Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series leaving soap behind
I have a Kenmore 80 series model 110.28812790. The last few weeks I am having problems with soap left behind in each load. The machine seems to be spinning fine and draining good, but there is a lot of vibration in the drain hose. I have checked and find that the machine is still level. I have not changed soaps or overloaded the machine. Any suggestions?
  • 426 Answers
Check for clogs in the output line (the drain hose)
Posted on Jun 17, 2008
Kenmore dishwasher ultrawash debris on glasses
Fill the soap cup with vinagar and run it while its empty.
Mar 09, 2012 | Kenmore Dishwashers
White residue left behind. Glasses come out pure white! had dishwasher for yr. and half and worked great! Now the last few months this white film is left and dishes are not coming out as clean. I use a...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
Oct 26, 2010 | Whirlpool Dishwashers
My dishwasher is leaving residue or soap scum on my dishes...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
May 02, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a Kenmore Series 80 washer and the tub
i would check the motor coupler
it sits behind the motor before the transmission
this model
thre piece part that drives the transmission
Oct 15, 2009 | Washing Machines
Laundry soap Residue
As a last resort add about 200grams of washing soda crystals to the drum before you start the wash.
Jun 24, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer leaves soap residue on clothes no matter
After speaking with someone with trouble shooting experience in these matters, I now believe the problem lies NOT with the washer but with a bad batch of laundry detergent which fails to dissolve properly in the water.
Mar 12, 2009 | Kenmore 22422 Top Load Washer
Does not drain
Try cleaning out the exit filter which is usually under a swinging flap at the front of the machine. If it isn't there it will be somewhere easily accessible. This should be cleaned every 2 weeks. Also the outlet hose could be blocked with a build up of debris and soap that gets stuck over a period of time.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Dryer - Series 80 - Model 96586200
the brown streaks are from the seals most likely from the front seal ... if your handy it will be an easy fix..
Oct 12, 2008 | Dryers
Broken Kenmore dryer 80 series
Hi Dave. The problem is the drive belt. They aren't that difficult to replace and can be done with just a few tools. I'll need the exact model number off of the dryer to explain how to gain access to it, though. The number can be found behind the door on the cabinet (it'll start with 3 digits then a decimal point then more digits, like this; xxx.xxxxxxx)
The part number for the repair is 4392065. This is a complete maintenance kit for your dryer. I recommend it because since your belt wore out, there are other parts that should be taken care of at the same time. Here's a picture and a place to order if you can't find it locally.
Oct 18, 2007 | Dryers
Kenmore 24032\24036 Top Load Washer Logo
111 people viewed this question
Sal De
 Brian Main
Brian Main
