Question about Dell 926 All-In-One InkJet Printer
Where is the ip address on the dell photo aio 926 printer???
rickzilla
  • 706 Answers
SOURCE: Dell Photo 926 Printer HELP!
Hello Jadamsfort.. try this link ..
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_ALL_A926&os=WLH&osl=en&catid=&impid=
You'll need to input your system details but you should be able to get the drivers you need...
Hope this helps..
Posted on Sep 28, 2008
manojro
  • 495 Answers
SOURCE: Dell Photo 926 Power cable
You can get it from site below:
http://accessories.euro.dell.com/sna/productdetail.aspx?c=uk&cs=ukdhs1&l=en&s=dhs&sku=450-11224
Posted on Jan 08, 2009
Vivektj
  • 55 Answers
SOURCE: Dell AIO 926 driver is not installed, even though I installed it!
Hi, The problem here is that the CD has an older version of the driver which has some known issues. Few steps will be required to fix this.
  1. Unplug the printer
  2. Goto control panel -> Add/Remove programs (or) Programs & features (Vista), uninsuatll the Dell Printer software if listed.
  3. Download the Driver from the Dell Support Website
XP Driver
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=195205
XP Printer Application
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=205258
Vista Driver
Vista Printer Application
Hope this works... Please rate your feedback!!! Thanks
Posted on Mar 02, 2009
john_yap
  • 51 Answers
SOURCE: printer aio 926 communication error
hi aweintra,
you can do the following steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software, then unplug the usb cable of the printer.
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
just send me an update if the issue won't be fixed. have a great day.
Posted on Oct 19, 2009
  • 46 Answers
SOURCE: I refilled my dell ink cartridges from Costco. Now
Here is a fix I found for remanufactured Dell cartridges.
http://swapink.com/Merchant5/merchant.mvc?Screen=dell_int
This usually helps with my printer.
Posted on Mar 15, 2010
My DELL AIO photo 926 is telling me to remove tape from cartridges, how do I do that or how to solve this problem? i have new ink cartridges in already
remove the tape from the cartridges, it has tape on the contact point of the cartridge, pull them out again and double check dell printer
Dec 09, 2011 | Dell 926 All-In-One InkJet Printer
My dell photo AIO all in one printer 926 the scanner wont work. The printer and copier works fine but the scanner dont
First I would reinstall the driver from the Dell website.
If that doesn't work, check if you are under warranty and have them replace it.
Jan 25, 2011 | Dell Photo 926 All-in-One Printer
I'm tryin g to scan a photo with my Dell AIO 926 Printer, connected to my Dell Inspiron 1525 laptop. But the laptop doesnt seem to be bringing up the AIO 926 printer file folder/menu, and when I request...
Did you figure this out? You should have a "Dell All-In-One Center" that was installed with the drivers for the printer. Try searching for it by pasting that phrase in the box in your "Start" button. When you locate it, drag the shortcut to your desktop or up in the top of the programs in the Start location. When you click on the Dell All-In-One Center icon, you should find some options for scanning.
Nov 12, 2010 | Dell Photo 926 All-in-One Printer
Deleted the whole Dell photo aio 926 program in error. Try to run the orig cd that came with printer but it won't run. How can I get it back? Went to search and came up with 'google icon' and 'folder' but...
Try reinstalling the printer using the instructions located at....
926 Photo All-In-One Printer owners thread (W7)
You'll need to disconnect the printer. Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer.
Install the proper drivers. You'll get the message, the printer is not connected. Connect the printer at this time.
Rick
May 21, 2010 | Dell 926 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
476 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
