Question about Frigidaire FER211A Electric Dryer
Fer211as2 frigidaire will come on , but will not heat up . If it is a fuse that's needs to be replaced I need to know where it's located
  • Frigidaire Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 07, 2010
HIGH PITCHED dryer SQUEAL but clothes are drying...
Had same problem that went away after replacing each of the drum roller wheel/bearing assemblies. (repairclinic.com) Not the easiest of jobs removing & replacing the drum, but a lot cheaper than a new machine.
Nov 23, 2013 | Frigidaire Washing Machines
My frigidaire dryer LEQ642DS0 will not shut off by itself, would that be the timer or the knob? Also if it is the timer, is the kenmore/frigidaire part #131062300 (timer) compatable with my dryer
Instructions
Things You'll Need:
* Phillips and hex nut screwdrivers
* Replacement thermal fuse
* Replacement thermostat
1. Disconnect the dryer from the electrical outlet.
2. Slide a putty knife between the top panel and front panel on the left side. Slide the knife toward the center of the dryer to release the left-side spring clip. Repeat the process on the right side. Lift the top panel up and rotate toward the back of the dryer. The thermal fuse and thermostat are located along the dryer's back wall, attached to the heating element housing.
3. Disconnect the two wires from the thermal fuse. The thermal fuse is an inch-long rectangular plastic part, located near the top of the heating element housing. Remove the screw holding the thermal fuse in place. Remove the old fuse. Place a new fuse on the housing and replace the screw. Reconnect the wires to the fuse.
4. Remove the wires on the thermostat. The thermostat is a black, oval-shaped part located just below the thermal fuse. Remove the screws holding the thermostat in place and slide it out of its slot on the heating element housing. Slide a new thermostat into the slot and replace the screw. Reconnect the wires.
5. Lower the dryer's top panel and press down until the spring clips lock into place. Plug the dryer back into the electrical outlet.
Feb 24, 2011 | Frigidaire Dryers
The heating coil isn't heating up what part can i look for to replace to make the heating coil work? on this daryer Model # FER211AS2 SERIAL # XD33511962
The most common problem on these dryers is the heating element itself. The part number for the element assy is 131553900 and runs about 70 bucks you can buy a restring kit for alot cheaper but I would recommend just buying the assy because if you over stretch the coil it will cause it to burn out quicker. Good luck.
_MJ_
Dec 15, 2010 | Frigidaire Dryers
Dryer runs but won't heat. I need to check the
there is no fuse, you need to replace heating element
Oct 24, 2010 | Frigidaire GLEQ332A Electric Dryer
Need to install a 4 prong to a Frigidaire electrict dryer model FER211AS2
The following link explains how to correctly install a 4-prong power cord on your dryer:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you have any questions about this repair, please let me know. I hope this helps you.
Nov 02, 2009 | Frigidaire Electric Dryer
Have a frigidaire affinity electric dryer that doesn,t heat
check your heating element or the thermal fuses located on the back wall the side of the heating element can and the plastic blower ducting
Sep 06, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire FER211AS2 dryer drum belt
the washer has to be tipped forward. can access from bottom (and back).
Jun 03, 2009 | Frigidaire FER211A Electric Dryer
you will have to take it apart to get the drum out. you have to take the top off
May 06, 2009 | Dryers
Dryer works but won't heat
2 things ,,no heat whats so ever ,sounds like ignitor,, or little heat possible coils )gas)
Nov 29, 2008 | Frigidaire Dryers
Frigidaire FER211A Electric Dryer Logo
288 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
