Question about Samsung Washing Machines
Unit containing motor and washing tub suddenly jump around dislodging drive belt. Is it a bareing problem or gear box.
  • 18 Answers
More information on the problematic unit would really help but the jumping of the tub isn't a tub bearing problem although it can definitely lead to one. The jumping could be due to an unbalanced load, the unit itself not being properly leveled or if it is a floating tub then one or more of the support shocks may not be positioned correctly. Also if this is a new unit then make sure all shipping bolts and/or supports are removed. The bearings in the belt pulleys or the tension pulley could be bad and also make sure the belt properly installed.
Posted on Nov 07, 2010
My washer will spin but very slowly. Motor and shaft spins out of washer.
Your problem sounds like the drum/tub drive clutch is worn. Especially if the motor operates fine and attempts to spin the tub. This model is a direct drive unit, no belts, so if the motor operates during the spin and drain cycles but the tub is barely moving, only two problems can cause this, bad clutch (which is engaged only during the spin cycles) or worn drive coupling on the motor. If the coupling were a problem, though, you would also notice sluggish or erratic agitation during the wash cycle.
Hope this helps
kcomp1863
Jan 04, 2011 | Roper RAS6233KQ Top Load Washer
Tip
How to service tub & agitator
The washing machine tub, or basket, generally doesn't cause problems. However, at times it may cause damage to the laundry, make a lot of noise, vibrate, or stop completely.
If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
The agitator -- the finned part that fits on the tub shaft -- can also tear laundry if the fins are cracked or broken. You may be able to solve the problem temporarily by pinching off the splinters with pliers and lightly filing the plastic smooth, but this is just a stopgap measure; the agitator should be replaced. Replace a damaged agitator with a new one of the same type. To do this, unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator into place and replace the agitator cap.
Damage to the snubber, a padlike device sometimes located under the agitator cap, can cause the machine to vibrate excessively. The snubber may have a suspension spring in it. Lift off the agitator cap and examine the snubber. If the spring is broken, or if the pad is visibly worn, replace the entire snubber. Snubbers might also be found at the splash guard at the top of the tub, under the transmission, or as part of the water pump housing. Look around until you see it.
If the machine doesn't have a snubber, listen for noise at the suspension unit between the tub and the machine cabinet. The suspension unit has fins or pads that may need replacement. In some cases, the entire unit may have to be replaced. Another noise point is the basket support nut. Tighten the nut or, if you can't tighten it, replace it.
Sudden tub stops can be caused by a broken motor belt, but they are usually due to poor tub loading. Check to see if wet laundry is wadded around the bottom of the tub shaft, or under the basket or agitator assembly. Remove the basket or agitator in order to remove the laundry easily.
on Jan 16, 2010 | Washing Machines
Maytag Atlantis washer. Washer makes noise that approaches grinding, and the agitator doesn't spin. Rather, isn't connected to the motor. Spins semi-freely by hand, with a rough motion and noise
Your unit is gear driven and is contained in a mechanism enclosure.The roughness your feeling when turning it are the worn-out gears.One cause is it might have ran out or dried out of gear lubricant.The motor drives a belt to run the gears so the motors are running fine.Your gear box is the problem.
Dec 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My tub wont spin but the aggiator free spins
The tub and agitator are two different pieces. The tub bearings or seal may be broke.
Servicing the Tub and Agitator
©2006 Publications International, Ltd.
Unscrew the cap on top of the
agitator and pull straight up;
the agitator should lift off.
If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work -- or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
Replacing Drive Belts and Tightening Pulleys
The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
Servicing the Motor
In most cases, motor malfunctions should be handled by a professional; do not try to fix the motor yourself. If the motor is a universal motor, however, you can change worn carbon brushes when sparking occurs, as detailed in the how to repair appliances article. To save the expense of a service call, remove the motor from the washer and take it to a professional service person, then reinstall the repaired or new motor yourself. To access the motor, remove the back panel of the washer. The motor is mounted on an adjustable bracket.There is one other motor problem you can repair yourself. Washer motors usually have an overload protector clipped to the motor. When this component fails, the motor won't work. Before you take the motor in for service, test the protector with a VOM set to the RX1 scale. Disconnect one electrical lead wire to the protector and clip one probe of the VOM to each protector terminal. The meter should read zero. If the needle jumps higher, the protector is faulty and should be replaced. Pry up the protector with a screwdriver and replace it with a new one made specifically for the motor or washer. Connect the new protector the same way the old one was connected.
Sep 11, 2009 | Roper RAX4233PQ Top Load Washer
It knocks on spin cycle
The tub may be off balance.
Sep 10, 2009 | Washing Machines
Kenmore elite sm 9710803-a motor
Belt is loose or pulley needs to be tightened.
Sep 04, 2009 | Washing Machines
Washer drum bangs from front to back
This may be a drum or agitator problem. Possibly bad bearings or coupler
Sep 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Fills and will spin out, but will not agitate. I
Sounds like the motor is not engaging. Or the agitator is stuck.
Servicing the Motor
Sep 03, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Tremendous noise and vibration when spinning
Servicing the Motor
Aug 29, 2009 | Washing Machines
The agitator stops moving during the wash period, and sometimes it slow when is suppose to be spinning to remove the water from the clothes.
We will conclude our tour of the washing machine on the next page with tips for servicing the water pump, the belts and pulleys, and the motor.
Servicing Water-Related Problems, Belts, Pulleys, and the Motor
On this page we will explore some of the more mechanical parts of a washing machine like belts, pulleys and the motor. First, we have some tips for water-related problems.
Aug 24, 2009 | Washing Machines
Washing Machines Logo
52 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
