Question about The Home Depot
The template for countertop cutout for the square Glacier Bay vessel sink, is not as shown in the instructions. Where can I find a template to match the model of sink I have? Also the instructions indicate that when the sink has been installed, "wipe the outside of the toilet gently with a damp cloth. . . " I do hope this is a typo error or do I have a completely different set of instructions?
Where can I get a replacement handle/flush lever for a 2006 Glacier Bay 1.6 gallon toilet?
Glacier Bay Toilets are made in China by "various manufacturers" a local plumbing parts supplier is your best bet.
Jan 11, 2016 | Home
How do I put seats and springs in a glacier bay Aragon three handle knobs
How to Repair a Glacier Bay 3 Handle Tub and Shower ...
www.faucetinstructions.com > Glacier Bay Faucet Instructions
My three Handle Glacier Bay Tub Shower Faucet Makes a High-Pitch Squealing ...The Glacier Bay tub faucet screw-cover buttons will not stay on the handles. ... Sealthe flanges to the shower wall with a high-grade anti-microbial kitchen and ...
Nov 07, 2015 | Plumbing
I need a cutout template for teka sink model 86555
If u have the sink. Put card board down for your pattern set sink on card board and trace sink .if no sink measure sink cut to size
Mar 31, 2014 | Trion Teka Sink 60 S Stainless Steel...
I installed the sink drain with overflow and water is leaking from behind the sink and under the countertop. What did I do wrong.
a vessel I dont beleive has a overflow. you need a differant waste for that unless theres something your not telling me
Sep 03, 2011 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
How to repair facet stem for glacier bay products kitchen sink
Theres not much you can do to repair the stem except replacing the small O-ring up inside. You can call Glacier Bay and ask for a new stem ( the faucet has a limited lifetime warranty. You can also use Delta faucet repair parts in your Glacier Bay kitchen faucet; they come from the same mold. Heres a link to Glacier Bay 2 handle kitchen faucet repair. Heres one to the Glacier Bay faucet manual for your faucet.
Sep 16, 2010 | Globe Union Glacier Bay 8 In Double Handle...
I just want to be sure I place the sink properly into the new countertop. Are there certain distanced from the back or front I should be aware of? I have an Eljer tile-in bathroom sink, model 052-0317. 21...
The most critical dimension is the clearance between the backsplash (wall side) and the sink as you want to ensure that there is room for whatever faucet set you've selected. Typically you want to leave 4 1/2 to 5" between the rear of the sink and the backsplash for the faucet but that's not critical as long as you leave sufficient space for it. A typical bathroom countertop is 22" deep so your large sink will be close fit. Now, if the faucet mounts through holes in the sink itself you can just center it.
Apr 22, 2010 | Home
Poor Draining of Vessel Sink
have the plumber pop an opening on the side of the drain pipe under the sink. and add a indoor vent.
Apr 10, 2009 | Advent KRAUS Amber Rectangular Glass...
Pegasus Push Button Vessel Sink Drain with overflow
Put plumbers putty around the flange that will be in contact with the sink. When you put it into the hole, try to line up the overflow as good as possible. The nut that goes onto the bottom (tailpiece) has a rubber gasket that will go between the nut & the sink. Adding some plumbers putty here won't hurt. After all is secure, just remove the putty that squeezed out from tightening.
Feb 21, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
The Home Depot Logo
142 people viewed this question
Top The Home Depot Apps Experts
Erin Wood
Erin Wood
Are you a The Home Depot App Expert? Answer questions, earn points and help others
