Question about HP Pavilion a805n (PS519AA) PC Desktop
Cannot install a new graphic card. The name of the card is GeForce 9500 series. The slot inside the CPU to install a video card is shaped how it needs to be, but backwards. Any way to fix this? Should I buy another graphics card? Is there any models from Nvidia that fit into this slot that you know of? Again, the model is and HP Pavillion a805n.
5 Suggested Answers
costin
  • 12 Answers
SOURCE: Setting up dual monitors with NVIDIA 7300 GS Graphics Adapter
so...
your computer don't recognize your nvidia graphic card in PCI Express slot.
you are runing now with computer's integrated graphic card?
if so then you won't have dualview option. in this case it looks for me like you've installed in the wrong way your graphic card.
your NV GeForce 7300 GS has 2 video output?
if yes then you should have the option for 2 monitors on nVIDIA control panel (i have check my nVIDIA GeForce 7600gt and in my case this option is present but is enabled only if i connect the second monitor, so try do so)
you have installed the latest nVIDIA drivers from the official website? http://www.nvidia.com/Download/index.aspx?lang=en-us
check if your video card is corect installed start/run type in " devmgmt.msc ". it will open device manager and under the display adapter tab you should see what video card you use now.
Posted on Feb 24, 2009
  • 61 Answers
SOURCE: i have a hp iq780 touchsmart pc.recently nvidia
if the hw is working fine then you can go to the device manager and uninstall the driver ... and then go to the nvidia website and install the driver sw for it
Posted on Mar 20, 2010
  • 39 Answers
SOURCE: Bad graphics card. Need suitable
heres your card http://www.buy.com/prod/axle-ax-66gt-512d2a8cdht-geforce-6600-gt-graphics-card-pci-express-x16/q/sellerid/19015909/loc/101/211556736.html
Posted on Jan 08, 2011
SOURCE: I have HP Pavillion M8330F desktop computer that
Am looking to install this card in a Gateway Computer DX 4850-45U
a) Can I do this?
b) there is a black/white thin wire coming off the card whith one white three hole connector. What is this wire and where on the mother board does this go to?
Posted on Jun 20, 2011
What cheap but good video card should i get to run modern warfare 2 on my dell desktop computer
From what I can determine, for you to have the permornace you need for Modern Warfare 2, the following are the recommended computer requirements:
A CPU: 2.4 GHz dual core or better, RAM: 1 GB on XP / 2 GB on Vista and Windows 7 and a
GeForce 9500 GT 1GB memory Graphics board. (this is a PCI Express slot board).
Make sure your Dell has the slot required for the graphics board, if no slot then there is an AGP board, but with 512MB memory that would work good.
Either graphice baord would cost about them same
Recommend, EVGA @ Negeeg.com or Tiger Direct.
Good Luck
Sep 04, 2011 | Nvidia GeForce FX 5500 256 MB, (256 MB)...
GEForce series AGP 5500 256MB when connected using Windows xp OS there is no display in the monitor intel pentium dual core 2g ram
If you're having trouble on display in your monitor,please check the following;
1. Check your CPU if its responding,booting or the power light indicator is running.
2. Check the video card slot pin if its align and clean,as well as the serial/com cable connected ion both ends.
3. Try to replace another video card, might the current attached is damage.
4. Check all cords and see if there's some intermittent lines neither need to replace new cord.
good luck,
Jun 29, 2011 | Nvidia GeForce FX 5500 Video Card Graphic...
I downloaded the 32 bit vista driver for a nvidia geforce 9500 gt graphics card and it says it cant find the device even though its in there
same problem here sir.. i had a hard time looking fo the installer of my video card.. i don't wanna downgrade to winXP.. just pot here if you found the solution.. tnx..
Dec 26, 2010 | Nvidia GeForce 9500 GT, PCI Express Video...
How do i install geforce 6200
Hello! You must first shutdown your computer. Open your cpu and connect the video card on the agp slot of the motherboard. Make sure it is properly seated. Return back the cover of the casing. Connect the vga cable of your monitor to the vga connector of the video card. turn on the computer. The operating system will automatic read the new found hardware. Now try to download the driver of the video card this will give the video card its properties to change its resolution sizes and graphics output. The download site can be found here, just enter the code you see from the image and click download.
Jun 10, 2010 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
My nvidia 9500gt drivers stop responding during gameplay and the game crashes and throws me out on windows
While your computer is on, see if the fan attached to your video card is working. If it does, check the temperature inside your cpu. Overheating is one of the reason for logging out on window during online games. If possible additional cooler fan must be install inside the cpu. If that did not help suggest you replace your video card.
May 17, 2010 | Nvidia GeForce 9500 GT, PCI Express Video...
Lenovo desktop pci express slot
it may that ur pci express slot not working. u contact ur graphics card retailer or go with the cpu to his shop.
Jul 01, 2009 | Lenovo GeForce 6200, (64 MB) PCI Express...
Sims 3? new card?
No, a 9000 will not be enough. You'll need something from this list, and it will have to be AGP.
NVIDIA GeForce series
    FX 5900, FX 5950
    6200, 6500, 6600, 6800
    7200, 7300, 7600, 7800, 7900, 7950
    8400, 8500, 8600, 8800
    9300, 9400, 9500, 9600, 9800
    G100, GT 120, GT 130, GTS 150
    GTS 250, GTX 260, GTX 280, GTX 285, GTX 295
ATI Radeon™ series
    9500, 9600, 9800
    X300, X600, X700, X800, X850
    X1300, X1600, X1800, X1900, X1950
    2400, 2600, 2900
    3450, 3650, 3850, 3870
    4850, 4870
Jun 27, 2009 | ASUS ATI RADEON HD3450, PCI Express Video...
"Call of Duty" runs in slow motion on my PC.
Hi thomas,
Upgrading video cards will definitely increase in performance. You asked whether you should upgrade your entire PC or just the card and that really depends on the hardware you are running. If all of your hardware just barely meets the requirements than upgrading the videocard WILL give you a noticeable improvement but obviously it will not be as good as getting a better CPU and more RAM as well as a new card.
A good measure of a cards performance is based on the series of cards it is from. Your Geforce is from the 6000 series of Nvidia cards, they have 7000, 8000, and even 9000 series cards atm.
I would recommend something like an XFX Geforce 9800 GTX+ series card with 512MB of onboard memory, or any other competing card in the 200$ price range. This will definitely give you an increase in performance, and is a very popular card.
Hope this helps and please take a second to rate!
Mar 20, 2009 | HP Pavilion a1610n PC Desktop
Can a Dell Dimension 2400 take a GeForce 6600 graphics card?
This card can only Be installed in a Tower CPU. Your Card slot will not Accept this.
Jan 23, 2009 | Computers & Internet
Software
First of all, you should not even mention that is a cracked version, I will fake I did not hear that. I am sure you installed the pirate version only to test it on your computer, and you will buy the original if this works.
Regarding the games here are the specification:
Minimum System Requirements:
You must have these minimum system specifications for the game to function correctly. We do not provide support for configurations that do not meet the minimum requirements.
  • Operating System: Microsoft Windows® 2000/XP (Windows 95/98/ME/NT Not Supported)
  • CPU: Pentium 4 1.5Ghz or Athlon XP Equivalent
  • RAM: 512MB
  • Graphics: 100% DirectX 9.0c compatible video card which supports Hardware TnL and Pixel Shader 2.0 (GeForce FX / Radeon 9500 or higher)
  • Sound: 100% DirectX 9.0c Compatible Sound Card
  • DVD-Rom: Quad-speed (4x) Dvd-Rom Drive
  • Hard Drive: 5.0GB free disk space
  • Input Devices: 100% Windows 2000/XP compatible Mouse and Keyboard (Gamepads and controller are not supported)
Recommended System requirements:
  • CPU: Pentium 4 2.4Ghz or Athlon XP/64-bit equivalent
  • RAM: 1024MB
  • Graphics: ATI X800 series, Nvidia GeForce 6800 series or higher video card
  • Sound: 100% DirectX 9.0c Compatible Sound Card, Sound Blaster X-Fi series
  • DVD-Rom: Eight-speed (8x) DVD-Rom drive or faster
This game requires a CPU of at least 2.4 Ghz and a powerful video card, such as
ATI X800 series, Nvidia GeForce 6800 series or higher.
You also need
DirectX 9.0c installed, that may be the reason why it does not start.
Try downloading
DirectX 9.0c here, if it does not work, then, providing that CPU is good enough, you will need to upgrade video adapter or get a new computer.
Download from here and install:
Download details: DirectX End-User Runtime
or
Download details: DirectX 9.0c Redistributable for Software Developers
Sometimes you need an overpowered computer to play latest games, standard computers are usually not powerful enough for new games, that is the reason why they invented Xbox and PS.
See here my favourite computer for gaming.
Sep 13, 2008 | Computers & Internet
Open Questions:
Official Toshiba Support ' Toshiba Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Virus like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Apr 19, 2018 | Toshiba Computers & Internet
See all HP Pavilion a805n (PS519AA) PC Desktop Questions
HP Pavilion a805n (PS519AA) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
