Question about Gateway GT5622 PC Desktop
Computer fan runs fast all the time. cpu temperature about 80 deg f. bios says 262 de f. I done feel any excessive heat with side cover off. Help
  • 1,179 Answers
The temperature reading of 262 degrees f is incorrect, think of it this way if it really was running this hot it would have keeled over and died long ago. The reading at 80 degrees is very accurate, use this one for reference purposes. Ignore the reading of 262 degrees f.
Thanking you
damnor01
Posted on Nov 08, 2010
Got an ACER 7530G with a thermal isue. After some time it shuts immediately down. Seems to be a thermal processor problem. Fan is running, no dust inside. Processor temperature is between 52deg. C and 66...
If the fans are spinning then you need to take off the heatsink and ensure that there is paste between the heatsink and the CPU (its a golden or silver color normally). If not, go buy thermal paste.
If there is paste, then the heatsink was not placed properly on top of the CPU. Even if 3 corners are properly inserted and only one is not properly done, this can certainly cause overheating.
Oct 13, 2013 | Acer Aspire 7530 7530g 7730 7730g 7730z...
TOO HIGH TEMPERATURES AT MY LAPTOP ACER ASPIRE 5735Z
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Aug 01, 2012 | Acer Aspire Computers & Internet
I turn on the computer and it may run some times for about 10 or 15 min. and then shut down i was wondering if i need a bio's update or what i have two hard drives in the computer xp pro on 1 and vista...
It could be overheating. After it shuts down, restart it, and enter BIOS SETUP, and look for a "PC Health" or "Status" entry on the menu. If you're lucky, it will report the current CPU temperature, and the speed of the fans, and the settable temperature at which it will shut itself down.
Check the capacitors on the motherboard -- any capacitor with a "dome" on top, instead of perfectly-flat, is a leaking capacitor that is intermittently failing.
Jul 19, 2011 | Mach Speed (MSNV-939) Motherboard
Automatic shutdown over heating
Turn the computer off.
Remove the side-panel, to expose the motherboard.
Turn the computer on.
When you see PRESS <blah> TO ENTER BIOS SETUP, press the <blah> key.
Use the "arrow" keys to move around the BIOS SETUP menu,
looking for any "system health" menu-entry.
Press the "enter" key to select that menu-entry.
It should report the current motherboard temperature, and the current CPU temperature,
and the temperature-limit, beyond which the motherboard will force a shutdown.
It may also report the speed of the power-supply fan, the case fan (if installed), and the CPU fan.
Also, take a look at the fans, to confirm that they are spinning.
Replace any non-functioning fans.
Jul 13, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My computer is beeping every so often it beeps about 3 times and it does it fast please tell me why
It only mens that there's an error on your computer.
Beep codes are use to check or identify which computer part/s causing the problem.
Beeps
Error Message
Description
1long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1long, 3short No video card or bad video RAM Reseat or replace the video card. High frequency beeeps while running Overheated CPU Check the CPU fan for proper operation. Check the case for proper air flow. Repeating High/Low CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed.
May 11, 2011 | Toshiba Computers & Internet
My computer fan afb0712hhd. when i turn it on the fan runs fast for a few seconds, then runs slow and the cycle continues. can you tell what is wrong?
Your fan is following the heat pattern of the CPU. As your computer does more stuff, like runs more applications, it has to work harder to make everything go. This creates heat that needs to be cooled by the fan. The fan usually has 2 settings, low, and high. When the CPU reaches a certain temperature the fan will switch into high gear to help cool it down.
Mar 29, 2011 | Computers & Internet
I have a hp slimline 3100. the cpu fan runs fast everytime i open a program or play a cd. it speeds up the slows down. sometimes it runs really fast, then the computer shuts down. whats going on?
This is an indication of overheating within the PC. Open the PC case and clean all the air vents. Take the heatsink and fan off the CPU and give it them a good clean. Put the heatsink and fan back on to the CPU and start up the PC. check that the fan on the heatsink is running smoothly.
Also, make sure the vents on the power supply are clear and the fan on the power supply runs well.
If you go into the BIOS setup, you may be able to monitor the fan and the CPU temperature.
Mar 18, 2011 | Computers & Internet
My cpu fan spins very fast than normal and makes a lot of noise. I use hp d530 cmt- 3.06GHz
Most fans are "temperature-sensitive" -- if it is sensed that your computer is close to over-heating, the fan will run at full speed, very noisily, to try to cool it.
So, shut it down, and disconnect the AC power.
Remove the side-panel.
Purchase a can of compressed-air.
Give the computer a "blow-job", to remove excess dust,
since the layer of dust is acting like a blanket,
keeping heat inside your computer.
Sep 20, 2010 | HP Compaq d530 CMT PC Desktop
I have a HP M1270N Media Center PC. The CPU Fan
The CPU fan is designed to run constantly to prevent the CPU from overheating. The speed depends on temperature condition of the room; slow in cold and fast in a hot room. However if you suspect that it runs too fast them try re-seating the CPU. WARNING: Re-seating should only be done if you are know how to do; don't experiment.
If it is running noisy, you can apply one or two drops of machine oil to the fan's spindle.
Other reasons include deposits of dust; use a blower to remove dust from the heat-sink.
To make sure you CPU is not in a critical state, log in the BIOS and in the hardware monitoring tab check the CPU temperature. It should be near 60 deg Celsius or 140 Fahrenheit.
One thing more, do not apply thermal grease in excess; its a conductive compound and can short the motherboard if it melts and deposits on the motherboard due to high CPU temperature.
May 25, 2010 | HP Media Center m1270n (PP132AA#ABA) PC...
Toshiba 4010 is giving me a "warning, problem with the cooling system message" Machine gets real slow. How can I inhibit this message, I have it on a cooling pad?
The electrical components in a PC generate heat, and fans inside the PC help move the air to keep the components from getting too hot. Excess heat will cause the fans to run constantly, damage components, and limit the speed of the CPU. All of these problems with high power and high heat will cause applications to work slower than normal. One of the main functions of the BIOS is to monitor the temperature and adjust the operating conditions. While the sound of the fan running all the time can be annoying, it may the first clue that your PC is running as efficiently as possible. To help your PC as cool and as efficiently as possible, do one or more of the following corrective actions.
  1. Update the BIOS
  2. Keep air vents clear and clean
  3. Minimize disk operation
  4. Minimize CPU operations
  5. Check whether FAN is enabled in BIOS
Thanks Rajesh
Jul 13, 2008 | Toshiba Computers & Internet
Gateway GT5622 PC Desktop Logo
112 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
