Question about Saeco Caffe Charisma Espresso Machine
Coffee watery Dose setting is at max (+) and grinder at finest (2). I just descaled and and installed new parts on the brew group. Didn't help. Help.
  • 40 Answers
Setting your dose at max and grinder at finest is not good. This means that you are asking the machine to grind coffee really fine, and then dose maximun amount which can lead to the grinder getting clogged. If you are looking for stronger coffee, it is best to have several shots that one that has too much coffe and too fine. For stronger espresso, use less water instead of more coffee. Two shots of 2 oz. espresso (made with 7 grams of coffee) are more flavorful & sweeter than one shot of 4-oz. espresso made with 14 grams of coffee which could clog your grinder and door/channel. At this point, you need to clean the grinder ( inlcuding the door/channel). I suggest you have an Authorized SAECO Service Center check your machine. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 19, 2008
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
What is the proper method to descale?
Yes, you should empty the bean hopper and put the solution in the tank and run it through.
Nov 09, 2007 | Saeco Vienna De Luxe Espresso Machine
Flashing dregdrawer and descaling lights
You need to run the descale process, which essentially cleans the plumbing.
Aug 19, 2012 | Saeco Odea Giro Plus Coffee Maker
The alarm light to empty the coffe grounds drawer AND the descaling light flash alternately I cleaned the brew group. Machine comes ready, but when I press to make a coffee it comes back with alternate...
Hi, the problem with your machine is with the grinder motor (not working).As soon as you press the coffee the CPU senses the motor is out of circuit and the lights start flashing alternately.
You can test it by doing this. Press and hold the steam button and switch on the machine, you will see the lights going around in anticlockwise direction. Release the button then turn the dial to left (Min) and press the steam button the grinder should work. The dial on the right (Max) the brew group will come up..and half way it will come back to normal position. Press the coffee button in that position will work the pump. Servicecenter can fix this if the machine is less than 2 year old FOC.
Oct 10, 2010 | Saeco Odea Go
I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Mar 23, 2010 | Saeco Odea Go
Coffee is too weak
I just spoke to someone at customer service. My coffee has been weak and kind of thin. We had the Superautomatica by Saceo for years and I remembered the coffee being richer.
Anyway! The person suggested that I adjust the grind but slowly. So set it to the coarsest setting, brew 2-3 cups. Then put it to the 2nd-coarsest setting, brew 2-3 cups. To the third, brew 2-3 cups. To the forth, brew 2-3 cups. Etc. Until you're at the finest grind setting. Again, brew 2-3 cups. An awfully sensitive machine. It seems to have worked although the last few seconds of brewing continue to be a kind of milky colour (as opposed to a deep black coffee colour). You can, though, press the "cup" button to stop the brew. So once, it starts running milky, you can stop the cycle.
I hope this helps. I know I've been struggling and cursing the machine for a while :)
Dec 30, 2009 | Saeco Odea Giro Plus Coffee Maker
Waret Pucks
Hi There are 2 problems that can cause a watery puck. 1. Like EsWorld said, If the grinds is too coarse it leaves room for more water and you get a watery puck. 2. But if your grind is like a grain of salt, the you don't have enough coffee going into the brew unit, and this leaves room for extra water. To fix this, there is a lever on the top center of the door. The lever will increase the dose if pushed towards the back. DON'T push the lever to the full back position. This could cause an over charge, which could cause the brew unit to dump the ground coffee with out making because it could not compress the charge, or it could break the brew drive. 1 click back from the full plus is fine and will give a great shot.
Jun 03, 2009 | Saeco Royal Professional Espresso Machine
Re: no coffee comes out after the grinding and loading stages!
Sounds like your coffee grinder is grinding too fine. I would up the size of your grinder. The larger the numbers the coarser the grinds. Also, should descale the machine if you haven't in a while. One of these two things may help.
Also, if the above two things do not work you can try to clean out your grinder using the instruction #2 posted on the website http://cerinicoffee.com/Saeco_technical_documents.asp
Sales, Service and Information of Saeco Machines visit:
www.CeriniCoffee.com
Hope Everything works out for you.
Oct 06, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco incanto deluxe
Try descaling it manually- by adding the descaler into the tank, letting the machine warm up and then open the water spout to fill one cup at a time. wait 15min. in between. Also clean brew group and grinder.
Jun 10, 2008 | Saeco Incanto Classic Espresso Machine
Water leaking from coffee dispenser
Hei dory may be this can be helpful.Inside the machine take out the brewing group on the back panel there is asmall metal piston with 2 small orange rubber o ring.Try to replace that(is not easy since the position)were the o ring are locate is very unconfortable but is something i believe you can do it.That one is the main connector between the inside and the conjunction with your brewing group.
Good Luck
Sep 09, 2007 | Saeco Incanto Classic Espresso Machine
Saeco Caffe Charisma Espresso Machine Logo
207 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
