replace the blade on the saw. mastercraft 10" mitre saw. i've managed to loosen it but can't seem to get the blade out of the machine to put the new one in. what am i not doing?
Lifting the safety guard maybe? The blade will not pass through the opening with the guard down (it's one of the purposes of the guard).
Jun 13, 2011 | Garden
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 | Garden
To get the blade guard on a Ryobi circular saw to stay up.
Blade guards are spring loaded so they will not stay up unless you hold it up manually
May 05, 2010 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
Chainsaw blade will not turn?
If the saw is running and the chain doesn't turn, chances are you tripped the kick safety (the guard in front of the top handle) Push that guard back towards the handle firmly until it clicks. It should work now. The other possibility is if you just changed the chain that the safety isn't correctly engaged with the guard.
Mar 06, 2010 | Standard Oregon Chainsaw Chain For Stihl...
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Dewalt miter saw .
Either the blade or the guard is out of alignment. You will have to check and find out which one is the culprit.
Aug 29, 2008 | Dewalt DW715 Heavy Duty 12" Single -...
Makita 10" Miter Saw LS1030N Logo
142 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
