Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Replace or repair drain hose - Frigidaire FEX831CS Top Load Stacked Washer/Dryer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Frigidaire Expert
  • 154 Answers
REPLACE
Posted on Nov 08, 2010
Tip
LG Dishwasher Fault Codes
Failure Code > Condition : Check/Repair
  • 1E Water inlet problem > Condition : Not reached to the normal water level in spite of 10 minute water supply. Water supply problem. The inlet hose is kinked. The water pressure is to low (10psi) Inlet valve. The inlet water valve filter is clogged. The hall sensor. The impeller of Air guide is bound. Remedy : Check resistance of inlet valve ( 950-1300ohms) Clean valve. Check pressure. Replace the Air braker.
  • OE Drain error > Condition: The drain hose kinked or blocked. Wiring connections. The drain outlet of sump is blocked. The drain pump/motor or circuit is troubled : Remove kink. Check wiring. Measure the resistance of drain motor (20-40ohms) Replace the drain motor or repair the circuit.
  • E1 Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.Replace the connections of hose. Check the point of damages and repair or replace the related parts. Correct drain connections. Replace the impeller of the washing pump.
  • FE Excess Error > Condition : Excessive water is supplied than normal water level (automatically drain pump operated. Possible cause: The inlet valve is troubled,or the controller.Possible cause: The inlet valve is troubled,or the controller. Replace valve or the controller.
  • BE (Thermal error) > Condition: the resistance of the thermistor not normally out put. Possible cause the inlet water temperature is very high(over 194°F) Wiring connections. Thermistor problem.Check temps to dishwasher 120°F needed. Check thermistor 11-14kohms at 77°F. Replace the PCB.
  • LE( Motor error ) > Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.Correct wiring connections. Replace the cause of resrtiction. Replace the washing motor. Replace the PCB.
on Feb 26, 2011 | Dishwashers
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
How to fix drain hose on LG WM2487H M
The following are a number of things to check for the OE (drain error) indication.
If the washer does not drain then the drain pump may be clogged, damaged, or defective.
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Open the drain pump filter tray at the lower left of the machine and check whether it is clean, check also that the pump impeller spins freely. Remove the hoses from the pump and check for any obstructions.
First, check the drain hose to determine if it is kinked, twisted, or bent. If the drain hose is bent, straighten it out. In addition, remove the drain hose and check it for obstructions. If the drain hose has any obstructions, try to remove them. If necessary, replace the drain hose.
Check the machine's water level frequency by pressing the WASH/RINSE + DELAY WASH buttons simultaneously. Check the reading on the display, if it is below 260 (26 Khz) then have someone measure the resistance of the pump motor coil.
It should be between 10-20 Ohms resistance, if too high or too low, replace the pump assembly as it cannot be repaired.
Mar 08, 2016 | LG Washing Machines
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
Ddw1899BLS built in dishwasher wont drain
follow this steps and fix it. Merry Christmas.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#3#ixzz2nvKv4oia
Dec 19, 2013 | Danby DDW497W 22 in. Countertop Dishwasher
Water will not drain and agitator wont move
Water will not drain from machine
1.kinked or clogged hose----clean drain hose
2.pump does not run----readjust & tighten pump-drive mechanism
3.suds lock----remove suds,, add cold water
4.faulty transfer valve---replace
5.defective timer----replace
6.loose belt---adjust belt
No agitation
1. Motor failure---repair or replace motor
2.faulty timer contacts---replace timer
3.faulty transmission---repair or replace
4.defective control solenoid---replace
5.broken linkage---repair or replace linkage
6.faulty water level switch---replace switch
Sep 23, 2011 | Washing Machines
Drain hose has a small hole spraying out water. How difficult is it to replace the drain hose myself?
sometimes u can repair that leak with electrical tape. is your machine leaking where the hose comes out of the unit? they only sell the drain hose with the wiring loom attached. better to repair than dismantel unit. please reply and i will help u whatever u decide, good luck.
Apr 30, 2010 | Fisher and Paykel GWL11 Top Load Washer
My Whirlpool dishwasher is not draining on the last cycle and the heating coil is not heating. Should I repair or replace it?
You can try to find the drain blockage b4 replacing it. Easiest is to check the hose and connections to the drain under the sink. Make sure the hose is not kinked. Remove the hose and check for food blockages. If it is connected to a garbaqe disposal make sure the drain plug on the disposal has been removed.
May 13, 2008 | Dishwashers
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
53 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
