Question about Electrolux EOD6335 Electric Double Oven
My fridgeidare ovens eliment sizzled and cought fire. no food was on it guessing i need a new elimenhow hard to change? where do i get one is it worth the hassle ? its approx 10 yrs old
  • Electrolux Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Nov 07, 2010
HBN 5605.0B power failure
Unplug the oven , then ohm out the heating eliment. My guess is that it is burned open.
Jul 13, 2014 | Bosch HBN 430560B / 430520B Single Oven
We replaced my ge gas oven ignightor but the gas is building up and when its heating to the right temp the door blosw open
sounds like the gas valve is leaking un plug the range and use a soapy water to find the leak
Jun 26, 2014 | GE Ovens
ON AN OVEN DOES BAKE MEAN BOTH ELIMENT HOT
hi,
depends on the manufacturer. on newer ovens the oven will run both elements to get you preheated quickly. once preheat has been established it switches back to the bottom element only.
jm
May 09, 2011 | Ovens
My oven burns the food on one side
You need a new element in your oven the thing that gets hot ,Im guessing your talking electric. Unplug unit before taking out old one
Feb 18, 2011 | Bosch Ovens
Should my broiler turn on when I am preheating my oven this does not seem right to me and my oven caught on fire last night
Yes the broiler will often turn on to help preheat the oven.
If it caught fire, it is not because of that, but because you have too much run over food in the oven. That is what caught fire. You need to clean it an NOT with the self clean!!
hetaman101
Aug 18, 2010 | Hotpoint Ovens
Double oven,the top ovens lower heating eliment will not work-I have relaced it and tried the lower ovens eliment still nothing,the broiler(upper)eliment works fine?
There are some small relays on the circuit board in the area of the controls. These relays are undersized and normally fail shortly after the warranty period. If you are handy with electical work and a soldering iron you can replace the components on the board using standard items from Radio Shack. If not, then buy the circuit board but expect to pay a lot. I once fixed a friend's oven and broiler by putting a low voltage optical semiconductor relay from Radio Shack into the space of each failed mechanical relay. Then I used those to operate large 40A definite purpose contactors -- normally used in HVAC systems. This required addition of a 24vac power transformer. All of it fit easily into the space behind the control panel of her drop-in range. The beauty of the optical semiconductor relays is that they isolated the electrical system of the original circuit board from the additional parts I was supplying. This makes is easy for anyone who works on it later to see the nature of the upgrade/repair.
Dec 12, 2009 | Ovens
Eliment in oven will not turn off
Sounds like the element is still getting a feed from the thermostat, even though it is in the Off position
If it has a temp indicator light and this is still glowing then you definately have a faulty thermostat.
The other possibility is that there is an earth fault on the element, and this could cause problem.
Plz rate this solution.
Thanks.
Dec 15, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Electrolux EOD6335 Electric Double Oven Logo
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
