Question about Canon PowerShot SD1000 Digital Camera
My display screen is black when I go in camera mode, how can I resolve that problem
  • Canon Master
  • 4,738 Answers
First try pressing the DISP or DISPLAY button to verify that you didn't accidentally turn it off. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Jun 24, 2011
Hi, I have a Canon IXUS 95IS camera.. For some reason, when I attempt to take a photo, the LCD screen isn't displaying what is actually in view? In movie mode it comes up on the screen but when i flick it...
Ah yes! you have pressed the display button. Turn the camera on and you see the icons in the display, look for the Disp button and press it, the display will cycle through its modes icons, black, image and icons.
Jan 22, 2010 | Cameras
Camera not working ,when in camera mode the screen is fuzzy and black
Hi Friend,
As you have mentioned that u are facing the screen fuzzy and black when u are in camera mode,i to was facing this same problem.Actually the problem is with the Display.
Once i have changed the display the problem has been got solved,So kindly change the display you will get a perfect solution
Regards,
Ayyasam
Jun 30, 2009 | Nokia 8800 Cellular Phone
Canon Powershot SD1000: LCD screen display
Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
May 05, 2009 | Canon PowerShot SD1000 Digital Camera
Black LCD monitor on Powershot S410
that is not a malfunction, if the "display" button is pressed, the LCD turns off, (black), but if the mode switch is rotated to movie or panorama, it comes back on but will go black again if switched into the other 2 modes. when in one of the 2 modes that show black, simply press "display" and the LCD will come back on.
FYI "GURU", the CCD malfunction manifests as a purple colored screen with various levels of distortion, not black
Feb 02, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Samsung s860 digital camera turns on and then goes to blank screen and will do nothing else, to turn off it requires battery removal. same story with new batteries.
Dear customer
thanks for ur inquiry for ur product
If the LCD screen is blank or black when you have your camera in the Camera or Play mode, the camera may need service. To determine if this is the case, follow these steps:
1. Press the Menu button to see if the LCD screen can display the OSD (On Screen Display). 2. Set your camera to Play mode, and then see if the LCD screen displays a picture. 3. To eliminate the possibility of a user setting causing the problem, put the unit into Auto mode by rotating the dial on the units exterior to Auto Mode. Note: The word "Auto" appears on the screen when this mode is activated. 4. If putting the camera into Auto mode does not resolve the problem, test the unit in Play mode. If the unit operates normally in Play mode, but the screen in Camera mode is blank, your camera requires service which you can arrange by Creating a Service Ticket below. Note: Because your camera has an automatic LCD display shutdown feature, its normal for the LCD to stop displaying when the camera has been on for along period of time. This feature prolongs battery life.
urs sincerely
Harrish
Jul 10, 2008 | Samsung Cameras
Canon Powershot A70
There is a button on the back that can be pressed called Disp. (stands for Display). There are two or three settings it flips through each time you press the button. Press this button a few times to cycle through the choices in each of the playback and camera mode to see if this resolves your issue. Happy snapping...
Nov 23, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Black Display Screen
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....
Oct 31, 2007 | Sony Handycam CCD-TRV68 Camcorder
Fuji f700
I recently had trouble with the LCD Display coming up with a black screen. So I mailed it to Fuji with a letter explaining the problem. About 3 weeks later I got it back in the mail and it seem to be working fine until a month later. I turned it on and the LCD display show a black screen only now it has white lines. I'm so incredible mad and extremely dissapointed in Fuji. Reading online I have notice many people having trouble with Fuji Products. I WILL NEVER BUY a Fuji again!!!
Jan 15, 2007 | Fuji FinePix F700 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
44 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
