Question about Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV
There is no spark. I've replaced the plug, and when I hold the metal threads of the plug against the cylinder housing and pull the starter cord, there is nothing. The spark plug wire goes into a sealed module, so there is no way to check it as far as I can tell. I removed one wire lead from teh kill switch just in case it had failed "shorted" but that did not change anything.
    Problem Solver:
  • 8 Answers
Replace the coial
Posted on Nov 07, 2010
I have a 2004 popular gas blower but can't get it to start an how would I make adjustments if needed as far as carburetor?
I would start by taking the spark plug out. Is it wet? Should be dry with a little black soot on it. Put the wire back on it and hold the threads against the cylinder head. Hold this by the rubber spark plug boot. Pull the cord and see if you see spark. Next take out the air cleaner and make sure it is clean.
Mar 04, 2016 | Garden
Will not start, no spark
try this test. take off the spark plug cap ( they unscrew ) snip a small piece off the ht lead ( as the metal inside will be chewed from the thread of the cap ) with a new cut hold the lead against any metal near it ( the cylinder head etc ) and pull it over. you should see a spark from the lead ? if you do you can replace the cap ( it will have new wire to screw into now ) and try fro spark at plug ( no spark new plug needed ) ..if you get no spark from the ht lead unscrew it from the coil and try a new lead
Apr 30, 2015 | Poulan Pro PP133 17" Gas Trimmer
Craftmans lawn mower 5.5 wont start up. what r some of the things i need to checik
Check for Spark. Take out the plug. With the Wire attached, hold the threads up against the engine as to Ground it. Then Have someone pull the starter cord and see if you have spark at the plug. If you do, then you have a Gas issue and
Aug 09, 2013 | Garden
Stihl hedge trimmer non start
remove the spark plug from the cylinder and plug the wire onto it hold it against metal and pull the starter cord and watch for spark
Jun 01, 2012 | Garden
How do I check for spark on a two cycle homelite blower?
remove the spark plug hook it up to the wire pull the engine over while holding the plug against the metal and watch for spark
Apr 22, 2012 | Garden
Homelite hlt25cs, pull starter cord, wont engage starter clutch, cant find how to access it
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. ``
Feb 02, 2012 | Homelite Garden
Getting to much gas in the cylinder . wont start
Flush out the cylinder by running it with choke off, leave for 5 minutes then try to start again with choke on.
Check that the air filter isn't dirty as this can cause too much fuel to be sucked in through the carburettor.
Ensure that you have a spark by removing plug and holding body of plug against the metal of chainsaw body while pulling starter rope. This can be awkward and possibly risky. Ideally you should do this with fuel removed from the tank and allow the gas to evaporate from the cylinder. You also have to think of how to keep the spark plug against the chainsaw as it will bounce about while pulling the cord.
Feb 19, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
I have 5000mtm pressure washer ,starter wll not turn over and there is spark to to starter,what do yo think
Take out spark plug
Put cap on spark plug
Hold spark plug by spark wire
Put spark plug threads against edge of hole where spark plug came out. Metal to metal.
Pull start cord.
No spark, then you need new spark coil from small engine repair shop
Oct 15, 2010 | Mi T M WP-2700-4MHB Pressure Washer
** Help Starting **Yard Machine 21inches 139cc
amiseybold;
First check for spark. Remove the spark plug. Leave the spark wire connected. Hold the plug against the metal of the mower engine so you have a ground and can see the gap of the electrode where the spark jumps across. Have someone pull the starter cord and verify that you have a spark. Hold it by the threads of the plug so you don't get a little spark jolt yourself.
go to an auto parts store and get a can of starter spray (it's actually ether), Remove the lawnmower spark plug and spray a little ether in the plug hole. Put the plug back and tighten it and see if it starts.
It will probably start, run for 5 or 10 seconds and then die. Repeat this procedure once or twice again and eventually it will start to draw gas from the lawnmower tank.
A seasonal tip. when you put the mower up for the winter, **** the remaining gas out of the tank, start the engine and let it run until it uses up the gas in the carburetor. This will make iot much easier to start in the spring
Hope this helps Good Luck Loringh PS Please give me a rating
Nov 08, 2008 | Yard Machines 158cc Push Lawn Mower #11a...
Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV Logo
650 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
