Question about Dell Dimension 4600 PC Desktop
My dell dimension 4600c powers on when I plug it in even though I haven't hit the power-on button. This results in having to run "set-up" and reset the date and time manually each time by hitting F2. Advice, please
  • susan_howard Nov 10, 2010
    There is nothing to "clean" about the on-off switch. It is contained. I keep the computer unplugged because we have frequent power-surges/brown-outs and I don't trust the surge protector. When I plug the computer in, many times it will just turn on and then I have to run the set-up, which is time-consuming.
  • 1,472 Answers
Susan_howard
Actually your problem is that the CMOS battery in your computer is dead. This is what allows the BIOS to save your system settings like your clock time.
So when you unplug the computer the BIOS loses power in turn reseting your data and time.
The CMOS battery is the watch battery on the motherboard. What you will need to do is take this battery to your local electronic store so they can get you the proper replacement.
If you are needing help finding it and/or getting it removed let me know.
Issken
http://www.fixya.com/users/issken
Posted on Nov 11, 2010
  • Dell Master
  • 7,733 Answers
It seems that the problem is caused by a burn power button.Sometimes the power button get stiky or malfunction.So when you plug your PC the PB is stuck in "power on" .You can try if you can to remove the PB from the case and check or replace it.
Posted on Nov 08, 2010
Dell dimension 4600c won't turn on since we had a power outage
hi
if you CPU has a green light it meance your Power supplay is working fine chack back side of your CPU fan is working or not if it's working then just open case
folow the 2 step
1 remove RAM
2 CIMOS beetery which is on mother board leave your CPU for Some thime re fix both i hope you CPU will give you the disply
Jul 19, 2010 | Dell Dimension 4600 PC Desktop
Dell dimension 4600 will not power up.
Hi there if your computer is not receiving power you should try plugging it in a different wall outlet first, if the problem still exist try a different power cable. If the problem is not solve you should change the power supply,and if the computer still does not receive power the you would need to replace the motherboard.
May 19, 2010 | Dell Dimension 4600C PC Desktop
When plugged in, my dell 4600c will not start up, and the light on the front of the tower stays yellow. Is this a power supply issue, a hard drive issue or a motherboard issue?
The only real way to test all is to have a 2nd pc. You can even unplug the hard drive from the motherboard just to test the MB and power supply. The bios will still load without a hard drive attached to it.
Dec 21, 2009 | Dell Dimension 4600C PC Desktop
I need printed instructions on how to install Dell Dimension 4600c power supply. I ordered the part but it came with no instructions.
Power Supply Removing the Power Supply caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions in your Owner's Manual or Product Information Guide. caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before removing the cover.
  1. Follow the procedures in "Before You Begin."
  2. Remove the fan assembly.
  3. Disconnect the AC power cable from the AC power connector on the back of the power supply.
  4. Unplug the DC power cables from the drives and system board.
  5. Remove the four screws that secure the power supply to the back of the computer.
OR
As you add more devices to your Dell Dimension 4600 desktop, it is important to ensure there is enough electrical power being fed to the components. While the 250 Watt power supply that comes standard with the Dell Dimension 4600 is acceptable at stock settings, it is almost certainly not capable of providing power for many more devices such as graphics cardsmag-glass_10x10.gif and multiple hard drives. If you add such devices, you also should upgrade your Dell Dimension 4600 power supply.
Aug 28, 2009 | Dell Dimension 4600C PC Desktop
I have a dimension 4600c. installed a new power
The power supplies have extra connectors which are not used.
Try doing a system restore to an earlier date when your computer was working ok.
Restart your computer and hit F8 while it is booting. When the menu comes up, select "Last Known Configuration"
This will bring it back to a time when it was working.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 11, 2009 | Dell Dimension 4600C PC Desktop
4600C no power, flashing amber light
i have a dimension 4600c. same problem. amber flashing light no sounds. replaced my power source and its now working fine. bought one on ebay for $47
Apr 11, 2009 | Dell XPS 700 PC Desktop
My dimension 4600c wont always read discs
sounds as though you need a new CD drive, the optics in your drive are not working correctly.
CD drives are available for cheap at any computer store or consumer electronics store.
very easy to replace, 4 screws hold it in, and plug in the cables to the new drive from the old one. please dont forget to rate!
Mar 31, 2009 | Dell Dimension 4600C PC Desktop
Dell 4600c will not power up -- green power button lit -
i think it may not power supply problem.it may be ram memory problem.try this,remove your ram and clean it with cloth and restore back.
Dec 16, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600C won't turn on
Unplug the unit. Re-seat the Memory and Daughter-boards. Plug in and try to start.
Nov 22, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600C will not power up
Sounds like the power supply is faulting. If not it is your mother board that has failed.
Mar 06, 2008 | Dell Dimension™ 4600C PC Desktop
Dell Dimension 4600 PC Desktop Logo
37 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
